node-red-contrib-custom-chatgpt4o 1.2.18
A Node-RED node that interacts with OpenAI machine learning models to generate text and image outputs like 'ChatGPT-4o' and 'DALL·E 2'.
npm install node-red-contrib-custom-chatgpt4o
Platform npm Downloads MIT License
Supercharge your Node-RED flows with AI! Seamlessly integrate with OpenAI's powerful models like GPT-4, GPT-4o and DALL·E 2, and unlock a world of creative possibilities. Create imaginative chatbots, automate content generation, or build AI-driven experiences. The power of AI is just a node away!
Table of Contents
Getting Started
To start using node-red-contrib-custom-chatgpt4o, you can install it through the built-in Node-RED Palette manager or using npm:
Setup
With these, you're ready to configure your node-red-contrib-custom-chatgpt4o nodes.
With node-red-contrib-custom-chatgpt4o, you have the power to select the behavior of the node by setting the Topic property value to image, edit, turbo , or gpt4 / gpt4o. You can control the node with a single required message property msg.payload or dynamically set the behavior with incoming messages using read from msg.topic.
For detailed information on the usage of these modes, please refer to the OpenAI API documentation.
1. When msg.topic is set to completion:
  • [Required] msg.payload should be a well-written prompt that provides enough information for the model to know what you want and how it should respond. Its success generally depends on the complexity of the task and quality of your prompt. A good rule of thumb is to think about how you would write a word problem for a middle schooler to solve.
  1. When msg.topic is set to image:
    • [Required] msg.payload should be a prompt of text description of the desired image.
    • [Optional] msg.size should be a string of the desired image dimensions. [Default:256x256]
    • [Optional] msg.format should be a string of either b64_json or url. [Default:b64_json]
  2. When msg.topic is set to edit:
    • [Required] msg.payload should be a prompt of text to use as a starting point for the edit.
    • [Required] msg.last should be a string of text to use as the input to be edited.
  3. When msg.topic is set to turbo:
    • [Optional] msg.history should be an array of objects containing the conversation history. [Default:[]]
  4. When msg.topic is set to gpt4 or gpt4o:
Additional optional properties
The following optional inputs are supported - msg.max_tokens, msg.suffix, msg.n, msg.temperature, msg.top_p, msg.presence_penalty, msg.frequency_penalty, msg.echo, msg.API_KEY and msg.ORGANIZATION. See the nodes built-in help tab for more information on how they are used.
External Links
Bugs and Feature Requests
Encountered a bug or have an idea for a new feature? We'd love to hear from you! Feel free to submit an issue on our GitHub page.
Version: 1.2.18
Updated 2 years, 7 months ago
Rating: 2.0 4
11 in the last week
  • chatgpt
  • chatgpt
  • nodejs
  • javascript
  • api
  • flow
  • npm
  • machine-learning
  • node
  • example
  • text-generation
  • openai
  • image-generation
  • code-generation
  • conversational-ai
  • gpt-3
  • gpt-4
  • gpt-4o
  • dall-e
  • ai
