node-red-contrib-conect-plus 1.0.6
This is a node for the data design tool, conect+ Studio (https://studio.conect.plus/).
npm install node-red-contrib-conect-plus
Node-RED nodes for conect+Studio
1. studio-send
To send sensor data to c+ Studio, you will need:
  • Workspace ID
  • Web API Key
  • Device ID
  • Sensor ID
Fig.1-1 The relationship between conect+ Studio Parameters Fig.1-1 The relationship between conect+ Studio Parameters
For Workspace ID, Web API Key, and API specifications, sign in to c+ Studio (https://studio.conect.plus), and check it from [Data Adapter] → [Reference]. (Fig.1-2,1-3)
Fig.1-2 Web API Reference menu Fig.1-2 Web API Reference menu
Fig.1-3 Web API Reference details Fig.1-3 Web API Reference details
You can set the properties for the keys shown in Fig.1-3 in [studio-send]. (Fig.1-4)
Fig.1-4 Settings for studio-send Fig.1-4 Settings for studio-send
Device ID and Sensor ID will automatically integrate values that you set and send.
(e.g. device01, temperature, sensorA )
2. studio-fetch
This node retrieves sensor data from c+ Studio.
To retrieve sensor data from c+ Studio, you need:
  • Workspace ID
  • Web API Key
  • Device ID
  • Sensor ID
Follow essentially the same procedure as [studio-send]. To check each parameter, see” 1. studio-send”.
However, with studio-fetch, you need to designate an ID registered with the following:
  • Device ID
  • Sensor ID
Registered ID’s can be checked from [Device] → [Edit]. (Fig.2-1,2-2)
Fig.2-1 Device ID List Fig.2-1 Device ID List
Fig.2-2 DeviceID / Sensor ID Fig.2-2 DeviceID / Sensor ID
you can set the parameters for the keys shown in Fig.1-3 and 2-2 from [studio-fetch]. (Fig.2-3)
Fig.2-3 Settings for studio-fetch Fig.2-3 Settings for studio-fetch
Set Limit and Page to a number of your choosing.
  • Limit : The amount of data retrieved (default: 100)
  • Page : Retrieved pages (default:1)
MIT
Version: 1.0.6
Updated 7 years, 1 month ago
5 in the last week
  • studio-fetch
  • studio-send
  • conect+
  • conect plus
  • conect+ studio
  • connect+
  • connect plus
  • IoT
