node-red-contrib-crypto-storage 0.0.5
Node-RED node for Crypto Storage with Block/Stream Ciphers
npm install node-red-contrib-crypto-storage
node-red-contrib-crypto-storage :package:
This is a subflow node for encrypting / decrypting payloads and creating encrypted stores on the specified folder utilizing AES for Block Ciphering and Rabbit for Stream Ciphering preserving the confidentiality of payloads.
Install :zap:
Cipher API :closed_lock_with_key:
  • :information_source: Encrypt: POST localhost:1880/encrypt
  • :information_source: Decrypt: POST localhost:1880/decrypt
The plaintext payload can be either a string or an object, you must define the function to use (encrypt/decrypt), the cipher key and the type of cipher to use (AES/Block Cipher or Rabbit/Stream Cipher).
:warning: In the case of AES, the mode (CBC/CFB/OFB/CTR) parameter must also be set!
CipherAPI
Cipher Encrypt Payload :key: :arrow_right:
  • Setting the payload of the Cipher Encrypt injector:
CE1
Cipher Encrypt Result :lock: :back:
  • Encryption response payload:
CE2
Cipher Decrypt Payload :key: :arrow_right:
  • Setting the payload of the Cipher Decrypt injector:
DE1
Cipher Decrypt Result :unlock: :back:
  • Decryption response payload:
DE2
Cipher Store API :toolbox:
  • :information_source: AES: POST localhost:1880/blockStore
  • :information_source: Rabbit: POST localhost:1880/streamStore
The plaintext payload can be either a string or an object, you must define the function to use (encrypt/decrypt), the cipher key and the filename of the crypto storage.
CipherStoreAPI
You firstly need to define the path of the store in the properties of the subflow:
CSO
Store Encrypt Payload :key: :arrow_right: :toolbox:
  • Setting the payload of the Store Encrypt injector:
CSB1
Store Encrypt Result :lock: :back: :toolbox:
  • Store encryption response payload:
CSB2
Store Decrypt Payload :key: :arrow_right: :toolbox:
  • Setting the payload of the Store Decrypt injector:
DSB1
Store Decrypt Result :unlock: :back: :toolbox:
  • Store decryption response payload:
DSB2
Version: 0.0.5
Updated 4 years ago
