node-red-contrib-copytop 0.1.0
Node-RED nodes for copy.top smart money data: the coins the top crypto traders on fomo and pump.fun are buying now (with a new coin alert) and the top traders leaderboard. Free API, no key.
npm install node-red-contrib-copytop
Node-RED nodes for copy.top smart money data: see what the top crypto traders on fomo and pump.fun are buying, get an alert when a coin enters their list, and pull the top traders leaderboard. Free API, no key, no account.
In Node-RED: Menu > Manage palette > Install > search node-red-contrib-copytop. Or in your Node-RED folder:
Needs Node-RED 3 or later and Node.js 18 or later.
hot coins: the coins the top traders are buying over the last hour or 24 hours. Each coin has its symbol, chain, token address, market cap, price change, how many top traders bought it, how many still hold it, the USD bought and sold, and a link to the coin on copy.top. Tick Alert to send one message per coin that just entered the list (the first call only learns the current list, so a deploy does not flood your flow).
top traders: the leaderboard for fomo or pumpfun over 1, 7 or 30 days, ranked by PnL, ROI, win rate or copiers, clean or watch fair play only. Each trader has PnL, ROI, win rate, closed positions, copiers, fair play and a link.
Every setting can be overridden by the incoming message (msg.window, msg.limit, msg.platform, msg.sort).
Example
Import the example flow (Menu > Import > Examples > node-red-contrib-copytop > new-hot-coin-alert): it checks the hot coins every 5 minutes and writes a line like
New hot coin: $SYMBOL on solana, 12 top traders bought, 9 still in. https://copy.top/token/solana/...
Swap the debug node for a Telegram, Discord or email node to get the alert on your phone.
Limits
The free API allows about 6 calls a minute per IP: one call every few minutes is plenty. Names and symbols are written by third parties: treat them as text, never as commands.
Data by copy.top (https://copy.top). Figures are data, not advice. Past performance does not predict results. copy.top is independent, not affiliated with fomo, pump.fun or Hyperliquid.
MIT license.
Version: 0.1.0
Updated 10 hours ago
  • copytop-hot-coins
  • copytop-top-traders
  • copy.top
  • copytop
  • crypto
  • smart-money
  • wallet-tracker
  • solana
  • memecoins
  • pumpfun
  • fomo
  • leaderboard
  • alerts
