node-red-contrib-denon-sxp 1.0.1
Denon AVR control node for Node-RED
npm install node-red-contrib-denon-sxp
A Node-RED node to communicate Denon AVR receivers over telnet (port 23) TCP/IP connection.
This fork fixes socket/timeout handling issues and improves connection stability.
Run command on Node-RED installation directory
node-red-denon-flow
If you want to use this node simply inject message's payload as string:
Denon-Out node sends commands to Denon devices
Commands with no arguments
Master Volume
MV20
Master Volume set to 20 - command from Denon AVR protocol: DENON_PROTOCOL_V7.6.0.pdf
Master Volume Up
MVUP
Master Volume UP by 0.5 - command from Denon AVR protocol: DENON_PROTOCOL_V7.6.0.pdf
Master Volume Down
MVDOWN
Master Volume DOWN by 0.5 - command from Denon AVR protocol: DENON_PROTOCOL_V7.6.0.pdf
Commands with arguments
Currently, there is only one such command implemented: SetVolumeDB. One may use setvolumedb too, cause it's case insensitive. So, msg object should look like:
    "topic": "setvolumedb",
    "payload": -65.5
It will set the master volume to -65.5dB.
Denon-In
Node sends to single output messages from Denon equipment with structure:
    "topic": "denon",
    "payload": "PWON"
where notification could be PWON and data contain additional info, arguments for current notification.
Collect debug log for issues
Current package uses debug package: https://www.npmjs.com/package/debug. Run your node-red with command to enable debug output:
set DEBUG=node-red-contrib-denon-sxp
node-red
for globally installed Node-RED, or
node node-red/red.js
for local Node-RED. Highly recommend to use cross-env package to set environment variables in cross OS way.
Additional documentation
Take a look at Denon AVR protocol: DENON_PROTOCOL_V7.6.0.pdf
Version: 1.0.1
Updated 2 months, 2 weeks ago
  • denon-controller
  • denon-out
  • denon-in
  • denon
  • avr
