node-red-contrib-debug-file 0.1.0
A Debug-style Node-RED node that can also write the selected value to a file.
npm install node-red-contrib-debug-file
A Debug-style node that can show a selected message value in the Debug sidebar and write that same value to a log file. It has no output, so it can be attached to a flow exactly like the built-in Debug node.
  • Debug sidebar and runtime-log output can remain enabled independently.
  • The file name is automatically derived from the node name: My debug becomes My debug.log.
  • A path can be static, msg, JSONata or an environment variable.
  • Append or overwrite; optional newline and automatic directory creation.
  • Same encoding set as the built-in Write File node, including set by msg.encoding.
  • Serialises objects as JSON and preserves Buffers when encoding is none.
After publication to npm, open Menu → Manage palette → Install, search for node-red-contrib-debug-file, install it, then restart Node-RED if requested.
For a local preview, use Manage palette → Install → upload and select the packed .tgz file.
Notes
This is a new debug file node. Node-RED does not allow an add-on to insert fields into the edit dialog of the built-in debug node safely, so the core node stays untouched.
The filename is sanitised on every platform and defaults to debug.log when the node has no name. For a separate file per logger, give each node a unique name.
MIT
Version: 0.1.0
Updated 1 month, 3 weeks ago
  • debug-file
  • debug
  • logging
  • file
