node-red-contrib-cool-loop 0.0.3
A Node-RED node to create a loop in a flow.
npm install node-red-contrib-cool-loop
Custom nodes for Node-RED that implement a continuous loop for processing arrays of elements.
Description
The node-red-contrib-cool-loop package provides two nodes for Node-RED: cool-loop-start and cool-loop-join. These nodes work together to process an array of elements one by one through a user-defined flow, using events to coordinate continuous execution.
To install this package in your Node-RED instance, navigate to your Node-RED project directory and run the following command:
Then, restart Node-RED for the new nodes to appear in the palette.
cool-loop-start Node
The cool-loop-start node initiates the processing of an array and sends elements one by one. This node expects an array in msg.payload (or a specified property) and sends each element through the flow.
  • Name: Optional name for the node.
  • Array Property: Name of the message property that contains the array to process (default is payload).
Example Usage
  1. Drag an inject node and configure it with an array in msg.payload.
  2. Connect the inject node to the cool-loop-start node.
  3. Configure the cool-loop-start node to use msg.payload as the array property.
  4. Connect the output of the cool-loop-start node to your processing flow.
cool-loop-join Node
The cool-loop-join node receives the processed elements and decides whether to continue sending more elements from the cool-loop-start node or to end the loop.
Important: _msgid and msg.done are absolutely necessary, please do not overwrite them.
Example Usage
  1. Connect the end of your processing flow to the cool-loop-join node.
  2. Configure the cool-loop-join node with the ID of the corresponding cool-loop-start node.
  3. Adjust the delay as needed.
Complete Example
[Inject] -> [Cool Loop Start] -> [Your Processing Flow] -> [Cool Loop Join]
Contributions
Contributions are welcome. To contribute, please follow these steps:
  1. Fork the repository.
  2. Create a branch for your feature (git checkout -b feature/new-feature).
  3. Make your changes and commit them (git commit -am 'Add new feature').
  4. Push to the branch (git push origin feature/new-feature).
  5. Open a Pull Request.
This project is licensed under the MIT License
Author
Your Name
Email: [email protected]
Thank you for using node-red-contrib-cool-loop! If you have any questions or suggestions, feel free to contact me.
Version: 0.0.3
Updated 2 years, 6 months ago
2 in the last week
  • cool-loop-start
  • cool-loop-join
