node-red-contrib-dayjs 0.1.1
Wrapper of dayjs for Node-RED
npm install node-red-contrib-dayjs
Under development
A simple Node-RED node that integrates the versatile JavaScript library Day.js, offering an alternative to Moment.js.
You can install this node via the manage palette option in the Node-RED editor or by navigating to your Node-RED user directory and running:
Input
This node expects a parsable string in the following formats:
'2018-04-04T16:00:00.000Z'
'2018-04-13 19:18:17.040+02:00'
'2018-04-13 19:18'
1318781876406
1318781876
If the input is not parsable, the current time is used.
Manipulate
Operations
The operation to perform is specified via the msg.operation property, which supports the following options:
  • add
  • subtract
  • startOf
  • endOf
Units
Specify the unit of time using the msg.unit property, which can take the values:
  • year
  • quarter
  • month
  • week
  • isoWeek
  • day
  • hour
  • minute
  • second
Amount
The amount of time to manipulate is provided via the msg.amount property.
Output
By default, the output is provided as an ISO String, but it can be customized. You can also specify a custom output format using the (Format Options).
Additionally, you can adjust the timezone (e.g., 'utc', 'Europe/Paris')).
Example
Contributing
Acknowledgments
Version: 0.1.1
Updated 2 years, 9 months ago
4 in the last week
  • day.js
  • dayjs
