node-red-contrib-dashboard-terminal 1.0.6
A FlowFuse dashboard node that provides an interactive terminal window for the host system (pure JS, no native deps).
npm install node-red-contrib-dashboard-terminal
A FlowFuse Dashboard node that provides an interactive terminal connected to the host system.
  • Full interactive terminal (via node-pty)
  • Requires login after deployment
  • Inactivity timeout (based on no typing, not long-running processes)
  • Works with FlowFuse Dashboard
Run inside your Node-RED user directory:
    Drag the dashboard-terminal node into your flow.
    Deploy.
    Open your FlowFuse Dashboard – you’ll see the terminal widget.
    First, login by sending:
    { "payload": { "user": "myuser", "pass": "mypassword" } }
    (Currently accepts all logins – customize for real auth.)
    Once logged in, send strings to msg.payload as keystrokes.
    Terminal output is sent out as messages with msg.topic = "output".
Config
    timeout – inactivity timeout in seconds (default: 300). If no keystrokes are entered, the user will be logged out.
Notes
    This node spawns a shell on the host. Use with caution in multi-user or exposed environments.
    Extend login logic for production use (PAM, LDAP, or hashed user store).
Version: 1.0.6
Updated 1 year, 2 months ago
Rating: 0.0
78 in the last week
  • dashboard-terminal
  • flowfuse
  • dashboard
  • terminal
  • shell
