node-red-contrib-dataprobe-iboot 0.0.5
Node-RED node for dataprobe iboot g2
npm install node-red-contrib-dataprobe-iboot
send http request to iboot g2 dataprobe AC relay
Information
Config : Enter your Iboot IP and Credentials
IP Address: Ex: 192.168.1.254
Username: Ex: admin
Password: Ex: admin02c691
Status dly(sec) = Its the delay beetween each status request is send to the iboot
Power on msg.payload = "IBOOT_ON" //
Power off msg.payload = "IBOOT_OFF" //
Power cycle msg.payload = "IBOOT_CYCLE" //
Each time you send a power * request you will received the status off the device a status request is send each 10 seconds
OUTPUT MESSAGE
IBOOT_TURN_ON = a request to be turn on has been send to the iboot
IBOOT_TURN_OFF = a request to be turn off has been send to the iboot
IBOOT_CYCLE_START = a request to start a power cycle has been send to the iboot
IBOOT_CYCLE_FINISH = that message send a power on to the iboot to finish the power cycle
IBOOT_IS_ON = This is a ON status received from the iboot, that message also confirm you are connected to the iboot
IBOOT_IS_OFF = This is a OFF status received from the iboot, that message also confirm you are connected to the iboot
Version: 0.0.5
Updated 4 years ago
License: unknown
1 in the last week
  • i-boot
  • dataprobe
  • g2
  • i-boot-g2-2
