node-red-contrib-couchdb-nodes 0.1.7
Node-RED nodes for CouchDB CRUD operations
npm install node-red-contrib-couchdb-nodes
Node-RED nodes for performing CRUD operations on Apache CouchDB databases.
npm version Node.js CI
[Node-Red Flows]
  • Server Configuration: Centralized CouchDB connection management with authentication
  • Document Operations: Query, insert, get, and update documents
  • Database Management: Create, delete, and list databases
  • View Queries: Execute CouchDB views with filtering and pagination
  • Optimistic Concurrency: Built-in revision control for safe updates
  • Error Handling: Dual-output pattern for success/error flow separation
  • Pagination: Support for limit/skip in queries and document listing
Install via Node-RED's palette manager or run:
Quick Start
Check out the example flows to get started quickly:
Import any example into Node-RED to see it in action!
Requirements
  • Node.js: 10.0.0 or higher
  • Node-RED: 1.0.0 or higher
  • CouchDB: 2.0 or higher
Available Nodes
CouchDB Server (Configuration)
Configuration node that stores CouchDB connection details. Used by all operational nodes.
Properties:
  • hostname: CouchDB server hostname (default: localhost)
  • port: CouchDB port (default: 5984)
  • username: Optional authentication username
  • password: Optional authentication password (stored securely)
CouchDB Query
Execute CouchDB view queries with filtering and pagination options.
Inputs:
  • msg.database (optional): Override configured database
  • msg.view (optional): Override configured view
  • msg.key (optional): Filter by specific key
  • msg.limit (optional): Maximum documents to return
  • msg.skip (optional): Number of documents to skip
  • msg.include_docs (optional): Include full documents in results
Outputs:
  • Output 1 (Success): msg.payload contains query results
  • Output 2 (Error): Error information
Example:
msg.database = "products";
msg.view = "catalog/by_category";
msg.key = "electronics";
msg.limit = 10;
CouchDB Insert
Insert new documents into CouchDB.
Inputs:
  • msg.payload: Object to insert (must be a valid object, not string/array/null)
Outputs:
  • Output 1 (Success): msg.payload contains inserted document with _id and _rev
Example:
msg.payload = {
  type: "product",
  price: 999.99
CouchDB Get
Retrieve a specific document by ID.
Inputs:
  • msg.docId: Document ID to retrieve
Outputs:
  • Output 1 (Success): msg.payload contains the document
  • Output 2 (Error): Error information (e.g., 404 if not found)
Example:
msg.docId = "product-12345";
CouchDB Update
Update existing documents with optimistic concurrency control.
Inputs:
  • msg.payload: Document object with _id and _rev fields
Important: The document must include both _id and _rev. Use the Get node first to retrieve the current version.
Outputs:
  • Output 1 (Success): msg.payload contains updated document info with new _rev
  • Output 2 (Error): Error information (e.g., 409 conflict if document was modified)
Example:
// First, get the document
// Then update it:
msg.payload._rev = "2-abc123";  // Current revision from Get node
msg.payload.price = 899.99;      // Update field
CouchDB Create DB
Create a new CouchDB database.
Inputs:
  • msg.database: Name of database to create
Outputs:
  • Output 1 (Success): Confirmation message
CouchDB Delete DB
Delete a CouchDB database.
Inputs:
  • msg.database: Name of database to delete
Outputs:
CouchDB List DBs
List all databases on the CouchDB server.
Outputs:
  • Output 1 (Success): msg.payload contains array of database names
CouchDB List Docs
List documents in a database with pagination support.
Inputs:
  • msg.include_docs (optional): Include full document content
Outputs:
  • Output 1 (Success): msg.payload contains document list
Usage Patterns
Basic Query Flow
[Inject] → [CouchDB Query] → [Debug]
                           → [Error Handler]
Insert with Error Handling
[Function] → [CouchDB Insert] → [Success Handler]
                              → [Error Logger]
Update with Get-Modify-Update Pattern
[Inject] → [CouchDB Get] → [Function: Modify] → [CouchDB Update] → [Debug]
                        → [Error Handler]                        → [Error Handler]
Pagination Example
// In a Function node before CouchDB Query
var pageSize = 20;
var pageNumber = msg.page || 0;
msg.limit = pageSize;
msg.skip = pageNumber * pageSize;
msg.include_docs = true;
Error Handling
All operational nodes use a dual-output pattern:
  • First output: Successful operations
  • Second output: Errors (with detailed error information)
This allows you to route errors to dedicated error handling flows without cluttering your success path.
Example error message:
  error: {
    message: "Document update conflict",
    status: 409,
    reason: "Document update conflict"
CouchDB Concepts
Document Revisions
CouchDB uses _rev fields for optimistic concurrency control. Every document has a revision that changes with each update. When updating a document, you must provide the current _rev to prevent conflicts.
Workflow:
  1. Get the document (retrieves current _rev)
  2. Modify the document fields
  3. Update with the current _rev
If another process updates the document between steps 1 and 3, you'll receive a 409 conflict error.
Views
CouchDB views are stored queries defined in design documents. Views are referenced as design_doc_name/view_name.
Example: catalog/by_category refers to the by_category view in the catalog design document.
Development
Running Tests
npm test
The test suite includes 37+ tests covering all node types and error conditions.
Project Structure
src/nodes/
├── server/          Configuration node
├── query/           View queries
├── insert/          Document insertion
├── get/             Document retrieval
├── update/          Document updates
├── create-db/       Database creation
├── delete-db/       Database deletion
├── list-dbs/        List databases
└── list-docs/       List documents
test/nodes/          Test suite
Contributing
Contributions are welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Add tests for new functionality
  4. Ensure all tests pass (npm test)
  5. Submit a pull request
MIT © kanr
Links
Changelog
1.0.0 (2026-02-21)
  • Initial release
  • CouchDB server configuration node
  • Document operations: query, insert, get, update
  • Database management: create, delete, list
  • Document listing with pagination
  • Comprehensive test coverage
  • GitHub Actions CI/CD
Version: 0.1.7
Updated 9 months ago
  • couchdb-server
  • couchdb-insert
  • couchdb-get
  • couchdb-query
  • couchdb-update
  • couchdb-create-db
  • couchdb-delete-db
  • couchdb-list-dbs
  • couchdb-list-docs
  • couchdb
  • database
  • crud
