node-red-contrib-connector-manager 1.0.6
Node-RED sidebar panel to bulk-reassign any config node references across all flows — ideal when promoting from dev to prod.
npm install node-red-contrib-connector-manager
A Node-RED sidebar panel that lists every config node reference across all flow tabs and lets you bulk-reassign them in one shot — useful when promoting flows from dev to prod.
Works with any config node type: OPCUA connectors, MQTT brokers, HTTP request configs, database connections, whatever.
  • Sidebar panel — always accessible via the ⇄ icon, no node placement needed
  • Config-type selector — pick any type that actually exists in the workspace
  • Per-node cards, each showing:
    • Flow tab and node name
    • Node type and referenced property
    • Replace with dropdown
  • Bulk apply — one click to reassign all referencing nodes, then Deploy to save
  • Stale-reference detection — highlights nodes pointing to deleted config nodes
Requirements
  • Node-RED ≥ 3.0.0
  • Node.js ≥ 18.0.0
npm
Docker
COPY nodes/ /opt/nr-local-nodes/
RUN npm install /opt/nr-local-nodes/node-red-contrib-connector-manager
Open the ⇄ tab in the Node-RED right sidebar. That's it.
  1. Pick a config node type from the dropdown at the top.
  2. Each card is one node that references the selected config, labelled with its flow tab and node name.
  3. Set Replace with on the cards you want to change.
  4. Click Apply Changes, then Deploy.
Dev → Prod example
Say you have two MQTT brokers:
Config node Host
MQTT – Dev mqtt://dev-broker:1883
MQTT – Prod mqtt://10.0.1.5:1883
Open the panel, select mqtt-broker, set Replace with to MQTT – Prod on every dev card, click Apply Changes, then Deploy. Done.
Apache 2.0 — OWT Swiss
Version: 1.0.6
Updated 8 months, 3 weeks ago
Rating: 5.0 2
153 in the last week
  • config
  • connector
  • manager
  • migration
  • bulk
  • dev-to-prod
  • Arthur Cousin
