node-red-contrib-dali-sensor 0.4.0
Node-RED node for parsing DALI sensor data and outputting motion and lux
npm install node-red-contrib-dali-sensor
Node-RED dali-sensor Node
Overview
The DALI Sensor node is designed for use with the Lunatone DALI-2 IoT Gateway to easily filter and process DALI-2 sensor signals inside Node-RED.
It allows you to monitor occupancy (motion), lux levels, and lux alarms from connected DALI-2 sensors, with filtering by short address and instance type/number.
This node is ideal when you want to:
  • Extract and use specific motion or lux data from the DALI bus.
  • Convert raw DALI sensor frames into clean, meaningful outputs.
  • Optionally add automatic delayed Off logic for motion detection.
  • Short address filtering — Only process messages from the target DALI-2 device.
  • Scheme selection — Supports both:
    • Device scheme (instance types)
    • Device/Instance scheme (instance numbers)
  • Instance mapping — Configure which instance is motion and which is lux.
  • Lux setpoint — Auto-generate a Lux Alarm output when lux drops below the threshold.
  • Boolean or string outputs — Select "true"/"false" or "On"/"Off" for binary outputs.
  • Auto-Off option — Motion turns On immediately, then Off after a non-resettable delay.
  • Only send on change (new) — Each output is sent only when its value changed, instead of on every sensor frame.
Outputs
The node has three outputs:
Output Port Name Description
1 Motion Latched occupancy state. Controlled by Auto-Off if enabled.
2 Lux Value Raw lux reading (integer).
3 Lux Alarm Boolean/On-Off depending on whether lux is below the setpoint.
Auto-Off Feature
When Auto Off is enabled:
  • "On" is emitted immediately on motion detection.
  • First "Off" starts a delayed turn-off (non-resettable).
  • Further Off frames during countdown are ignored.
  • An On during countdown cancels the pending Off.
  • Default delay is 30 seconds (configurable).
  • msg.delay (in ms) on the message that starts the countdown can override the timeout.
  • Status shows a live countdown.
If Node-RED restarts during a countdown, the node will re-arm the remaining delay and emit Off when it expires.
Only Send on Change
DALI-2 sensors re-report their state every few seconds, and by default every frame re-emits Motion, Lux Value and Lux Alarm even when nothing changed. Wired straight to an NHC2 output, that means a write every few seconds per sensor — enough to hit the Hobby API rate limit and make the controller re-evaluate everything that depends on those flags.
When On Change is enabled:
  • Each output is sent only when its payload differs from the last one sent on that output.
  • A Motion frame no longer re-sends Lux Value / Lux Alarm (and vice versa).
  • The first frame after a deploy or restart is always sent, so downstream devices re-sync.
  • Auto-Off still emits its delayed Off (it is a change).
Field Description
Name Node label in the flow.
Short Address DALI short address of the target device.
Motion Instance Instance number/type for motion (for Device/Instance scheme).
Lux Instance Instance number/type for lux (for Device/Instance scheme).
Lux Setpoint Threshold for triggering Lux Alarm.
Use Boolean Output binary states as "true"/"false" instead of "On"/"Off".
On Change Only send an output when its value changed (default off).
Auto Off Enable automatic delayed Off for motion.
Timeout Delay in seconds before motion turns Off (default 30).
Example Flow
        "id": "dali-sensor-example",
        "type": "dali-sensor",
        "name": "Office Motion & Lux",
        "shortAddress": "1",
        "motionInstance": 0,
        "luxInstance": 1,
        "luxSetpoint": 400,
        "useBoolean": true,
        "enableAutoOff": true,
        "autoOffDelaySec": 30,
            ["debug-motion"],
            ["debug-lux"],
            ["debug-alarm"]
Version: 0.4.0
Updated 1 month, 1 week ago
3 in the last week
  • dali-sensor
  • dali
  • dali2
  • dali-2
  • sensor
  • lux
  • motion
  • occupancy
  • presence
  • lighting
  • control
  • automation
  • iot
  • building
  • building-automation
  • smart-lighting
  • lighting-control
  • gateway
  • lunatone
  • dali-gateway
  • dali2-gateway
  • iot-gateway
  • dali-sensor
  • lux-sensor
  • motion-sensor
  • occupancy-sensor
  • presence-sensor
  • niko
