node-red-contrib-dashboard-bar-chart-data 0.9.94
Transforms sensor measurements or meter readings to be displayed in dashboard-chart as bar-chart
npm install node-red-contrib-dashboard-bar-chart-data
Bar-chart-data
Donate via PayPal
This node transforms msg.payload, attaches (and stores) past values and build a message that could be linked to the ui_chart node configured as "bar chart". It can handle measurements (e.g. current power consumption) or meter readings (e.g. gas/water/energy meter count) and calculate the sum, min, max or average in a customizable time range. Works with multiple topics, too.
Properties :
Name
The name of this node
x-interval
1 bar per:
  • second
  • minute
  • quarter-hour
  • hour
  • day
  • year
  • x-size
    How many bars should be displayed. Example: x-interval=hours, x-size=24 : 24 bars, each 1 hour. That means that the last 24 hours will be displayed
    Unit
    The unit of the payload, will be displayed in the bar-chart
    Precision
    Number of decimals
    Meter reading
    Set this to "True" if msg.payload is a meter reading, so that this node will use the difference of the current and last value.
  • True: msg.payload is meter reading, like the total energy, gas or water meter value or operating hours
  • False: msg.payload is a measurement, like power (watt), pressure or temperature
  • Aggregate by
  • sum: sum all values in x-interval
  • min: just display the smallest value in x-interval
  • max: just display the largest value in x-interval
  • avg: average value in x-interval
  • Prevent negative
    For meter readings only: If the current meter reading is smaller than the last value, the difference between new and old value will be discarded and the new meter reading will be stored and become the current one. This is helpful if a new meter is installed or if the end of the meter is reached and the it starts from zero again. Without this switch the (negative) difference of new and old value will be calculated and displayed, what is not what you usually want when you want to display meter readings.
    Screenshot
    Clear
    A message with the payload "clear" and the same topic like the sensor will reset the data for this specific sensor only. A message with the payload "clear" without a topic (empty string) will delete all data, so that the chart will be blank again.
    Set (start) meter value
    A message with the payload "set_meter_value 123.45" will set the (start) value for the topic to 123.45. The calculation of the difference between the new and the previous meter reading value will be skipped. You can use this when your old meter is replaced with a new one and the values begins from 0 (again).
    Restore
    If you put the output of this node to the input of this kind of node (via persist node), the data will be restored. This could be helpful to avoid getting a blank bar-chart after node-red has been restarted (reboot).
    Logfiles to bar-chart
    If msg.ts or msg.timestamp is given, this timestamp will be used for the reading instead of the current timestamp. You could use this feature to load (older) logfiles into bar-chart data. Caution: All values older than the given timestamp will be discarded => You have to start with the oldest value and will loose all values that are not inside the log files - except the current values are older than the ones from the logfile.
    Additional output: Sum, Min, Max, Settings
    This is included in the output message (and could be used to set chart title etc.):
  • The node settings (unit, x_interval, x_size, precision, is_meter_reading, agg_by) as json in msg.settings
  • The smallest value of all bars (min) in msg.min
  • The largest value of all bars (max) in msg.max
  • The sum of all bars in msg.sum
  • Sample Result
    Sample Flow
    [{"id":"307f07f.8b8c1f8","type":"bar-chart-data","z":"3b18da32.bba756","name":"bar-chart-data","x_interval":"seconds","x_size":"24","unit":"Liter","precision":"0","is_meter_reading":"False","agg_by":"sum","x":340,"y":140,"wires":[["11edb254.d31a6e","3e6bc8b7.f4bc88"]]},{"id":"11edb254.d31a6e","type":"ui_chart","z":"3b18da32.bba756","name":"","group":"c716d8f1.4bb848","order":3,"width":"12","height":"4","label":"Liter letzte {{msg.settings.x_size}} Sekunden {{msg.data_sum}}","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"30","removeOlderPoints":"","removeOlderUnit":"60","cutout":0,"useOneColor":true,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":510,"y":100,"wires":[[]]},{"id":"3e6bc8b7.f4bc88","type":"persist in","z":"3b18da32.bba756","name":"store","storageNode":"e0e7ea5c.056af8","x":510,"y":180,"wires":[]},{"id":"8343e961.cbf7e8","type":"inject","z":"3b18da32.bba756","name":"sensor","topic":"devices/homie-har/water/liter","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":100,"wires":[["307f07f.8b8c1f8"]]},{"id":"29a85329.d6b03c","type":"persist out","z":"3b18da32.bba756","name":"store","storageNode":"e0e7ea5c.056af8","x":130,"y":180,"wires":[["307f07f.8b8c1f8"]]},{"id":"c716d8f1.4bb848","type":"ui_group","z":"","name":"bar-chart","tab":"957fd14a.a1277","disp":true,"width":"12","collapse":false},{"id":"e0e7ea5c.056af8","type":"persist-store","z":"","filename":"~/store.json","interval":"60"},{"id":"957fd14a.a1277","type":"ui_tab","z":"","name":"bar-chart","icon":"dashboard","disabled":false,"hidden":false}]
    Version: 0.9.94
    Updated 2 years, 5 months ago
    Rating: 5.0 7
    111 in the last week
    • bar-chart-data
    • dashboard
    • chart
    • bar-chart
    • bar
    • timeseries
