node-red-contrib-difference 1.0.0
Node-RED difference calculator - calculates the difference between two numeric inputs
npm install node-red-contrib-difference
Node-RED Difference Calculator - calculates the difference between two numeric input values.
  • Calculates A - B from two input values
  • Configurable topic names for inputs
  • Absolute value mode (|A - B|)
  • Configurable decimal places (0-10)
  • Outputs detailed input info
Behavior
  • Input A identified by configurable topic (default: "a")
  • Input B identified by configurable topic (default: "b")
  • Result = A - B
  • Output triggered on every new message once both values are known
Example
topic="a", payload=24.5  → stored as A
topic="b", payload=18.2  → stored as B
Output: 24.5 - 18.2 = 6.3
Property Description Default
Topic A Topic name for input A "a"
Topic B Topic name for input B "b"
Absolute Output absolute value false
Decimals Number of decimal places 2
Input
  • msg.payload - Numeric value
  • msg.topic - Required - Must match Topic A or Topic B
Runtime Override
msg.reset true = reset both values
Output
  "payload": 6.3,
  "inputs": {
    "a": { "topic": "a", "value": 24.5 },
    "b": { "topic": "b", "value": 18.2 },
    "result": 6.3,
    "absolute": false
Use Cases
Application Description
Temperature Difference between two sensors
Energy Consumption difference between readings
Level Water level difference
Node Status
  • a(24.5) - b(18.2) = 6.3 - Result calculated
  • Waiting for a... - Input A missing
  • Waiting for a and b... - Both inputs missing
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
146 in the last week
  • difference
  • difference
  • subtract
  • minus
  • math
  • calculator
