node-red-contrib-dashboard-2-switchboard 0.1.0
Node-RED Dashboard 2.0 compact switchboard console widgets.
npm install node-red-contrib-dashboard-2-switchboard
Node-RED Dashboard 2.0 Switchboard
Compact Node-RED Dashboard 2.0 control-panel widgets inspired by sourcesimian/mqtt-panel.
This package provides Dashboard widgets only. It does not connect to MQTT directly; Node-RED flows should own MQTT input/output, retained messages, transforms, and automations.
  • switchboard text: display text values, optionally editable
  • switchboard button: emit a configured command value
  • switchboard switch: cycle through configured states
  • switchboard select: choose one configured state from a dialog, optionally as a button
  • switchboard fader: edit a numeric range value, or display it as a gauge
  • switchboard lamp: display a mapped state
  • switchboard image: display an image URL, optionally as a button
  • switchboard iframe: embed a URL
See MANUAL.md for configuration details and examples.
Example Flow
Import examples/demo-flow.json into Node-RED for a dashboard that demonstrates every widget mode, including delayed feedback for interactive widgets.
Import examples/switchboard-dark-theme.json if you only want the reusable Dashboard 2.0 switchboard: Dark theme.
Build
npm install
npm run build
The build writes the Dashboard bundle to resources/ui-switchboard.umd.js.
Local Development With Make
This repository keeps a disposable Node-RED user directory in _node_red.
make setup
make link
make run
Then open:
http://127.0.0.1:1880/
make setup installs Node-RED, Dashboard 2.0, and MQTT support into _node_red. make link builds this package and symlinks it into _node_red/node_modules as node-red-contrib-dashboard-2-switchboard.
Install Locally Into Node-RED
From your Node-RED user directory:
npm install /path/to/node-red-contrib-dashboard-2-switchboard
Restart Node-RED, then add Switchboard nodes from the palette.
Attribution
The visual direction and widget behavior are based on sourcesimian/mqtt-panel, which is MIT licensed.
Version: 0.1.0
Updated 5 months, 2 weeks ago
  • node-red-dashboard-2
  • switchboard
  • control-panel
  • console-panel
  • dashboard
