node-red-contrib-configurable-soap-server 1.0.3
Custom nodes for Node-Red to use SOAP Server
npm install node-red-contrib-configurable-soap-server
Node-Red custom nodes to setup a SOAP Server (currently under development)
install
Run npm i node-red-contrib-configurable-soap-server in node-red directory. Edit settings.js in node-red directory, set functionGlobalContext object as follow, or simply add http and soap:
functionGlobalContext:  {
  soap:  require('soap'),
  http:  require('http')
Import example_flow.json to see in action a basic soap server. Use a soap client UI (eg. https://www.soapui.org/) to test the server, wsdl and sample request are in example folder.
update
  • 1.0.3 added Response Wrapper to Response Node to customize response.
credits
Neil Kolban [https://github.com/nkolban], for WSDL and base idea.
Version: 1.0.3
Updated 5 years, 7 months ago
6 in the last week
  • soapserver
  • soapresponse
  • soap
  • wsdl
