node-red-contrib-deadband 1.0.3
Node-RED deadband filter - only passes values when change exceeds threshold
npm install node-red-contrib-deadband
Node-RED Deadband filter - only forwards values when the change exceeds a threshold.
  • Filters small value changes (noise)
  • Configurable deadband threshold
  • Optional initial reference value
  • Runtime override via msg
  • Reset function
Behavior
  • Change >= Deadband → value is forwarded + new reference stored
  • Change < Deadband → message is blocked, no output
  • First value always passes through (sets reference)
Example
Deadband = 0.5, reference = 20.0:
Input 20.3 → Δ0.3 → blocked
Input 20.6 → Δ0.6 → forwarded, new ref = 20.6
Input 20.8 → Δ0.2 → blocked
Input 21.2 → Δ0.6 → forwarded, new ref = 21.2
Property Description Default
Deadband Minimum change to forward value 0.5
Initial Value Initial reference value (optional) -
Input
msg.payload - Numeric value to filter
Runtime Overrides
msg.deadband Overrides deadband temporarily
msg.reset true = reset reference value
Output
{ "payload": 20.6 }
The original msg object is forwarded unchanged.
Use Cases
Application Deadband
Temperature sensor 0.5
Analog value (0-100) 2
Power consumption (Watt) 50
Node Status
  • Idle - Waiting for first input
  • ✓ 20.6 - Value forwarded
  • ✗ 20.3 (Δ0.3) - Value blocked
Author
sr.rpo
MIT
Version: 1.0.3
Updated 7 months, 2 weeks ago
72 in the last week
  • deadband
  • deadband
  • filter
  • threshold
  • hysteresis
  • noise
  • plc
