node-red-contrib-daichi-cloud 2.0.0
Node-RED nodes to monitor and control Daichi / Daikin HVAC units through Daichi Comfort Cloud
npm install node-red-contrib-daichi-cloud
Node-RED nodes for Daichi Comfort Cloud (web.daichicloud.ru), the cloud behind Daichi and Daikin Wi-Fi HVAC modules. Read the state of your air conditioners, send them commands, and react to changes as they happen.
  • Live updates over the cloud's MQTT broker, no polling.
  • Every command the cloud supports: power, mode, target temperature, fan speed, swing.
  • One account connection shared by every device node in your flows.
https://raw.githubusercontent.com/niklv/node-red-contrib-daichi-cloud/master/example.png
Unofficial. Not affiliated with Daichi or Daikin. The cloud API is undocumented and may change.
Requirements
Node-RED 5.0 or later
Node.js 22 or later
Use the Node-RED palette manager, or run this in your Node-RED user directory:
npm i node-red-contrib-daichi-cloud
Getting started
  1. Drag a daichi device node onto a flow.
  2. Open it, add a new Account, and enter the e-mail and password of your Daichi account.
  3. Pick your air conditioner from the Device list. It is filled in from the cloud.
  4. Deploy. The node sends the device state right away and again on every change.
The package ships an example flow. Import it from the Node-RED menu under Import → Examples → node-red-contrib-daichi-cloud.
daichi device
Monitors and controls one air conditioner.
Input
Field Type Notes
topic string Must be control. Any other topic is ignored.
payload.functionId number The function to change.
payload.value number or boolean A number for value functions, a boolean for on/off functions.
Output
Field Type Notes
topic string Always device-state.
payload object The device state.
A message goes out when the flow starts, whenever the cloud pushes an update, and after every accepted command. Cloud updates carry only the fields that changed, so the node merges them into the last known state before sending it on.
The node status shows the connection and the current temperature. A rejected command, an unreachable device, or a missing account is reported as a node error that you can catch with a catch node.
daichi service
A configuration node holding the credentials of one Daichi account. It logs in once and keeps a single MQTT connection that every device node reads from. Credentials live in Node-RED's credentials file, not in the flow.
Sending commands
Function ids differ between models, so read them from your own device. Wire a debug node to the device output and look at payload.pult, where every function lists its id, title and state.
Turn the unit on:
{ "topic": "control", "payload": { "functionId": 466, "value": true } }
Set the target temperature to 24°:
{ "topic": "control", "payload": { "functionId": 472, "value": 24 } }
A typical split unit reports a dozen functions such as cooling, heating, auto, dry, fan, quiet mode, vertical swing, comfort sleep, powerful and economy.
Troubleshooting
Node status Meaning
no service The device node has no account configured.
error The account could not log in, or the device state could not be read. Check the error in the debug sidebar.
disconnected, 21℃ The air conditioner itself is offline. The cloud still reports its last temperature.
Set DEBUG=daichi in the Node-RED environment to log every cloud response. Access tokens and passwords are masked.
Development
npm test          # unit tests against an in-process Node-RED
npm run lint      # oxlint, type-aware (npm run lint:fix to autofix)
npm run fmt       # oxfmt (npm run fmt:check in CI)
npm run typecheck # tsc --noEmit
npm run build     # bundles both nodes into build/
Each node lives in src/nodes/<node> as a runtime half (index.ts), an editor half (editor.ts) and its edit dialog (editor.html). The build bundles the runtime as an ES module for the Node-RED server and inlines the editor script into build/<node>.html for the browser.
References
MIT
Version: 2.0.0
Updated 2 months ago
149 in the last week
  • daichi-service
  • daichi-device
  • air-conditioner
  • daichi
  • daikin
  • hvac
