node-red-contrib-crapssim 1.3.5
CrapsSim Companion — Node-RED nodes for building and running CrapsSim strategies via Engine API or Vanilla.
npm install node-red-contrib-crapssim
Node-RED Contrib Craps (Vanilla + Engine API)
A collection of custom Node-RED nodes for designing, validating, and exporting Craps betting strategies.
These nodes let you build strategies visually as a “recipe flow,” validate them, and export them as vanilla CrapsSim-compatible Python strategy files.
No coding required—just drag, drop, and connect blocks.
This node pack exposes a supported-only bet surface aligned with the CrapsSim Engine API. For the full list of supported bets and their mappings, see docs/bet_surface_capabilities.md.
Palette and node overview (Phase 6 UI/UX)
  • Palette categories:
    • Craps: Strategy Builder for bet construction, utility, and compilation nodes.
    • Craps: Execution for simulation/export nodes.
  • Major nodes and labels:
    • Builder: Bet: Line/Place/Lay/Odds, Bet: Props/Hardways/Hops, Bet Variable, Clear Bets, Compile Strategy.
    • Execution: Run: Engine API Simulation, Run: Batch Simulation, Run: Export to CrapsSim (Legacy).
  • Typical flow: Bet nodes → Compile Strategy → Run: Engine API Simulation (optionally followed by Run: Batch Simulation for multi-seed runs).
Phase 5 Overview (Odds, Parity, Batch)
  • Odds v1: Line and Come odds (odds_pass_line, odds_dont_pass, odds_come, odds_dont_come) map to the Engine API odds verb with the correct base. Odds are Engine-only; vanilla export rejects them explicitly.
  • Parity mode: Deterministic dice via roll_mode: "script" or parity_mode: true with dice_script entries per roll. Still sends seeds but rolls come from the script.
  • Batch runner: Execute the same strategy_config across multiple seeds (explicit list or generated range) and return aggregated stats (batch_summary) plus per-run rows (batch_result).
Action Grammar (Phase 7)
  • The Node-RED pack now compiles flows into a strategy_config object with an actions[] array describing each { verb, args, meta } tuple.
  • Verbs are defined centrally in the Verb Registry (lib/verb_registry.json), which also governs argument schemas and vanilla-export mappings.
  • Execution paths (Engine API Runner and vanilla exporter) prefer actions[] when present and fall back to legacy bets[] for older flows.
Most users never hand-edit strategy_config—the Strategy Compiler produces it automatically. Advanced users and integrations can inspect actions[] directly when needed.
  "strategy_name": "three_point_molly",
  "actions": [
    { "verb": "pass_line", "args": { "amount": 10 } },
    { "verb": "come", "args": { "amount": 10 } },
    { "verb": "place", "args": { "number": 6, "amount": 30 } }
Bet Surface Overview (Phase 1)
  • bet_surface.json at the repo root is the single source of truth for every bet identifier used by the pack. Each entry includes a canonical key, the engine code it maps to, and is currently supported for export.
  • Bet nodes (bet-type, bet-prop, bet-in, clear) emit canonical keys such as pass_line, place_6, or hardway_8. Exporters and validators use those keys to align with CrapsSim’s bet classes.
  • Supported today: Pass/Don’t Pass, Come/Don’t Come, Field, numbered Place/Lay (4/5/6/8/9/10), and Hardways (4/6/8/10).
Supported Bets (Phase 1)
Family Canonical keys (supported)
Line pass_line, dont_pass, come, dont_come
Field field
Place place_4, place_5, place_6, place_8, place_9, place_10
Lay lay_4, lay_5, lay_6, lay_8, lay_9, lay_10
Hardway hardway_4, hardway_6, hardway_8, hardway_10
Adding or Deprecating Bet Types
  1. Add or edit entries in bet_surface.json, setting supported to true when the CrapsSim engine/API can accept the bet and false when the UI should show it but exporters must ignore it.
  2. Update exporters/validators as needed in future phases to map new bets to CrapsSim classes.
  3. Keep this README and example flows in sync with the catalog so users can see what is available at a glance.
Version Compatibility
Phase 1 targets the current CrapsSim vanilla/API bet surface that exposes BetPassLine, BetDontPass, BetCome, BetDontCome, BetPlace, BetLay, BetField, and BetHardway. If CrapsSim adds or removes bet types, update bet_surface.json, the supported list above, and any related exporters/validators to stay aligned.
Example Flows
  • examples/simple_line_and_place_flow.json: Pass Line plus Place 6/8 using canonical keys with both the legacy recipe.debug path and the strategy compiler + exporter path for parity checks.
  • examples/hardway_example_flow.json: Hardway 6 and Hardway 8 via bet-prop.
  • examples/strategy_simple_line_place.json: Minimal Pass Line + Place 6/8 feeding strategy-compiler → export-vanilla with debug taps for msg.strategy_config and the exported Python.
  • examples/strategy_hardway_demo.json: Hardway 6/8 demonstrating how bet-prop → strategy-compiler → export-vanilla produces hardway bets in strategy_config.
  • examples/api_simple_line_place.json: Simple Engine API run for Pass Line + Place 6/8 with debug taps for sim_result and sim_journal.
  • examples/api_with_file_output.json: Engine API run with file-ready NDJSON journal wired into the standard Node-RED File node.
What is strategy_config?
strategy_config is the normalized object the node pack builds from your graph. Bet nodes emit canonical bet steps (with amounts and unit types), table nodes provide limits/multipliers, and the Strategy Compiler assembles everything into a single object that exporters and runners can consume.
You usually do not edit strategy_config by hand; it is produced automatically. In Phase 7 the canonical surface is actions[] (with legacy bets[] retained for compatibility):
  "strategy_name": "MyStrategy",
  "table": { "mode": "10", "multiplier": 10, "bubble": false },
  "actions": [
    { "verb": "pass_line", "args": { "amount": 10 }, "meta": { "unit_type": "units" } },
    { "verb": "place", "args": { "amount": 12, "number": 6 }, "meta": { "unit_type": "dollars" } }
  "bets": [
    { "key": "pass_line", "base_amount": 10, "unit_type": "units" },
    { "key": "place_6", "base_amount": 12, "unit_type": "dollars", "number": 6 }
  "metadata": { "created_by": "node-red-contrib-craps", "version": "1.3.0", "notes": "optional" }
Exporters and runners read strategy_config to build CrapsSim components. Amounts expressed in units are scaled using the table multiplier; amounts in dollars are passed through directly. When both arrays are present, the nodes prefer actions[] and ignore bets[] unless the actions list is empty.
Strategy Compiler node
  • Inputs: Expects msg.recipe.steps (emitted by bet nodes), plus optional msg.varTable and metadata (e.g., msg.strategy_name, msg.strategy_notes).
  • Outputs: Writes msg.strategy_config (and also msg.payload) containing the normalized strategy and table info.
  • Usage: Wire bet nodes → strategy-compiler → exporters/runners. You generally don’t need to know the internal schema beyond that; the node handles normalization and validation for you.
Engine API Runner (Phase 3)
The Engine API Runner executes a compiled strategy_config against a running CrapsSim Engine HTTP API (e.g., uvicorn crapssim_api.http:app). It complements the vanilla exporter path—you can still export local Python files, or you can hit the HTTP API for immediate simulation feedback.
Typical flow: bet nodes → Strategy Compiler → API Runner → Debug/File.
When strategy_config.actions[] is present, the runner sends those actions directly to /session/apply_action; it falls back to mapping bets[] only when no actions are provided.
craps-api-config (config node)
Holds shared Engine API defaults so individual flows don’t have to repeat them:
  • base_url: API host, e.g., http://127.0.0.1:8000.
  • profile_id: Profile to send to /session/start (default: default).
  • default_seed_mode: fixed, random, or from_msg.
  • seed: Used when default_seed_mode is fixed.
  • timeout_ms: Per-request timeout.
  • retries/retry_backoff_ms: Exposed for future use; currently plumbed through the config object.
  • auth_token: Optional bearer token for protected deployments.
Override behavior: msg.api_config can override most fields, and msg.profile_id/msg.seed take precedence when provided. With default_seed_mode: from_msg, the runner pulls seeds from msg.seed (falling back to a timestamp when missing).
api-runner node
  • Inputs: Requires msg.strategy_config from the Strategy Compiler. Optional overrides: msg.seed, msg.rolls/msg.runs, msg.profile_id, msg.api_config.
  • Calls: /session/start → /session/apply_action (for each action; prefers actions[], falls back to bets[]) → /session/roll (for configured roll count) → /end_session.
  • Outputs:
    • msg.sim_result: Summary with strategy_name, seed, profile_id, rolls, bankroll start/end, net, ev_per_roll, and aggregated errors.
    • msg.sim_journal: Roll-by-roll responses from the Engine API.
    • msg.payload: Defaults to sim_result for dashboards.
    • When Prepare File Output is enabled: msg.file_output (NDJSON string) and msg.filename (auto-generated when not provided) for downstream File nodes.
  • Config options:
    • rolls: Default roll count when msg.rolls/msg.runs is absent.
    • strict_mode: When true, aborts on the first non-empty API errors array; when false, aggregates errors but keeps running.
    • prepare_file_output: Prepares NDJSON journal and filename, but leaves actual disk I/O to a File node.
API Runner walkthrough
  1. Start the Engine API locally: uvicorn crapssim_api.http:app --reload (or your deployment of choice).
  2. Import examples/api_simple_line_place.json into Node-RED.
  3. Open the craps-api-config node in the flow and confirm base_url matches your running API.
  4. Press the Inject node to trigger the flow.
  5. Watch sim_result in the debug sidebar. If you also import examples/api_with_file_output.json, the journal arrives in msg.file_output and is written by the File node (path set in the example).
📦 Nodes 🎲 Bet Construction
bet-type
Defines line/field/place/lay/hardway bets with fixed or fed amounts.
Outputs a bet object for the recipe.
bet-prop
For proposition bets (hardways, horn, etc.) that CrapsSim supports.
bet-in
Accepts amounts from upstream value nodes (val-int, type-units, type-dollars) and passes them to bet-type/bet-prop.
clear
Removes specified bets (or all bets) at that point in the flow.
🔢 Value Blocks
val-int
A simple integer value node.
Can be set to participate in validation/evolution (in future forks).
type-units
Treats values as “units” (table minimum multiples).
Useful for quickly scaling strategies by table denomination.
type-dollars
Treats values as literal dollars.
📑 Phase Markers
Used to structure the recipe into “chapters,” mirroring real Craps gameplay. They don’t affect rolls directly but control when bets are considered active.
comeout-marker
Marks the start/end of the Come-Out phase.
maingame-marker
Marks the start/end of the Point-On phase (main loop).
endgame-marker
Marks the cleanup/stop phase.
roll-marker
A visual indicator for where rolls conceptually occur.
Ignored in vanilla export (CrapsSim handles rolling internally).
✅ Validation
validator-recipe
Checks that the flow forms a syntactically valid recipe (generic).
validator-vanilla
Ensures all bets and amounts can be mapped to real CrapsSim classes.
Warns or errors if unsupported bet types are used.
📤 Export
export-vanilla
Converts the recipe into a runnable Python module using CrapsSim’s strategy API (AggregateStrategy, BetDontPass, BetPlace, BetField, etc.).
ℹ️ The exporter now prefers msg.strategy_config (assembled by the strategy-compiler node) as its primary input, but will fall back to msg.recipe.steps for legacy flows. When strategy_config.actions[] is present, it is used as the canonical source; bets[] is only consulted when actions are absent. Wiring is unchanged: feed your bet nodes into the compiler, then into the exporter.
Exports to a .py file via the File node.
Harness block at the bottom lets you run the strategy immediately with CrapsSim’s Table.
⚙️ Simulation Variables
Nodes that set parameters for the exported harness. They write into msg.sim and are read by export-vanilla.
var-bankroll
Sets starting bankroll (default: 300).
var-max-rolls
Sets maximum rolls. Options:
infinite → no limit (float("inf"))
fixed → user-specified number
var-seed
Sets RNG seed. Options:
none → leave seed unset (engine picks; fresh randomness each run)
fixed → explicit seed (number or string, repeatable runs)
random → a new random seed baked into each exported file
🔧 Typical Flow
Version: 1.3.5
Updated 1 year ago
7 in the last week
  • api-config
  • craps-api-runner
  • craps-batch-runner
  • bet-type
  • bet-prop
  • val-int
  • int-type
  • bet-in
  • clear
  • comeout-marker
  • maingame-marker
  • endgame-marker
  • roll-marker
  • strategy-compiler
  • validator
  • export
  • var-bankroll
  • var-max-rolls
  • var-seed
  • var-table
  • craps
  • casino
  • dice
  • strategy
