node-red-contrib-crestron 1.1.2
Node-RED nodes for communicating with a Crestron TCP Server.
npm install node-red-contrib-crestron
If you think this project is very helpful to you, you can give this project a star⭐. You can also buy me a cup of coffee, hh (● '◡' ●) I will keep updating.
Thank you
WARNING
It is not recommended to use the SIMPL 4.14 version, when I use it, it will cause some strange problems in the program (cause other macros to fail). So I rolled back the version to 4.11.
This is My Software Version.
SIMPL : simpl_windows_4.11.06.01.1
CRESTRON_DATABASE : crestron_database_89.05.002.00
DEVICE_DATABASE : device_database_115.00.002.00
Donate via PayPal
Nodered-Crestron
This is a NodeRed Plugin to Crestron Prefessor(Use Tcp Socket to commucation)
The Plugin has 3 types,there is
Digital
Accept Value is true/false or 0/1
Analog
Accept Value is 0-65535
String
Accept Value is any String(length is depend crestron marco)
技术交流群:107927710,里面有很多大神呦
PS:This is a free trial
How to use
  1. install nodejs and npm in your computer
  2. install node-red sudo npm install -g node-red
  3. install crestron-node sudo npm install -g node-red-contrib-crestron
  4. run node-red
  5. use crestron-node
    crestron-node
  6. config Crestron Professor Server
    crestron-node-server
  7. Fill in the ID and choose the data type,Make sure to match the pins of Crestron's macro file
    crestron-node-edit
  8. send the msg to the node
  9. Open Crestron SIMPL Software to edit CresNode
    crestron-node-edit
CHANGE LOG
V 1.0.0 First version
V 1.0.1 Fixed no digital output
V 1.0.2 add 10 inputs, "Serial -> String" , Added data type to label name for easy differentiation
V 1.0.3 Change node label, Easy to identify V 1.0.4 Update Demo
V 1.0.5 fixed Digital Node ouput
V 1.0.6 Support Crestron 2 Series Control System®
V 1.0.7 Support Crestron 4 Series Control System®(Will not continue to update for now)
V 1.0.8
  1. Update README
  2. false signal not need FeedBack now
V 1.1.0 Support Get FeedBack,Please check demo to know how to use
V 1.1.1 fixed the string problem,Thanks @gregjwinter found this bug.
V 1.1.2 update 4-series demo.
TEST
I created 50 nodes and sent 50 messages to the Crestron host every 1s, which is equivalent to a message of 20ms. After a long test, the information was sent steadily
crestron-node
DEMO
crestron-node-demo
[{"id":"34261440.6a55fc","type":"crestron-node","z":"ff2337eb.0985b8","server":"52a4d5a6.b307cc","cid":"1","ctype":"Digital","name":"","x":330,"y":3420,"wires":[["f9e0f22e.47fed"]]},{"id":"4f260411.c27f4c","type":"inject","z":"ff2337eb.0985b8","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":3380,"wires":[["34261440.6a55fc"]]},{"id":"5133cbb1.818fa4","type":"inject","z":"ff2337eb.0985b8","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":3480,"wires":[["34261440.6a55fc"]]},{"id":"f9e0f22e.47fed","type":"debug","z":"ff2337eb.0985b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":520,"y":3420,"wires":[]},{"id":"e6a48e93.8382","type":"crestron-node","z":"ff2337eb.0985b8","server":"52a4d5a6.b307cc","cid":"1","ctype":"Analog","name":"","x":320,"y":3600,"wires":[["88c34897.52f8f8"]]},{"id":"38457b10.e8e674","type":"inject","z":"ff2337eb.0985b8","name":"","topic":"","payload":"123","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":3600,"wires":[["e6a48e93.8382"]]},{"id":"88c34897.52f8f8","type":"debug","z":"ff2337eb.0985b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":510,"y":3600,"wires":[]},{"id":"1d423a1c.444716","type":"crestron-node","z":"ff2337eb.0985b8","server":"52a4d5a6.b307cc","cid":"1","ctype":"String","name":"","x":360,"y":3700,"wires":[["bbce66c1.5813f8"]]},{"id":"c605c078.97ddd","type":"inject","z":"ff2337eb.0985b8","name":"","topic":"","payload":"Hello World!","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":3700,"wires":[["1d423a1c.444716"]]},{"id":"bbce66c1.5813f8","type":"debug","z":"ff2337eb.0985b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":510,"y":3700,"wires":[]},{"id":"1a1b9880.d45828","type":"inject","z":"ff2337eb.0985b8","name":"","topic":"","payload":"getState","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":3820,"wires":[["e6a48e93.8382","1d423a1c.444716","34261440.6a55fc"]]},{"id":"52a4d5a6.b307cc","type":"crestron-node-config","z":"","host":"192.168.1.10","port":"9999"}]
Version: 1.1.2
Updated 3 years, 9 months ago
License: MIT License
Rating: 4.7 13
24 in the last week
  • crestron-node
  • crestron-node-config
  • crestron
