node-red-contrib-countdown-2 1.4.2
A countdown that supports dynamic setting of (future) run time and stopping with or without payload output
npm install node-red-contrib-countdown-2
node-red-contrib-countdown-2 is a simple countdown node. It starts a countdown timer on a received input msg and decreases the counter value (at the first output) until the countdown timer elapses. The countdown can be stopped at any time. Also the countdown timer can be set to any new countdown value at any time to reload the timer with a specific value. manual stopped can be configured to send output or cancel which does not send output payloads.
The output can emit a msg at its first output with an arbitrary msg.payload contents at the start of the timer as well as at the stop of the countdown timer. or nothing if cancled timer. At the second Output the node emits the remaining counter value every second.
The node's output msg can optionally contain an arbitrary topic string.
Forked from Ontje: https://github.com/ontje/node-red-contrib-countdown.git Thank you!
node-appearance
Fig. 1: Node appearance
In Node-RED (preferred)
  • Via Manage Palette -> Search for "node-red-contrib-countdown-2"
In a shell
  • go to the Node-RED installation folder, e.g.: ~/.node-red
  • run npm install node-red-contrib-countdown-2
Node Configuration
node-settings
Fig. 2: Node properties
Countdown (secs) property
Set the Countdown value to the desired countdown time in seconds. The timer will start with this countdown value to decrease the timer value (countdown start value). Minutes if the option "Counter is in Minutes" is checked.
Topic
The Topic can be set to any string value. This string is added to the output msg as an additional element msg.topic.
Note: No value is given to the topic.
Timer On payload, Timer Off payload
Set the Timer On payload to any payload type and value which is sent when the counter starts.
Set the Timer Off payload to any payload type and value which is sent when the counter elapses.
In both cases, also nothing to be emitted may be chosen.
Flags
You can configure the timer to
  • Timer in Minutes (default is seconds)
  • restart (reload) the timer to its countdown start value during the count down whenever a msg is received at the node's input.
  • activate the ability to set the timer value to an arbitrary value during the count down with the use of a control msg.
  • start the timer with a control msg (i.e. a msg with a control topic string).
Input
The node evaluates the following input msg types:
  • Input msg with a msg.payload contents of false (boolean) or '0' (number).
    This msg type stops resp. finishes the timer. The Timer Off payload is emitted also in this case.
  • Input msg with a msg.topic set to "control" and a msg.payload set to an arbitrary number value. This reloads the timer with the desired msg.payload value immediately and works at a running countdown as well as a non startet or elapsed countdown timer.
  • All other input msg do start/restart the timer if it is stopped.
  • See Node configuration for control topic options to cancel the timer.
Outputs
The node contains two outputs:
  • The primary output (upper output) emits an output msg at the countdown start/stop instant of time. These msg.payload contents are configurable
  • The secondary output (lower output) emits the remaining time every second during the timer runs. The msg.payload holds the remaining counting value
Examples (original)
Todo: create examples for modified control/stop/etc.
Basic behaviour
This example shows the basic behaviour with
  • starting the timer via an input msg (inject node)
  • showing the behaviour of the two outputs of the node
Just activate the inject and look at the output debug node status messages.
Alt text
basic flow
Fig. 3: Basic example flow
Sending messages and retriggering
This example shows how to
  • handle messages at the start and the end of the countdown
  • retrigger the timer during it runs
Text messages are output on the first output at start and end of the countdown.
You can restart the timer by activating the inject node during the countdown runs.
Alt text
messages and retriggering flow
Fig. 4: Message sending and retriggering example flow
Stopping the countdown timer
This example shows the two options to stop the countdown timer.
Alt text
stopping timer flow
Fig. 5: Timer stopping example flow
Reloading the countdown timer
This example shows the functionality of reloading the countdown value during a running timer.
Alt text
reloading timer flow
Fig. 6: Timer reload example flow
Version: 1.4.2
Updated 5 years, 8 months ago
Rating: 3.0 7
46 in the last week
  • countdown
  • count down timer
  • countdown
  • timer
  • timeout
  • stop timmer
