node-red-contrib-ctr700-io 1.2.1
Node-RED nodes for SYS TEC sysWORXX CTR-700 series
About
The 'node-red-contrib-ctr700-io' is a Node-RED node collection to support I/O access for the sysWORXX CTR-700 Edge Controller from SYS TEC electronic GmbH (see https://www.systec-electronic.com/en/products/internet-of-things/sysworxx-ctr-700)
Apache License, Version 2.0 (see http://www.apache.org/licenses/LICENSE-2.0)
Run the following command in your node-RED user directory (typically ~/.node-red):
npm install node-red-contrib-ctr700-io
Content
- ctr700_di: node to handle digital inputs
- ctr700_do: node to handle digital outputs
- ctr700_ai: node to handle analog inputs
- ctr700_led: node to handle run and error led of the module
- ctr700_switch: node to handle run/stop switch of the module
Node status
The state of the nodes is indicated by a status object (dot, grey/green/red) and text (depending on function)
