node-red-contrib-data-logger 0.1.6
Logs data stored in JSON object into a CSV file with columns extracted from JSON object.
npm install node-red-contrib-data-logger
A Node-RED Node that logs data stored in JSON object into a CSV file with columns extracted from JSON object..
  • Data to be logged should be passed in msg.payload as a JSON object. The header row will be populated with the property names of the JSON object on log file creation.
  • The Columns property in node properties can be used as a filter if filled with JSON object's property names as comma separated string. If left empty, all properties of JSON object in msg.payload will be logged to file.
  • msg.path should be passed in for setting the location where the file will be logged into.
  • msg.fileName should be passed in to set the file name of the log file.
Example Flow
[{"id":"88258a55.901628","type":"inject","z":"3c62c132.455f6e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":440,"y":480,"wires":[["54f959e1.e9fc88"]]},{"id":"54f959e1.e9fc88","type":"function","z":"3c62c132.455f6e","name":"Log Data","func":"var logPath = ".";\nvar folderName = "DataLog\\TestData";\nmsg.path = logPath + "\\" + folderName;\nmsg.fileName = "testFile";\n\nvar data = {};\n\nfor (var i = 0; i < 10; i++){\n data["Data"+i] = i*10;\n}\n\nmsg.payload = data;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":480,"wires":[["dbb8420e.ee474"]]},{"id":"dbb8420e.ee474","type":"data-logger","z":"3c62c132.455f6e","name":"","columns":"","parentDir":"","enableBuffering":"0","bufferSize":10,"bufferTimeout":1,"enableDateColumn":"1","seperator":",","x":880,"y":480,"wires":[]}]
Version: 0.1.6
Updated 3 years, 7 months ago
Rating: 2.0 2
11 in the last week
  • data-logger
  • data logger
  • csv logger
  • logger
