node-red-contrib-ctr700-ipc 1.2.1
Node-RED nodes for SYS TEC sysWORXX CTR-700 series
About
The 'node-red-contrib-ctr700-ipc' is a Node-RED node collection for the sysWORXX CTR-700 Edge Controller from SYS TEC electronic GmbH (see https://www.systec-electronic.com/en/products/internet-of-things/sysworxx-ctr-700)
This node collection supports the data exchange between OpenPCS (IEC-61131-3 PLC Runtime System running on the sysWORXX CTR-700) and Node-RED. With the help of these nodes it is possible to use Node-RED as a graphical interface for OpenPCS PLC programs.
Apache License, Version 2.0 (see http://www.apache.org/licenses/LICENSE-2.0)
Run the following command in your node-RED user directory (typically ~/.node-red):
npm install node-red-contrib-ctr700-ipc
Content
- openpcs_read: node to read data from OpenPCS (OpenPCS -> Node-RED)
- openpcs_write: node to write data to OpenPCS (Node-RED -> OpenPCS)
Node status
The state of the nodes is indicated by a status object (dot, grey/green/red) and text (depending on IPC status)
