node-red-contrib-datetime-format 1.1.2
A Node-RED node that formats datetime values (epoch, ISO 8601 or Date) into human-readable strings with configurable timezone, locale and format.
npm install node-red-contrib-datetime-format
A Node-RED node that formats datetime values — the epoch timestamps, ISO strings and Date objects that flow through Node-RED — into human-readable strings, with a configurable timezone, locale and output format.
Powered by Luxon.
  • Flexible input — reads from any msg/flow/global property (default msg.payload) and auto-detects the value type:
    • epoch milliseconds or seconds (auto-detected, or forced),
    • ISO 8601 strings (e.g. 2026-06-22T14:30:00Z),
    • JavaScript Date objects.
  • Configurable timezone — any IANA name (e.g. Europe/Zurich, Asia/Tokyo). Blank uses the server's local timezone.
  • Configurable locale — any BCP 47 locale (e.g. de-CH) for localised month/day names and ordering.
  • Two formatting modes:
    • Presets — named formats such as DATETIME_MED (e.g. Jun 22, 2026, 2:30 PM),
    • Custom tokens — Luxon format strings such as yyyy-LL-dd HH:mm:ss.
  • Configurable output — writes to any msg/flow/global property (default msg.payload), leaving everything else untouched.
  • Optional JSON output — write a structured object (formatted, iso, epoch, seconds, zone, locale) instead of a plain string.
  • Robust errors — unparseable input or an invalid timezone raises a catchable error (use a Catch node) and shows a red status; the flow keeps running.
From your Node-RED user directory (typically ~/.node-red):
Or, to install this checkout locally for development:
npm install /path/to/this/repo
Then restart Node-RED. The datetime format node appears in the function category of the palette.
Wire it after any node that emits a datetime. For example:
[ inject (timestamp) ] → [ datetime format ] → [ debug ]
Field Description Default
Input Property to read the datetime from (msg / flow / global). msg.payload
Epoch unit How to interpret numeric input: Auto-detect, Milliseconds, or Seconds. Auto-detect
Timezone IANA timezone name. Blank = server local time. (blank → local)
Locale BCP 47 locale for names/ordering. Blank = system default. (blank → default)
Format Preset (named format) or Custom tokens (Luxon format string). Preset
Preset The named preset to use (shown when Format = Preset). DATETIME_MED
Tokens The Luxon token string (shown when Format = Custom tokens). yyyy-LL-dd HH:mm:ss
Output Property to write the result to (msg / flow / global). msg.payload
Output as JSON Write a structured object instead of a plain string (see Output). (off)
Locale note. A blank Locale uses Node.js's default, which is derived from the LANG / LC_ALL / LC_TIME environment variables — not your OS regional settings. When those aren't set to a real locale (common for services, e.g. LANG=C.UTF-8), Node falls back to en-US, so output is US-formatted. For predictable results set Locale explicitly (e.g. de-CH), or start Node-RED with LANG/LC_ALL set to your locale.
Input
The input value (default msg.payload) may be:
Type Example Notes
epoch ms 1700000000000 ≥ 11 digits → milliseconds in auto mode
epoch seconds 1700000000 ≤ 10 digits → seconds in auto mode
numeric string "1700000000000" parsed as epoch
ISO 8601 string "2026-06-22T14:30:00+02:00" offset honoured, then converted to the target zone
Date object new Date()
Output
The formatted string is written to the configured Output property. With the defaults, msg.payload is replaced by the formatted string.
Enable Output as JSON to write a structured object instead — handy when a downstream node needs more than the display string:
  "formatted": "Nov 14, 2023, 10:13 PM",
  "iso": "2023-11-14T22:13:20.000Z",
  "epoch": 1700000000000,
  "seconds": 1700000000,
  "zone": "UTC",
  "locale": "en-US"
Field Description
formatted The formatted string, using the chosen preset / tokens.
iso ISO 8601 string in the target timezone.
epoch Epoch milliseconds.
seconds Epoch seconds (whole).
zone The resolved IANA timezone name.
locale The resolved locale.
Presets
Preset Example (en-US, Europe/Zurich)
DATE_SHORT 6/22/2026
DATE_MED Jun 22, 2026
DATE_MED_WITH_WEEKDAY Mon, Jun 22, 2026
DATE_FULL June 22, 2026
DATE_HUGE Monday, June 22, 2026
TIME_SIMPLE 2:30 PM
TIME_WITH_SECONDS 2:30:45 PM
TIME_24_SIMPLE 14:30
TIME_24_WITH_SECONDS 14:30:45
TIME_WITH_SHORT_OFFSET 2:30:45 PM GMT+2
TIME_WITH_LONG_OFFSET 2:30:45 PM Central European Summer Time
TIME_24_WITH_SHORT_OFFSET 14:30:45 GMT+2
TIME_24_WITH_LONG_OFFSET 14:30:45 Central European Summer Time
DATETIME_SHORT 6/22/2026, 2:30 PM
DATETIME_SHORT_WITH_SECONDS 6/22/2026, 2:30:45 PM
DATETIME_MED Jun 22, 2026, 2:30 PM
DATETIME_MED_WITH_SECONDS Jun 22, 2026, 2:30:45 PM
DATETIME_MED_WITH_WEEKDAY Mon, Jun 22, 2026, 2:30 PM
DATETIME_FULL June 22, 2026 at 2:30 PM GMT+2
DATETIME_FULL_WITH_SECONDS June 22, 2026 at 2:30:45 PM GMT+2
DATETIME_HUGE Monday, June 22, 2026 at 2:30 PM Central European Summer Time
DATETIME_HUGE_WITH_SECONDS Monday, June 22, 2026 at 2:30:45 PM Central European Summer Time
The examples above are en-US. In the editor, the Preset dropdown shows each example in your own locale (the browser reads your OS regional settings), so a de-CH user sees 22.06.2026, 14:30, etc. Note this is an editor preview only — the node's actual output follows the Locale field (see the note under Settings).
Custom tokens
Select Custom tokens and supply a Luxon format string. A few common tokens:
Token Meaning Example
yyyy 4-digit year 2026
LL 2-digit month 06
LLLL full month name June
dd 2-digit day 22
HH 2-digit hour (24h) 14
hh 2-digit hour (12h) 02
mm minutes 30
ss seconds 45
a AM/PM PM
ZZZZ timezone abbreviation CEST
See the full Luxon token table.
Examples
Input (msg.payload) Timezone Format / Tokens Output (msg.payload)
1700000000000 UTC yyyy-LL-dd HH:mm:ss 2023-11-14 22:13:20
1700000000000 Asia/Tokyo yyyy-LL-dd HH:mm:ss 2023-11-15 07:13:20
1700000000000 UTC (en-US) Preset DATETIME_MED Nov 14, 2023, 10:13 PM
"2026-06-22T14:30:00Z" Europe/Zurich dd.LL.yyyy HH:mm 22.06.2026 16:30
Development
npm install      # install luxon + dev dependencies
npm test         # run the mocha test suite
The runtime is split into:
Tests live in test/ and use node-red-node-test-helper.
MIT
Version: 1.1.2
Updated 5 months ago
Rating: 5.0 2
118 in the last week
  • datetime-format
  • datetime
  • date
  • time
  • format
  • timezone
  • luxon
  • human-readable
