node-red-contrib-coworkingview 0.1.1
Node-RED node for the CoworkingView catalogue API: search coworking spaces and private offices, fetch market rates and best-value rankings by city. No API key.
npm install node-red-contrib-coworkingview
CoworkingView
A Node-RED node for the CoworkingView catalogue of coworking spaces, private offices and flexible workspace. Search a city, fetch one space, read a or read a city's market rates, all from a flow.
Reads need no API key and no sign-up. The node calls the public CoworkingView API (https://api.coworkingview.com/v1), which is rate-limited.
From the Node-RED editor: Menu → Manage palette → Install, search for coworkingview.
Or from your Node-RED user directory (usually ~/.node-red):
Then restart Node-RED. The node appears in the network category as coworkingview.
Operations
Operation Needs Returns in msg.payload
Search spaces in a city city An array of spaces (title, slug, city, entry price…)
Get one space slug The full record for one space: pricing options, amenities, address
Market rates for a city city Median prices per workspace type, with sample sizes
List cities — Every city slug you can query
Every field can be set on the node or sent on the message, and the message wins, so one node can serve many cities:
Message property Used by Example
msg.payload (string) all but cities "berlin" fills an empty city, or an empty slug for space
msg.operation all search, space, rates, cities
msg.city search, rates berlin, madrid, barcelona, london, munich
msg.slug space a slug from a search result
msg.pricingOptionType search private_office, flex_desk, fix_desk, day_pass, meeting_room, virtual_office, event_space, membership, exclusive_bereich
msg.limit search (1–50) 5
msg.page search 2
msg.currency rates USD
msg.locale all en, de, es
The node also sets msg.statusCode and msg.coworkingview (operation, request url, response meta). Errors (unknown city, bad input, network) go to a Catch node with the original message.
Example
Import Menu → Import → Examples → node-red-contrib-coworkingview → search-berlin. It injects "berlin" into two nodes: one lists five private offices, the other reads Berlin's market rates.
[{"id":"c1","type":"inject","payload":"berlin","payloadType":"str","props":[{"p":"payload"}],"wires":[["c2"]]},
 {"id":"c2","type":"coworkingview","operation":"search","pricingOptionType":"private_office","limit":"5","locale":"en","wires":[["c3"]]},
 {"id":"c3","type":"debug","complete":"payload","wires":[]}]
Ideas: post new private offices in your city to Slack every Monday, alert when a city's median flex-desk price moves, or feed a dashboard with the price index.
Reading the numbers
  • Market rates are medians over the priced spaces in a city. Check sampleSize before calling a figure "the market rate": a small sample is a small sample.
  • Prices are what operators publish; the space's page on coworkingview.com has the current offer.
More ways in
COWORKINGVIEW_API in Node-RED's environment overrides the API origin (default https://api.coworkingview.com). Requests time out after 15 seconds.
Requires Node-RED 3.0 or newer and Node.js 18 or newer.
MIT © CoworkingView
Version: 0.1.1
Updated 3 weeks, 3 days ago
  • coworkingview
  • coworkingview
  • coworking
  • office
  • flexible-office
  • real-estate
  • api
