node-red-contrib-data-tracer 0.1.0
NodeRed node that adds metadata about who and when the data has been treated
npm install node-red-contrib-data-tracer
NodeRed Data Tracer
It helps enriching given object with metadata.
It add information about when the data has been treated and by which NodeRed flow.
E.g. the following object...
...will be enriched as following:
    _metadata: {
        logs: [
                flowName: 'example-collector',
                time: 1545218628149,
                flowName: 'example-enricher',
                time: 1545218628151,
How to use it
Pick data-tracer from the list of nodes.
Wire it at the end of the nodered process.
Configure the node property, the flow name and the target property.
Local development
npm install -g node-red
node-red
Nodered should works localhost:1880, now kill it 🔫
npm link /path/to/node-red-contrib-data-tracer
node-red
The node data-tracer is now available 💪
Working NodeRed example:
[{"id":"709ae9a5.fb128","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"e7a83422.2c5da8","type":"inject","z":"709ae9a5.fb128","name":"","topic":"","payload":"{\"id\":123,\"_metadata\":{\"logs\":[{\"flowName\":\"example-collector\",\"time\":1545229474815}]}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":60,"wires":[["f99e6105.8bb5e"]]},{"id":"c3c992e7.79cf48","type":"debug","z":"709ae9a5.fb128","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":130,"y":220,"wires":[]},{"id":"f99e6105.8bb5e","type":"data-tracer","z":"709ae9a5.fb128","name":"","prop":"","flowName":"example-enricher","dataProp":"_metadata","x":150,"y":140,"wires":[["c3c992e7.79cf48"]]}]
Version: 0.1.0
Updated 8 years, 5 months ago
2 in the last week
  • data-tracer
  • log
  • metadata
  • enricher
