node-red-contrib-connectmq 1.0.0
Node-RED nodes for the free public MQTT broker broker.connectmq.com: publish and subscribe with zero configuration over TCP, TLS, WebSocket or secure WebSocket. Works with private ConnectMQ brokers too.
npm install node-red-contrib-connectmq
Node-RED nodes for the free public MQTT broker broker.connectmq.com. Drag a node onto the canvas, set a topic and deploy: no account, no broker setup and no credentials needed. The same nodes also connect to private brokers created on connectmq.com.
In Node-RED, open Menu → Manage palette → Install and search for node-red-contrib-connectmq. Or run this in your Node-RED user directory (usually ~/.node-red):
Requires Node-RED 3.0 or later and Node.js 18 or later.
Node Description
connectmq in Subscribes to a topic (wildcards + and # are supported) and outputs every message
connectmq out Publishes msg.payload to a topic
connectmq-broker Config node with the connection. The defaults point to the public broker over TLS
connectmq in
Outputs msg.payload, msg.topic, msg.qos and msg.retain. The payload can be auto-detected (JSON is parsed, anything else is a string), always a string, always parsed JSON, or a Buffer.
connectmq out
Input Description
msg.payload Objects are sent as JSON, Buffers as-is, other values as strings
msg.topic Used when the node has no topic set
msg.qos Used when QoS is set to msg.qos (default 0)
msg.retain Used when Retain is set to msg.retain (default false)
Send an empty payload with retain set to true to clear a retained message.
connectmq-broker
Setting Default
Host broker.connectmq.com
Transport TLS 8883. Also TCP 1883, secure WebSocket 8084, WebSocket 8083
Port Standard port of the transport
Client ID Random (nodered-xxxxxxxx)
Protocol MQTT 5.0 (MQTT 3.1.1 optional)
Username / Password Empty. Only needed for private brokers
All nodes that use the same config node share one connection, which reconnects automatically. The node status shows connected, connecting or disconnected.
Example
Import Menu → Import → Examples → node-red-contrib-connectmq → public-broker-quick-start. The example publishes a simulated temperature every 5 seconds and shows it in the debug sidebar:
[inject every 5 s] → [simulate sensor] → [connectmq out  connectmq/demo/nodered-example/temperature]
[connectmq in  connectmq/demo/nodered-example/#] → [debug]
Change nodered-example to a random value of your own before deploying.
Public broker
Protocol URL
MQTT (TCP) mqtt://broker.connectmq.com:1883
MQTT over TLS mqtts://broker.connectmq.com:8883
WebSocket ws://broker.connectmq.com:8083/mqtt
Secure WebSocket wss://broker.connectmq.com:8084/mqtt
Access is anonymous, but the client ID must not be empty. Limits: 64 KB per message, 10 messages per second and 10 subscriptions per client, topics up to 8 levels deep, and sessions expire after at most 30 minutes.
Everything on the public broker is public. Any client can subscribe to #. Put your topics under a random prefix such as connectmq/demo/7f3a91/, and use the broker only for testing. For production, create a private broker with its own credentials at connectmq.com.
More: Free Public MQTT Broker for Testing. Also available for Node.js (@connectmq/mqtt), .NET (ConnectMQ.Mqtt) and PowerShell (MQTTBroker).
MIT
Version: 1.0.0
Updated 2 days ago
  • connectmq-broker
  • connectmq in
  • connectmq out
  • mqtt
  • mqtt-broker
  • public-mqtt-broker
  • free-mqtt-broker
  • iot
  • pubsub
  • connectmq
