node-red-contrib-connect 0.1.3
Node-RED nodes for AVEVA Connect (Data Hub, OMF, Streams)
npm install node-red-contrib-connect
Node-RED nodes for AVEVA Connect (Data Hub, OMF, Streams).
  • OAuth2 Authentication with automatic token refresh
  • OMF Write - Send data using OSIsoft Message Format
  • Streams Read - Read data from streams with multiple modes
  • Events - Subscribe to stream updates with polling
  • Full API support for AVEVA Data Hub
Via Node-RED Palette Manager
  1. Open Node-RED
  2. Go to Menu > Manage palette > Install
  3. Search for node-red-contrib-connect
  4. Click Install
Via npm
Then restart Node-RED.
Setting up AVEVA Connect credentials
  1. Log in to your AVEVA Connect portal
  2. Navigate to Developer Tools > Client Credentials
  3. Create a new client with appropriate permissions:
    • For OMF: ocsapi.data.readwrite
    • For Streams: ocsapi.data.read or ocsapi.data.readwrite
  4. Note the Client ID and Client Secret
Configuration Node Properties
Property Description
Resource URL AVEVA Connect base URL (default: https://datahub.connect.aveva.com)
Tenant ID Your AVEVA Connect tenant ID
Namespace ID The namespace to work with
Client ID OAuth2 client ID
Client Secret OAuth2 client secret
Token URL OAuth2 token endpoint
OMF Write
Writes data to AVEVA Connect using the OSIsoft Message Format (OMF).
OMF Message Types:
  • type - Define data types (schema)
  • container - Define streams (containers)
  • data - Send actual data values
Example - Define Type:
msg.payload = [{
    "id": "Temperature",
    "type": "object",
    "classification": "dynamic",
    "properties": {
        "Timestamp": { "type": "string", "isindex": true, "format": "date-time" },
        "Value": { "type": "number", "format": "float64" }
msg.omfMessageType = "type";
Example - Define Container:
msg.payload = [{
    "id": "Sensor1",
    "typeid": "Temperature"
msg.omfMessageType = "container";
Example - Send Data:
msg.payload = [{
    "containerid": "Sensor1",
    "values": [{
        "Timestamp": new Date().toISOString(),
        "Value": 23.5
msg.omfMessageType = "data";
Streams Read
Reads data from AVEVA Connect streams.
Read Modes:
  • last - Get the most recent value
  • first - Get the oldest value
  • range - Get values between start and end timestamps
  • window - Get the last N values
  • interpolated - Get interpolated values at regular intervals
Example - Read Last Value:
msg.streamId = "Sensor1";
msg.readMode = "last";
Example - Read Range:
msg.readMode = "range";
msg.startIndex = "2024-01-01T00:00:00Z";
msg.endIndex = "2024-01-02T00:00:00Z";
Events
Subscribes to stream updates and emits messages when new data arrives.
Control Commands:
  • msg.payload = "start" - Start polling
  • msg.payload = "stop" - Stop polling
  • msg.payload = "status" - Get polling status
Example - Start with Dynamic Streams:
msg.payload = "start";
msg.streamIds = ["Sensor1", "Sensor2", "Sensor3"];
Output Message Format:
    topic: "Sensor1",        // Stream ID
    payload: { ... },        // New data from stream
    streamId: "Sensor1",
    timestamp: "2024-...",
    eventType: "data"
OMF Overview
OSIsoft Message Format (OMF) is a JSON-based format for sending time-series data. The typical workflow is:
  1. Define Types - Create a schema for your data
  2. Define Containers - Create streams that use the types
  3. Send Data - Send actual values to the containers
For more information, see the OMF Specification.
Compatibility
  • Node-RED: >= 2.0.0
  • Node.js: >= 14.0.0
  • AVEVA Connect: Data Hub API v1
Troubleshooting
Authentication Errors
  1. Verify your Client ID and Client Secret are correct
  2. Ensure the client has the necessary permissions
  3. Check that the Token URL matches your region
Connection Issues
  1. Verify the Resource URL is correct for your region
  2. Check network connectivity to AVEVA Connect
  3. Ensure your tenant and namespace IDs are correct
OMF Errors
  1. Verify your type definitions are valid JSON
  2. Ensure container IDs match existing containers
  3. Check that data values match the defined types
MIT
Author
Holger Amort
Links
Version: 0.1.3
Updated 10 months, 3 weeks ago
119 in the last week
  • connect-config
  • connect-omf-writer
  • connect-streams-read
  • connect-events
  • aveva
  • connect
  • omf
  • osisoft
  • data-hub
  • streams
  • time-series
