node-red-contrib-datamatrix-restore 1.1.1
Reads QR and Data Matrix codes from noisy DPM photos and returns the scanned text
npm install node-red-contrib-datamatrix-restore
Node-RED node Code restore. It crops a noisy QR or Data Matrix photo (including industrial DPM), reads the code, and returns the scanned text.
The same node runs on Windows, Linux, and ARM. Install dependencies on the machine that runs Node-RED. Do not copy node_modules between operating systems.
Requirements
  • Node.js 18 or later
  • Node-RED 3.0 or later
  • Internet only during npm install (so sharp can download the native binary for that OS/CPU)
Palette Manager (after the node is in the Node-RED library)
  1. Menu → Manage palette → Install
  2. Search for datamatrix-restore or Code restore
  3. Install node-red-contrib-datamatrix-restore
  4. Restart Node-RED if the editor asks you to
npm (recommended)
In your Node-RED user directory:
Windows:
cd %USERPROFILE%\.node-red
Restart Node-RED. The node appears in the palette as Code restore.
From GitHub
npm install rivasrayos/node-red-contrib-datamatrix-restore
From a local clone
git clone https://github.com/rivasrayos/node-red-contrib-datamatrix-restore.git
npm install /path/to/node-red-contrib-datamatrix-restore
Docker / offline devices
If the Node-RED host has no outbound internet, npm install on that device will fail.
On a PC with internet, install native modules for the target OS, then copy the package (including node_modules) into the Node-RED user directory.
Example for Alpine Linux ARM64:
npm install --omit=dev --cpu=arm64 --os=linux --libc=musl
Copy the folder into node_modules/node-red-contrib-datamatrix-restore inside the Node-RED user directory and restart Node-RED.
zxing-wasm is loaded from the local .wasm file. The node does not download WASM at runtime.
Flow
image URL or Buffer → Code restore → debug
A separate crop node is not required. Send the image in msg.payload and { x, y, width, height } in msg.crop.
Input
Property Type Description
msg.payload string or Buffer Image URL or image Buffer (configurable)
msg.crop.x number Crop left
msg.crop.y number Crop top
msg.crop.width number Crop width
msg.crop.height number Crop height
Output
msg.payload string Scanned text
msg.format string QR or DataMatrix
msg.image Buffer Clean 200×200 PNG
msg.original Buffer Cropped photo
If the code cannot be read, the node reports an error and does not send a message.
MIT
Version: 1.1.1
Updated 3 months, 1 week ago
  • datamatrix-restore
  • datamatrix
  • qr
  • qrcode
  • barcode
  • dpm
