node-red-contrib-delta-timed 0.3.0
Node for Node-RED that computes the difference between messages, including optionaly a period of time.
npm install node-red-contrib-delta-timed
node-red-contrib-delta-timed npm version npm downloads Unlicense
$ npm install node-red-contrib-delta
Restart Node-RED and use the node!
Or from the Node-RED's palette, search for "node-red-contrib-delta-timed
Time type (interval | timeperiod) Explaining this category will let the node choose the best way to work :
  • No period type (null)
By choosing this option, the node will check by pair the last value and the incoming value.
  • Interval type (number)
By choosing this option, the node will perform his check each period defined
  • Timeperiod type (Times)
By choosing this option, the node will perform his check between the timeperiod defined every minute. Optionaly, you can set a threshold that, when he is defined, will send message only if the threshold is exceeded
See the node information for more details
This is free and unencumbered software released into the public domain.
For more information, please refer to the UNLICENSE file or unlicense.org.
Version: 0.3.0
Updated 10 years, 1 month ago
License: Unlicense
7 in the last week
  • delta
  • node-red-contrib
  • delta
  • timed
  • measure
  • trigger
  • metrics
