node-red-contrib-dashboard-average-bars 0.0.6
Calculate and display the average values of msg.payload in a bar chart.
npm install node-red-contrib-dashboard-average-bars
Pre-requisites :
node-red-contrib-dashboard-average-bars requires node-red-dashboard. The average-bars node is necessarily linked to the node-red dashboard template node. The average-bars node create the input msg of the template node and the template node display the chart.
Releases :
Version 0.0.6 :
  • Fixed bug : wrong bar height when dashboard automatically refresh
Version 0.0.5 :
  • The top and the bottom values of the Y-axis can be forced.
Version 0.0.2 :
  • First published version
Node properties :
X-axis :
  • last hour : 1 bar per minute
  • last day : 1 bar per hour
  • last week : 1 bar per day
  • last month : 1 bar per day
  • last year : 1 bar per month
  • msg.topic : 1 bar for each msg.topic
Y-axis :
  • "auto" : y-axis is calculated according to the msg.payload received.
Bar style :
  • rectangle : classical bar
  • equalizer : equalizer bar style
Bar colors : choice the color gradient of the bars
Display values : check boxes to display or hide values :
  • bar values : value above the bar
  • x-axis values : period values (or msg.topic if x-axis = msg.topic )
  • last value : the last msg.payload received
  • chart average : the average of all values received
  • chart minimum : the minimum of all values received
  • chart maximum : the maximum of all values received
Unit : unit to display behind values
Decimals : number of decimals to display
Font color : color of the scale and the values
Note :
  • Average-bars node values can be cleared by sending the string "clear" in the msg.payload.
  • Node-red reboot : keep the node values by storing the context values ( see contextStorage attribute in settings.js )
Version: 0.0.6
Updated 8 years, 9 months ago
Rating: 3.0 2
7805 in the last week
  • average-bars
  • dashboard
  • chart
