node-red-contrib-ctrlx-automation 1.9.8
Node-RED nodes for ctrlX AUTOMATION
npm install node-red-contrib-ctrlx-automation
This package node-red-contrib-ctrlx-automation contains nodes to easily connect to ctrlX AUTOMATION devices from Bosch Rexroth.
Using the nodes you can read from and write to the ctrlX Data Layer.
The nodes can run in a Node-RED app environment on a ctrlX CORE device as well as on a third-party device which runs Node-RED.
Important: It is recommended to upgrade the AutomationCore System App to version 1.20.0 (XCR-V-0120, part of ReleaseMilestone 23.03) or newer for full subscription settings support! Older versions are still supported but with less features.
Install using the managed palette from inside Node-RED.
In Node-RED (preferred)
  • Via Manage Palette -> Search for node-red-contrib-ctrlx-automation
In a shell
  • go to the Node-RED user data directory, e.g.: ~/.node-red
  • run npm install node-red-contrib-ctrlx-automation --save
Usage - Quick Overview
There are two new nodes which appear in the category ctrlX AUTOMATION in your Node-RED palette. In addition to that, a configuration node will be added to the project as soon as the nodes are used in a flow. The configuration node contains all settings for a connection to a device and is used by other nodes which are embedded in the flow and share the same session. Besides the hostname or IP address it is also necessary to provide the user credentials for authorization of your session in the configuration node.
Data Layer Request
This node can be triggered to execute read, write, browse, create or delete operations within the ctrlX Data Layer.
Data Layer Subscribe
This node allows to subscribe to value changes of an item in the ctrlX Data Layer. It is an input node, which does not need to be triggered, but automatically emits a new msg, when the value changes. The node is useful for continuous tracking of value in the ctrlX Data Layer and in this case more efficient than the Data Layer Request node, because it does not need to be triggerd to poll for a value. Instead, this node automatically watches for value changes on server side and publishes new values via server sent events and low overhead for data transmission.
Usage - Reference Manual
Besides this quick introduction, there is a Reference Manual which describes the nodes in more detail. It covers all the different configuration options, error handling, troubleshouting and generals hints for usage. For working with different nodes in the Data Layer it might also be useful to have a look at the Data Type Overview.
Examples
It might be helpful to have a look at the Examples document to find various flows for different use-cases. They demonstrate the different ways how the nodes can be used. Most of the examples are also directly available from within the Node-RED editor. They appear under the Examples section of the library import menu in Node-RED.
Release Notes
New features since version 1.9 are introduced in more detail in the release notes
Support
There is a troubleshooting section which covers common problems and solutions.
This repository is provided and maintained by Bosch Rexroth. Feel free to check out and be part of the ctrlX AUTOMATION Community. Get additional support, e.g. related to Bosch Rexroth Devices, Apps, SDKs and Services, or leave some ideas and feedback.
To report bugs, request changes and discuss new ideas you may also have a look at the issue tracker of this repository: https://github.com/boschrexroth/node-red-contrib-ctrlx-automation/issues
Important directions for use
Areas of use and application
The content (e.g. source code and related documents) of this repository is intended to be used for configuration, parameterization, programming or diagnostics in combination with selected Bosch Rexroth ctrlX AUTOMATION devices. Additionally, the specifications given in the "Areas of Use and Application" for ctrlX AUTOMATION devices used with the content of this repository do also apply.
Unintended use
Any use of the source code and related documents of this repository in applications other than those specified above or under operating conditions other than those described in the documentation and the technical specifications is considered as "unintended". Furthermore, this software must not be used in any application areas not expressly approved by Bosch Rexroth.
Changelog
* 2020-09-29: 1.2.0  - Initial release with request node for ctrlX Data Layer.
* 2020-11-28: 1.2.2  - fix: msg.topic is not set to path if msg.topic is undefined.
* 2020-12-02: 1.2.3  - Only documentation and diagnosis improvements.
* 2020-12-14: 1.2.4  - fix: Error when request was triggered immediately after deploy.
* 2020-12-20: 1.8.0  - Initial release which adds node to subscribe to ctrlX Data Layer.
                     - Support custom port after hostname. E.g. 'localhost:8443'.
* 2020-10-01: 1.8.1  - fix: automatic reconnect when device was not available on start of flow.
* 2021-02-22: 1.8.2  - Switched to ctrlX Data Layer API version v2 which is only available with AutomationCore 1.8.0 or newer.
                     - Introduced new setting to request node, which allows to set payload format to return only 'value' or 'value' and 'type'.
* 2021-03-10: 1.8.3  - Internal improvements for more compliant URI encoding of http requests.
* 2021-05-07: 1.8.4  - fix: allow to make a write without arguments (msg.payload = null). E.g. for 'diagnosis/confirm/error'.
* 2021-05-25: 1.8.5  - fix: make 'BROWSE' requests to support the payload property 'value only'.
* 2021-05-28: 1.8.6  - feat: make path tree view selection in property window to automatically expand to current path.
                     - fix: make subscribe node to emit an initial 'msg' after deploy, even if value does not change.
* 2021-06-29: 1.8.7  - fix: writing strings with non-ASCII symbols (e.g. 'ü') resulted in DL_TYPE_MISMATCH.
* 2021-07-04: 1.8.8  - fix: give each of the subscribe nodes his own counter to show in the status text.
                     - fix: allow to make a create without arguments (msg.payload = null). E.g. for '/motion/axs/<axs_name>/cmd/reset'.
* 2021-09-20: 1.8.9  - fix: read with argument failed with error 'DL_TYPE_MISMATCH'.
* 2021-10-19: 1.8.10 - fix: support 64bit integer as BigInt to prevent rounding errors on big integer values.
* 2021-10-22: 1.8.11 - fix: prevent "Failed login attempts" after flow gets redeployed with correct credentials (Bug392030).
* 2021-10-22: 1.8.12 - fix: make subscription to properly report error and reconnect when authorization token expires (Bug405282).
* 2022-01-27: 1.8.13 - refactor: update dependency versions. No functional change.
* 2022-03-02: 1.8.14 - fix: improve diagnostics for misconfigured subscriptions. E.g. when a single node of a subscription is missing (Bug449366).
* 2022-03-14: 1.8.15 - fix: make subscribe node useable on other ports than 443 (Bug457112).
                       fix: remove an uncaught exception which was introduced with version 1.8.14 (Bug454078).
* 2022-04-26: 1.8.16 - fix: possible connection break on heavy load for commands: create, delete, write.
* 2022-05-05: 1.8.17 - feat: added support for IPv6.
* 2022-05-06: 1.8.18 - fix: possible node crash on browsing with bad credentials.
* 2022-10-16: 1.8.19 - fix: make IPv6 work on device.
                     - fix: support addresses with special characters (e.g. '^' in 'mm/s^2').
                     - docs: updated and extended the example flows.
* 2022-10-20: 1.8.20 - fix: throw correct error on password change and dropped session (Bug534347).
* 2023-07-01: 1.9.0  - feat: dynamic subscriptions to change subscription at runtime
                     - feat: support new subscription properties
                     - feat: show and limit number of pending requests
                     - fix: default payload format changed to `value + type`
* 2023-07-17: 1.9.1  - fix: change sampling interval to microseconds
* 2023-08-07: 1.9.2  - fix: automatic reconnect of subscription on reboot of control
* 2023-09-04: 1.9.3  - fix: subscription with ipv6 address that contains a zone index
* 2024-03-13: 1.9.4  - fix: timeout of connection with Node.js v19. "Read timeout, received no data in undefinedms, assuming connection is dead"
* 2024-03-19: 1.9.5  - fix: update dependencies in package-lock
* 2024-05-24: 1.9.6  - fix: catch exception when server sends invalid/incomplete json in subscription (Bug849302).
                     - fix: add more tests to handle node address with invalid symbols
* 2024-12-06: 1.9.7  - fix: update dependencies in package-lock
                     - fix: further improve resilience on invalid data from server
* 2025-01-27: 1.9.8  - fix: no support for raw binary data (types/datalayer/raw). E.g. for some Ethercat nodes, returned now as a buffer for further processing.
About
Copyright © 2020-2024 Bosch Rexroth AG. All rights reserved.
https://www.boschrexroth.com
Bosch Rexroth AG
Bgm.-Dr.-Nebel-Str. 2
97816 Lohr am Main
GERMANY
Licenses
MIT License
Copyright (c) 2020-2024 Bosch Rexroth AG
Version: 1.9.8
Updated 1 year, 10 months ago
Rating: 5.0 3
13 in the last week
  • ctrlx-config
  • ctrlx-config-subscription
  • ctrlx-datalayer-request
  • ctrlx-datalayer-subscribe
  • ctrlX AUTOMATION
  • ctrlX OS
  • ctrlX CORE
  • ctrlX DRIVE
  • Bosch Rexroth AG
  • www.ctrlx-automation.com
  • www.boschrexroth.com
