node-red-contrib-dialoqbase 1.0.0
Node-RED node for dialoqbase
npm install node-red-contrib-dialoqbase
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-dialoqbase, or run the following command in your Node-RED user directory, typically ~/.node-red
Wrapper dialoqbase API
Sample parameters
msg.api = 'chat/completions';
msg.params = {
    "model": "gpt-3.5-turbo",
    "messages": [
            "role": "system",
            "content": "You are a helpful assistant."
            "role": "user",
            "content": "Hello!"
    "max_tokens": 7,
    "temperature": 0
Sample Flow
You can make this json string into a flow by using the node-red flow import function.
alt
alt
Version: 1.0.0
Updated 2 years, 9 months ago
4 in the last week
  • dialoqbase
  • dialoqbaseApiKey
  • node-red-contrib-contribgen
  • dialoqbase
  • chatbot
  • AI
  • search api
  • AI 검색
  • Completion
  • image generation
  • Text Embeddings
  • Fine tunes
  • Moderations
  • ChatGPT
  • Ollama
  • LLM
  • Local LLM
  • nodejs
