node-red-contrib-condition-monitoring 0.4.2
Node-RED Nodes for anomaly detection, predictive maintenance, and time series analysis
npm install node-red-contrib-condition-monitoring
A comprehensive Node-RED module for anomaly detection, predictive maintenance, and time series analysis.
npm version npm downloads License: Apache 2.0 Node-RED Node.js Status: Beta Sponsor
Table of Contents
Project Status: v0.4.2 Beta
Per-device state in every analysis node, corrected detection maths, LLM Analyzer, Vision Pipeline & Data-Source Simulators
Upgrading from 0.3.x: several nodes produce different (corrected) results — read "Changed behaviour" in the changelog before deploying.
  • 15 Nodes - analysis, ML inference, vision pipeline, LLM analysis, and data-source simulators
  • ISO 20816-3 Integration - Vibration severity zones A-D by machine group and foundation (legacy ISO 10816-1 classes kept); acceleration input integrated to velocity over 10–1000 Hz
  • Bearing diagnostics - fault frequencies from bearing geometry, per-message shaft speed (msg.rpm), BPFI sidebands, looseness and sub-synchronous rules
  • Operating-point regimes - one anomaly baseline per speed/load class, so a load change is not an alarm
  • Butterworth Filter - 2nd order IIR filter with zero-phase filtering (filtfilt)
  • Hysteresis (Anti-Flicker) - Prevents rapid alarm on/off switching
  • Dynamic Sensor Weighting - Auto-adjusts weights based on sensor reliability
  • Robust RUL Calculation - Theil-Sen estimator, median filter, moving average smoothing
  • High-Performance FFT - Radix-4 Cooley-Tukey algorithm via fft.js
  • State Persistence - Optional context-based state saving across restarts
  • Comprehensive Testing - 405 unit tests with Jest framework
Important Disclaimer
This software is provided for condition monitoring and predictive maintenance purposes.
  • NOT a replacement for safety-critical systems
  • NOT suitable as the sole means of safety decision-making
  • Should be used as an additional monitoring layer
  • Always validate results with domain experts
  • Follow proper safety protocols and regulations for your industry
Use at your own risk. See LICENSE file for full legal terms.
Background & Industry Context
Predictive maintenance works because machines don't fail randomly — they fail predictably, given the right signals. The industry converges on a small set of condition-monitoring techniques and a common pipeline shape, both of which this module implements as composable Node-RED nodes.
Common monitoring techniques → nodes in this module:
Industry technique Detects Node(s) here
Vibration analysis (the dominant technique by market share) bearing wear, misalignment, imbalance, looseness signal-analyzer (FFT, RMS, kurtosis, crest factor, envelope), ISO 20816-3 zones
Thermal / process trending overheating, degradation drift trend-predictor, anomaly-detector
Anomaly detection on a learned "normal signature" deviations preceding failure anomaly-detector, isolation-forest-anomaly, pca-anomaly
Multi-signal fusion + asset context a "digital profile" per asset multi-value-processor, condition-monitoring-source, health-index
Root-cause + recommended action in the alert actionable alerts, not just flags llm-analyzer
Remaining Useful Life estimation time-to-failure with confidence bounds trend-predictor (RUL mode)
The typical pipeline — sensors → fusion → anomaly/trend → health score → actionable alert — maps directly onto the architecture below, and runs on the edge (inside Node-RED) rather than requiring a cloud round-trip.
On the published benchmarks. Vendor case studies report figures such as ~70% of failures predicted ≥24h ahead, 25–35% less unplanned downtime, and 80–97% prediction accuracy.[^pdm1][^pdm2] These are third-party industry results under their own conditions — not benchmarks of this module. Treat them as motivation for the approach, and validate any deployment against your own data and domain experts (see the disclaimer above).
[^pdm1]: ThinkAI, Cutting Machine Downtime with Predictive Maintenance and AI — https://thinkaicorp.com/case-study-cutting-machine-downtime-with-predictive-maintenance-and-ai/ [^pdm2]: iFactory, Predictive Maintenance 2026: AI vs. Factory Downtime — https://ifactoryapp.com/blog/predictive-maintenance-2026-ai-factory-downtime
  • 15 Powerful Nodes - Complete condition monitoring + vision + LLM toolkit
  • 10 Anomaly Detection Methods - Z-Score, IQR, Moving Average, Threshold, Percentile, EMA, CUSUM, Isolation Forest, PCA, Mahalanobis
  • Signal Analysis - High-performance FFT (Radix-4), Vibration Features (RMS, Crest Factor, Kurtosis), Peak Detection, Envelope Analysis, Cepstrum, Autocorrelation (ACF), Sample Entropy, Periodicity Detection
  • Correlation Analysis - Pearson, Spearman, Cross-Correlation with time lag detection
  • Gearbox Diagnostics - Cepstrum analysis for gear mesh faults
  • Reliability Analysis - Weibull distribution, B-life, MTTF, RUL
  • Trend Prediction - Linear Regression, Exponential Smoothing, Rate of Change
  • Multi-Value Processing - Split, Analyze, Correlate, Aggregate multiple sensors
  • ML Inference - TensorFlow.js, ONNX, Keras, scikit-learn, TFLite, Google Coral (with persistent Python bridge)
  • State Persistence - Optional buffer/statistics persistence across restarts
Prerequisites: Node.js >= 18, Node-RED >= 3.0.0
Or install directly from Node-RED:
  1. Menu → Manage palette
  2. Install tab
  3. Search for node-red-contrib-condition-monitoring
  4. Click install
Quick Start
With Docker Compose (Recommended)
# Start Node-RED with the module
docker-compose up -d
# Access at http://localhost:1880
Import Example Flows
  1. Open Node-RED: http://localhost:1880
  2. Menu → Import → Examples
  3. Select one of the example flows
Available Nodes (15 Nodes)
Nodes are grouped in the palette under five Condition Monitoring categories: Condition Monitoring Stats (analysis), Condition Monitoring ML (ml-inference, training-data-collector), Condition Monitoring Vision (image-preprocess, vision-annotator), Condition Monitoring LLM (llm-analyzer) and Condition Monitoring Demo (condition-monitoring-source, image-source, json-source).
Data sources for testing: condition-monitoring-source simulates realistic sensor data — trended KPIs (vibration RMS, temperature, current, pressure with degradation, faults, ISO thresholds, RUL) and, in waveform mode, a raw vibration time-signal so the signal-analyzer (FFT/envelope/kurtosis) can be driven too. image-source is its visual counterpart: it generates synthetic inspection images with configurable defects (spot/scratch) + a ground-truth mask to drive the vision pipeline. json-source is a generic structured-data simulator — you define arbitrary fields (mean/noise/trend, optional anomaly injection) and it emits JSON records to drive the object/record nodes (multi-value-processor, health-index, pca-anomaly, training-data-collector, llm-analyzer record mode).
Architecture at a glance
How the nodes fit together — data sources (or real inputs) feed the processing nodes, which emit results to dashboards/alarms/storage:
flowchart LR
    subgraph SRC["🔌 Sources"]
        EXT["Real inputs<br/>MQTT · OPC-UA · files"]:::src
        CMS["CM Sensor Source"]:::src
        IMS["CM Image Source"]:::src
        JSS["CM JSON Source"]:::src
    end
    subgraph STATS["📊 Statistical analysis"]
        AD["Anomaly Detector"]:::stats
        IF["Isolation Forest"]:::stats
        PCA["PCA Anomaly"]:::stats
        MVP["Multi-Value Processor"]:::stats
        SA["Signal Analyzer"]:::stats
        TP["Trend Predictor"]:::stats
        HI["Health Index"]:::stats
    end
    subgraph MLG["🤖 Machine learning"]
        MLI["ML Inference"]:::ml
        TDC["Training Data Collector"]:::ml
    end
    subgraph VIS["🖼️ Vision pipeline"]
        IPP["Image Preprocess"]:::vis
        VAN["Vision Annotator"]:::vis
    end
    subgraph LLMG["💬 LLM"]
        LLA["LLM Analyzer"]:::llm
    end
    OUT["Dashboard · Alarm · Database"]:::sink
    EXT --> AD & IF & SA & MVP & TDC
    CMS -->|scalar| AD & IF & TP & HI
    CMS -->|waveform| SA
    JSS --> MVP & PCA & HI
    IMS --> IPP --> MLI --> VAN --> OUT
    AD & IF & SA & TP & HI & PCA --> OUT
    MVP --> AD
    MLI -->|predictions| OUT
    AD -->|anomaly context| LLA --> OUT
    TDC -.->|labelled data| MLI
    classDef src fill:#9482f1,color:#fff,stroke:#6b5bd6;
    classDef stats fill:#42a5f5,color:#fff,stroke:#1e88e5;
    classDef ml fill:#ffa726,color:#3e2723,stroke:#fb8c00;
    classDef vis fill:#ec407a,color:#fff,stroke:#d81b60;
    classDef llm fill:#66bb6a,color:#fff,stroke:#43a047;
    classDef sink fill:#26a69a,color:#fff,stroke:#1c7e74;
The vision path is its own short pipeline:
flowchart LR
    IMG["Image<br/>(CM Image Source or PNG/JPEG)"]:::src --> P["Image Preprocess<br/>decode · resize · normalize → tensor"]:::vis
    P --> M["ML Inference<br/>ONNX / TFJS model"]:::ml
    M --> A["Vision Annotator<br/>boxes · masks · keypoints · heatmap…"]:::vis
    A --> V["Annotated PNG<br/>(editor preview / dashboard)"]:::sink
Standards map (ISO 13374)
ISO 13374 splits a condition-monitoring system into six functional blocks. This is where the nodes sit — useful when you integrate with a platform that speaks the same vocabulary (MIMOSA OSA-CBM, most CM software):
Block Name Nodes
DA Data Acquisition MQTT / OPC UA nodes, condition-monitoring-source, json-source, image-source
DM Data Manipulation signal-analyzer (FFT, envelope, indicators), multi-value-processor, image-preprocess
SD State Detection anomaly-detector, isolation-forest-anomaly, pca-anomaly
HA Health Assessment signal-analyzer (fault-frequency diagnosis, ISO 20816 zones), health-index, ml-inference (classification)
PA Prognostic Assessment trend-predictor (RUL with confidence band), ml-inference (regression)
AG Advisory Generation llm-analyzer, your CMMS integration
Background, standards and the research behind these choices: docs/RESEARCH-cm-pdm-landscape.md (landscape), docs/RESEARCH-pdm-cm.md (methods literature) and docs/RESEARCH-pdm-cm-followup.md (October 2026 follow-up: diagnostics techniques, standards conformance, anomaly and RUL benchmarks, LLM agents, edge deployment, drift — and a verification of the other two documents).
Core Analysis Nodes
1. Anomaly Detector
7 detection methods in one node:
Method Best For
Z-Score Normal distributions, general purpose
IQR Robust to outliers, skewed data
Threshold Fixed min/max limits
Percentile Dynamic bounds based on data distribution
EMA Recent changes, adaptive baseline
CUSUM Drift detection, gradual shifts
Moving Average Smoothed baseline comparison
Hysteresis (Anti-Flicker):
  • Prevents rapid alarm on/off switching near thresholds
  • Configurable consecutive samples before triggering
  • Deadband percentage for exiting anomaly state
Multi-Sensor JSON Input:
  • Accepts JSON objects with multiple sensors: { "temp": 65.2, "pressure": 4.5 }
  • Maintains separate buffers and hysteresis states per sensor
  • Outputs combined result with per-sensor analysis
Example:
[MQTT Sensor] → [Anomaly Detector (Z-Score)] → [Normal] → [Dashboard]
                                              → [Anomaly] → [Alarm]
2. Isolation Forest
ML-based anomaly detection with online learning:
  • Unsupervised learning - no training labels required
  • Detects complex, multivariate anomalies
  • 3 learning modes:
    • Batch - Retrain when buffer full
    • Incremental - Periodic retraining (configurable interval)
    • Adaptive - Auto-adjust threshold based on feedback
  • Configurable number of trees and samples per tree
3. Multi-Value Processor
4 modes for multi-sensor data:
Mode Function
Split Extract individual values from arrays/objects
Analyze Anomaly detection per value (Z-Score, IQR, Threshold, Mahalanobis)
Correlate Pearson, Spearman, or Cross-Correlation between two sensors
Aggregate Reduce to single value (Mean, Median, Min, Max, Sum, Range, StdDev)
Mahalanobis Distance: Detects multivariate anomalies considering correlations between sensors.
Cross-Correlation: Finds time lag between sensors - detects propagation delays (e.g., temperature wave through pipe).
Example:
[Sensors] → [Multi-Value (Split)] → [Anomaly Detector] → ...
[Sensors] → [Multi-Value (Aggregate)] → Mean value for dashboard
4. Signal Analyzer
5 modes for signal analysis:
Mode Output
FFT Frequency peaks, spectral features
Vibration RMS, Crest Factor, Kurtosis, Skewness, Health Score, ISO 20816-3 assessment
Peaks Local maxima/minima detection
Envelope Bearing fault detection (BPFO, BPFI, BSF, FTF from geometry or typed in), BPFI sidebands, looseness, sub-synchronous, with Butterworth filter
Cepstrum Gearbox fault detection (GMF, sidebands)
ISO 20816-3 Vibration Severity:
  • Machine groups 1 (300 kW – 50 MW) and 2 (15 – 300 kW), rigid or flexible foundation; the legacy ISO 10816-1 classes I–IV stay selectable for existing flows
  • Zones A-D with severity levels and recommendations, output as payload.iso20816 (iso10816 kept as an alias)
  • Acceleration input (g, m/s²) is integrated to velocity bin-wise over 10–1000 Hz, not scaled at a single frequency
  • Automatic alarm/warning thresholds
Bearing diagnostics (Envelope mode):
  • Enter the bearing geometry (rolling elements, element and pitch diameter, contact angle) and the node derives BPFO/BPFI/BSF/FTF from the current shaft speed; typed-in frequencies win over derived ones
  • msg.rpm overrides the shaft speed per message for variable-speed drives (vibration, envelope and cepstrum modes)
  • Rules beyond the line match: BPFI harmonics with ±1X sidebands (inner-race defect through the load zone), four or more 1X harmonics (looseness), 0.38–0.48X components (oil whirl / rub, suppressed when they match the cage frequency)
Butterworth Filter:
  • 2nd order IIR filter for envelope analysis
  • Zero-phase filtering (filtfilt) - no phase distortion
  • Automatic fallback for edge cases
Multiple devices per node: set Group By to a message property (typically topic, nested paths like payload.deviceId work too) and the node keeps an independent buffer per device, emitting one result per device tagged with msg.group. Max Groups (default 50) caps memory by dropping the least recently used buffer. Left empty, the node keeps a single shared buffer.
pump-01/vibration ─┐
pump-02/vibration ─┼─→ [Signal Analyzer]  ─→ one result per device
pump-03/vibration ─┘    groupBy: "topic"
Example:
[Vibration Sensor] → [Signal Analyzer (Vibration)] → RMS, ISO 20816 Zone
                   → [Signal Analyzer (FFT)] → Frequency Peaks
                   → [Signal Analyzer (Envelope)] → Bearing faults
5. Trend Predictor
3 modes for trend analysis:
Mode Output
Prediction Future values, trend direction
RUL Remaining Useful Life with confidence intervals
Rate of Change First/second derivative, acceleration
RUL Features:
  • Configurable failure and warning thresholds, for indicators rising or falling towards failure
  • Multiple time units (hours, minutes, days, cycles)
  • Confidence intervals for predictions
  • Status: healthy/warning/critical/failed
  • Degradation models: Linear, Exponential, Weibull (reliability-based)
  • Robust calculation: Theil-Sen estimator, median filter, moving average smoothing
  • Accepts JSON objects with multiple sensors: { "temp": 65.2, "vibration": 2.5 }
  • Calculates trends/RUL for each sensor independently
  • Tracks threshold exceedance per sensor
Weibull Analysis:
  • Weibull remaining life from the configured shape β and characteristic life η (equivalent-age method)
  • B-Life calculation (B1, B5, B10, B50) - time when X% have failed
  • Failure mode classification (infant_mortality, useful_life, wear_out, rapid_wear_out)
  • MTTF calculation
Example:
[Temperature] → [Trend Predictor (RUL)] → "RUL: 48.5h (95% confidence)"
6. Health Index
Multi-sensor health aggregation:
  • Weighted combination of sensors
  • 0-100% health score
  • Configurable aggregation methods (Weighted, Dynamic, Minimum, Average, Geometric)
  • Dynamic weighting - Auto-adjusts weights based on sensor reliability
  • Visual threshold configuration with slider-based UI
  • Configurable status levels (healthy, warning, degraded, critical)
  • Automatic worst sensor identification with reliability metrics
7. ML Inference
Machine Learning model inference with multiple runtime options:
JavaScript Runtimes (npm install)
Work immediately after installation - no additional setup:
  • ONNX (.onnx) - PyTorch, TensorFlow, scikit-learn models
  • TensorFlow.js (model.json + .bin) - Keras, TensorFlow models
Python Runtimes (Docker/Python required)
Require Python environment with ML libraries:
  • TFLite (.tflite) - Edge/mobile optimized models
  • Keras (.keras, .h5) - Native Keras models
  • scikit-learn (.pkl, .joblib) - Classic ML (Random Forest, SVM, etc.)
Hardware Accelerated
  • Google Coral / Edge TPU - 10-100x faster inference
Tip: Use ONNX format for best compatibility across frameworks. The node automatically detects available runtimes and shows warnings for Python-dependent formats.
8. PCA Anomaly Detection
Principal Component Analysis for multi-sensor anomaly detection:
  • Reduces high-dimensional data to principal components
  • Detects anomalies using Hotelling's T² and SPE statistics
  • Auto-selects components based on explained variance threshold
  • Contribution analysis - identifies which sensor caused the anomaly
Method Use Case
T² Variations within normal operating space
SPE New patterns not seen during training
Combined Both T² and SPE (recommended)
9. Training Data Collector
Collects sensor data for ML model training:
Feature Description
3 Collection Modes Batch, Streaming (JSONL), Time-Series Windows
Multiple Export Formats CSV, JSONL, JSON with metadata
Auto-Compression .gz compression for large datasets (>10k samples)
Train/Val/Test Split Automatic dataset splitting with configurable ratios
Label Modes Manual, from message, RUL countdown, unlabeled
S3 Upload Direct upload to AWS S3 buckets
Data Validation Rejects NaN/Infinity, tracks statistics
Use Cases:
  • Collect labeled training data from live sensors
  • Create datasets for the training notebooks
  • Export time-series windows for LSTM/Transformer training
  • Automatic cloud backup to S3
Control Actions:
msg.action = "export";   // Export current buffer
msg.action = "clear";    // Clear buffer
msg.action = "stats";    // Get collection statistics
msg.action = "pause";    // Pause collection
msg.action = "resume";   // Resume collection
msg.action = "resetRul"; // Reset RUL counter
Example:
[Sensors] → [Multi-Value Processor] → [Training Data Collector] → [S3/File]
                              [Inject: action="export"]
10. LLM Analyzer
Buffers sensor samples and asks an LLM to analyse them in plain language or structured JSON:
Feature Description
5 Providers Anthropic (Claude), OpenAI (GPT), Google (Gemini), Ollama (local), OpenAI-compatible (Groq, Together, OpenRouter, DeepSeek, Mistral, vLLM, LMStudio …)
3 Trigger Modes Batch (fire when N samples buffered), Manual (msg.flush=true), Interval (every X ms)
2 Input Modes Scalar (single sensor stream) or Record (multi-sensor objects with auto-detected columns)
2 Output Modes Text or structured JSON with example-based schema + optional dot-path field extraction
Cost Tracking Per-call msg.usage plus lifetime msg.totalUsage and live status indicator
Buffer Caps Hard ring-buffer size + separate cap on samples sent to the prompt
Persistence Optional buffer + counters survive Node-RED redeploys
Concurrency-safe Triggers during in-flight calls are queued, never silently dropped
Use Cases:
  • Operator-readable batch summaries ("the last 50 readings look unusual because ...")
  • Structured anomaly scoring (LLM returns {severity, score, summary} → switch-node routes alarms)
  • Cross-sensor correlation in record mode ("temp spiked AND pressure dropped — typical leak pattern")
  • Edge-deployable with Ollama for air-gapped sites
Configuration:
// Inputs
msg.payload    // number / number[] (scalar) or object / object[] (record)
msg.flush      // true → fire now (manual mode)
msg.prompt, msg.systemPrompt, msg.model // per-message overrides — only with "Allow msg overrides"
                                        // enabled (otherwise ignored with one warning)
msg.apiUrl                              // only with "Allow msg.apiUrl override" enabled (same origin)
// Outputs
msg.payload    // text response, parsed JSON object, or extracted field
msg.usage      // { inputTokens, outputTokens } from this call
msg.totalUsage // lifetime running totals + callCount
msg.samples    // exact batch sent — useful for archiving / replay
msg.json       // (JSON mode) full parsed object
msg.rawResponse // (JSON mode) raw LLM text
Example:
[Sensor] → [Anomaly Detector] → [LLM Analyzer (json)] → [Switch on score≥0.7] → [Alert]
11. Condition Monitoring Data Source
Synthetic sensor stream of a degrading machine — for demos, testing and predictive-maintenance prototyping (palette label CM Sensor Source):
Feature Description
Asset types Pump, motor, fan, gearbox (with configurable RPM → shaft frequency)
Output modes object (full JSON), value (vibration RMS), or waveform (raw vibration time-signal array + msg.samplingRate, for the Signal Analyzer)
Degradation model Health (0–100%) decays by degRate × loadFactor × (1 + Σ fault severity)
Derived sensors Vibration RMS (mm/s), temperature (°C), current (A), pressure (bar)
Fault injection Imbalance (1×), misalignment (2×), bearing (~3.5×), looseness (0.5×) with characteristic frequencies
Thresholds + RUL ISO 10816-style warn/alarm levels and an estimated remaining useful life
Streaming control Auto-start on deploy, interval timer, or manual inject; start/stop/reset commands
Runtime overrides msg.config adjusts load, faults, noise, thresholds and interval live
Reproducible Optional integer seed for deterministic streams
Configuration:
// Control inputs
msg.payload = "start" | "stop" | "reset";   // or msg.start / msg.stop / msg.reset = true
msg.config  = {                              // live reconfiguration
  load: 90, degRate: 0.2, noise: 0.1,
  faults: { bearing: 0.85, imbalance: 0.2 },
  warnThreshold: 4.5, alarmThreshold: 7.1, intervalMs: 500
msg.emit = true;   // with msg.config: also emit a sample immediately
// Output (object mode)
msg.payload = { asset, health, status, rul, sensors:{...}, faults:[...], thresholds:{...} };
msg.status  // "normal" | "warning" | "alarm"
msg.health  // 0–100
msg.alarm   // boolean
Example:
[Inject "start"] → [CM Data Source] → [Health Index / Signal Analyzer / Anomaly Detector]
Vision Nodes (for image models)
12. Image Preprocess
Turns a real image (PNG/JPEG Buffer) into a normalized tensor for ml-inference — pure-JS (pngjs + jpeg-js, no native deps).
Feature Description
Decode PNG and JPEG buffers
Resize bilinear / nearest to a target W×H
Normalize 0-1, 0-255, -1..1, imagenet (mean/std), or custom mean/std
Layout NCHW (ONNX) or NHWC (TFJS); channel order RGB/BGR; optional grayscale
Keeps the image sets msg.image (resized PNG) so vision-annotator can draw on the real photo
Output: msg.payload = flat tensor, msg.tensorShape = e.g. [1,3,224,224], msg.preprocess = metadata. Set the ml-inference Input shape to match.
13. Vision Annotator
Renders an image-model's output as an annotated image (PNG Buffer on msg.payload) plus structured msg.annotations. 9 modes:
Mode Annotation
boxes bounding boxes (xyxy or yolo + NMS)
obb oriented / rotated boxes
segmentation semantic class-mask overlay (+ area fractions)
instances per-object masks + bbox + area
polygons contour outlines (+ area & perimeter)
keypoints keypoints + skeleton (pose)
heatmap scalar field → jet/gray colormap (depth / CAM / density)
anomaly anomaly score field → heatmap + thresholded regions + metrics
classification label banner + status dot (softmax confidence)
With Editor preview on (default), the annotated image is drawn live as a thumbnail under the node on the canvas — double-click it to enlarge. Display it elsewhere with a dashboard ui_image, or via msg.payload.
A ready-to-run, self-validating example flow that exercises every node and every annotation mode (with both synthetic and real pretrained models — SqueezeNet, YOLOv10, YOLOv8-pose, Depth-Anything) lives in examples/test-suite.json. Fetch the models first with bash tools/fetch-models.sh, then GET /test runs all checks and GET /gallery shows every annotated image.
Data Source Nodes (Demo)
Simulate input so any node can be tested without real hardware. (The CM Sensor Source, node #11 above, is the third one — it also has a waveform output mode that emits a raw vibration time-signal for the Signal Analyzer.)
14. CM Image Source
Synthetic inspection-image generator (image-source) — the visual counterpart. Produces a textured surface with configurable defects (spot / scratch / multiple), severity, noise and optional degrade over time, plus a ground-truth mask (msg.mask) and defect list. Drives the whole vision pipeline.
15. CM JSON Source
Generic structured-data simulator (json-source). Define arbitrary fields ({ "temperature": { "mean": 60, "noise": 2, "trend": 0.05 }, "asset": "pump-01" }); each numeric field is mean + trend·count + gaussian(noise), constants pass through. Optional anomaly injection. Drives the object/record nodes (multi-value-processor, health-index, pca-anomaly, training-data-collector, llm-analyzer record mode).
Pretrained Models (catalog)
A curated catalog of pretrained models for common use cases ships with the package (nodes/model-catalog.json). In the ML Inference node, pick one from the Pretrained dropdown — it auto-fills the source, URL, SHA-256, type and input shape, and shows the matching preprocessing + annotation. The Insert full pipeline button drops a ready-wired image-preprocess → ml-inference → vision-annotator chain.
Use case Model Source License
Image classification (ImageNet) SqueezeNet 1.1 ONNX Model Zoo BSD-3-Clause
Object detection (COCO) YOLOv10n (NMS-free) onnx-community AGPL-3.0
Human pose / keypoints YOLOv8n-pose Xenova AGPL-3.0
Monocular depth Depth-Anything-v2-small onnx-community Apache-2.0
Surface defect segmentation bundled (trained in-repo) this package Apache-2.0
Vibration fault classification bundled (trained in-repo) this package Apache-2.0
  • Fetched on demand, not redistributed: url models download on deploy into ml-models/cache and are verified against the catalog's SHA-256. Mind each model's license (YOLO is AGPL-3.0). Only the small in-repo models are bundled.
  • Pre-download everything for offline use with bash tools/fetch-models.sh.
Which Node Should I Use?
Quick Decision Tree
Start from your data and goal, follow to the node:
flowchart TD
    Q{"What is your data?"}
    Q -->|"single numeric stream"| G1{"goal?"}
    G1 -->|"fixed min/max limits"| AD1["Anomaly Detector · threshold"]
    G1 -->|"statistical outliers"| AD2["Anomaly Detector · z-score / IQR"]
    G1 -->|"gradual drift"| AD3["Anomaly Detector · CUSUM"]
    G1 -->|"forecast / remaining useful life"| TP["Trend Predictor"]
    Q -->|"many sensors at once"| G2{"goal?"}
    G2 -->|"split / aggregate"| MVP["Multi-Value Processor"]
    G2 -->|"correlated / multivariate"| PCA["PCA Anomaly · Mahalanobis"]
    G2 -->|"single 0–100 score"| HI["Health Index"]
    G2 -->|"complex, unsupervised"| IF["Isolation Forest"]
    Q -->|"raw vibration waveform"| SA["Signal Analyzer<br/>FFT · vibration · envelope (bearings) · cepstrum (gears)"]
    Q -->|"image / photo"| VIS["Image Preprocess → ML Inference → Vision Annotator"]
    Q -->|"need a trained model"| ML["ML Inference (ONNX / TFJS)"]
    Q -->|"want a text summary"| LLM["LLM Analyzer"]
    Q -->|"build a training dataset"| TDC["Training Data Collector"]
Tip: the Demo sources (CM Sensor Source, CM Image Source, CM JSON Source) let you drive any of these without real hardware.
Usage Examples
Simple Temperature Monitoring
[MQTT] → [Anomaly Detector] → [Normal] → [Dashboard]
                             → [Anomaly] → [Email Alert]
Motor Predictive Maintenance
                                  → [Trend Predictor] → RUL Display
                                  → [Signal Analyzer (FFT)] → Frequency Chart
          → [Health Index] → Dashboard
Bearing Vibration Analysis
[Vibration] → [Signal Analyzer (Vibration)] → Features
            → [Signal Analyzer (FFT)] → Frequencies
            → [Signal Analyzer (Envelope)] → Bearing Faults
            → [Anomaly Detector (IQR)] → Outliers
ML Anomaly Detection
[Features] → [ML Inference (Autoencoder)] → Reconstruction Error → [Anomaly Detector (Threshold)]
Node Configuration Examples
// Input
msg.payload = 42.5;
// Output
  "payload": 42.5,
  "isAnomaly": true,
  "severity": "critical",
  "method": "zscore",
  "zScore": 3.2,
  "mean": 35.0,
  "stdDev": 2.3,
  "threshold": 3.0,
  "warningThreshold": 2.0,
  "bufferSize": 100,
  "windowSize": 100
// Input (continuous stream)
msg.payload = 0.45;
// Output
  "payload": 0.45,
  "peaks": [
    { "frequency": 30, "magnitude": 0.5 },
    { "frequency": 157, "magnitude": 0.3 }
  "dominantFrequency": 30,
  "features": {
    "spectralCentroid": 85.2,
    "crestFactor": 3.5,
    "rms": 0.42
Trend Predictor (RUL Mode)
// Input
msg.payload = 75.2;
msg.timestamp = Date.now();
// Output (RUL Mode)
  "payload": 75.2,
  "rul": {
    "value": 48.5,
    "unit": "hours",
    "lower": 42.1,          // Lower confidence bound
    "upper": 55.2,          // Upper confidence bound
    "confidence": 0.87,     // R-squared
    "status": "warning"     // healthy/warning/critical/failed
  "degradation": {
    "percent": 75.2,        // % toward failure threshold
    "rate": 0.5,            // Degradation rate per sample
    "trend": "increasing"
  "thresholds": {
    "failure": 100,
    "warning": 80
Dynamic Configuration (msg.config)
All major nodes support dynamic runtime configuration via msg.config. This allows you to override node settings on a per-message basis without redeploying the flow.
Supported Nodes and Parameters
Anomaly Detector
msg.config = {
  method: "zscore",           // Override detection method
  zscoreThreshold: 2.5,       // Override Z-score threshold
  zscoreWarning: 1.8,         // Override warning threshold
  iqrMultiplier: 1.5,         // Override IQR multiplier
  iqrWarningMultiplier: 1.0,  // Override IQR warning multiplier (0 = off)
  minThreshold: 10,           // Override min threshold
  maxThreshold: 100,          // Override max threshold
  lowerPercentile: 5,         // Percentile bounds (0-100)
  upperPercentile: 95,
  emaThreshold: 2.0,          // EMA critical / warning
  emaWarning: 1.5,
  cusumThreshold: 5.0,        // CUSUM critical / warning / drift
  cusumWarning: 3.0,
  cusumDrift: 0.5,
  maThreshold: 2.0,           // Moving-average critical / warning
  maWarning: 1.5,
  hysteresisEnabled: false,   // Enable/disable hysteresis
  consecutiveCount: 5         // Override consecutive count
// An unknown `method` is ignored with one warning; batch mode honours the same keys.
msg.payload = 42.5;
msg.regime = "high-load";     // selects the baseline when "Regime Property" is set to "regime"
Trend Predictor
msg.config = {
  mode: "rate-of-change",     // Override mode (prediction/rate-of-change/rul)
  threshold: 80,              // Override prediction threshold
  rocThreshold: 5,            // Override rate of change threshold
  failureThreshold: 100,      // Override RUL failure threshold
  warningThreshold: 80,       // Override RUL warning threshold
  predictionSteps: 10,        // Override prediction horizon
  failureDirection: "falling" // "rising" (default) or "falling": which way is failure
msg.payload = 75.2;
Signal Analyzer
msg.config = {
  mode: "vibration",          // Override mode (fft/vibration/peaks/envelope/cepstrum)
  samplingRate: 20000,        // Sampling rate of THIS message's frame (msg.samplingRate does the same)
  vibrationThreshold: 5,      // Override the crest-factor alarm threshold
  minPeakHeight: 0.3,         // Peaks mode: minimum peak height (peakThreshold is the legacy alias)
  shaftSpeed: 1450,           // RPM for this message (msg.rpm / msg.shaftSpeed do the same)
  bearingBalls: 9,            // Bearing geometry overrides (envelope mode)
  bearingBallDiameter: 7.94,
  bearingPitchDiameter: 39.04,
  bearingContactAngle: 0,
  bearingBPFO: 107.5          // …or the frequencies directly
msg.payload = [0.5, 0.7, 0.3, ...];
msg.rpm = 1450;               // shortest form of the shaft-speed override
Health Index
msg.config = {
  healthyThreshold: 90,       // Override healthy threshold
  warningThreshold: 70,       // Override warning threshold
  degradedThreshold: 50,      // Override degraded threshold
  criticalThreshold: 25,      // Override critical threshold
  aggregationMethod: "minimum", // Override aggregation (weighted/dynamic/minimum/average/geometric)
  sensorWeights: {            // Override sensor weights
    "temp": 2.0,
    "vibration": 1.5
msg.payload = { temp: 45, vibration: 2.3 };
Use Cases
  1. Adaptive Thresholds: Adjust thresholds based on time of day, operating mode, or external conditions
  2. A/B Testing: Compare different detection parameters on the same data stream
  3. Contextual Sensitivity: Use tighter thresholds during critical operations
  4. Batch Processing: Process historical data with different configurations
Docker Setup
For ML Inference Node
The ML Inference node requires a Debian-based container with native dependencies.
# Use the provided docker-compose.dev.yml
docker-compose -f docker-compose.dev.yml up
# This builds a custom image with:
# - Python 3 + build tools
# - TensorFlow.js Node bindings
# - ONNX Runtime Node bindings
Standard Setup
# Production mode
docker-compose up
# Development mode (hot-reload)
GPU Acceleration (NVIDIA, optional)
Both inference paths — the direct TensorFlow.js path in the Node-RED container and the MAX Engine bridge path (MAX Engine + ONNX Runtime) — can optionally run on an NVIDIA GPU. The CPU path stays the default; GPU is opt-in.
Host prerequisites:
Enable via Compose override:
docker compose -f docker-compose.dev.yml -f docker-compose.gpu.yml up --build
The override file swaps the Dockerfiles for their GPU variants (Dockerfile.gpu, Dockerfile.max.gpu) at build time and reserves the GPU(s) via deploy.resources. What this does:
Container GPU image base Enabled backends
node-red nvidia/cuda:12.4.1-cudnn-runtime-ubuntu22.04 @tensorflow/tfjs-node-gpu, tensorflow[and-cuda]
max-engine nvidia/cuda:12.4.1-cudnn-runtime-ubuntu22.04 MAX Engine (GPU) + onnxruntime-gpu (CUDAExecutionProvider)
The bridge code (nodes/python/max_bridge.py) automatically selects the best available backend in this order: MAX Engine GPU → ONNX Runtime CUDA → ONNX Runtime CPU.
Verification:
# ONNX Runtime should list CUDAExecutionProvider
docker compose -f docker-compose.dev.yml -f docker-compose.gpu.yml \
  exec max-engine python3 -c "import onnxruntime as ort; print(ort.get_available_providers())"
# Bridge status (shows backend & loaded models)
curl http://localhost:8765/status
# Inside the Node-RED container: tfjs-node-gpu should find CUDA
  exec node-red node -e "require('@tensorflow/tfjs-node-gpu'); console.log('OK')"
Notes:
  • The GPU images are significantly larger (several GB), so the first build takes correspondingly longer.
  • If a single GPU path is enough, you can trim the override file and keep only the max-engine or only the node-red service block.
  • For MAX-Engine-only acceleration, the official modular/max-nvidia-full images are an alternative — usable as a drop-in for Dockerfile.max.gpu (base image swap).
Dependencies
Required
  • Node-RED >= 3.0.0
  • Node.js >= 18.0.0 (the LLM Analyzer node uses the built-in fetch)
Core Dependencies
  • fft.js - High-performance FFT (Radix-4 Cooley-Tukey algorithm)
  • ml-isolation-forest - For Isolation Forest node
  • ml-matrix, ml-pca - Matrix operations and PCA (multi-value processor, PCA anomaly)
  • jpeg-js, pngjs - JPEG/PNG decoding and encoding for the vision nodes
Optional - JavaScript ML Runtimes
  • @tensorflow/tfjs-node - TensorFlow.js support
  • onnxruntime-node - ONNX Runtime support
Optional - Python ML Runtimes (Docker or manual)
For TFLite, Keras, and scikit-learn models:
pip install numpy tensorflow scikit-learn joblib ai-edge-litert
# TFLite runs on LiteRT (ai-edge-litert). An already installed tflite-runtime
# still works, but that package has no wheels for Python 3.12 and newer.
Performance Features
Sliding-window statistics
The Anomaly Detector keeps its live window as a plain value array plus a Welford accumulator, so the moment-based methods (z-score, EMA, CUSUM, moving average) read mean and standard deviation in O(1) per message instead of re-reducing the window. The order-statistic methods (IQR, percentile) still sort the window, which is inherent to them. windowSize is capped at 100 000.
The Signal Analyzer uses fft.js with the Radix-4 Cooley-Tukey algorithm:
  • O(n log n) complexity vs O(n²) for naive DFT
  • 10-100x faster for large signal buffers (2048+ samples)
  • Automatic power-of-2 sizing and windowing (Hann, Hamming, Blackman)
Persistent Python Bridge
For Python-based ML models (Keras, scikit-learn, TFLite), a persistent subprocess is maintained:
  • Single Python process shared across all ML Inference nodes
  • Model caching - models stay loaded in memory between inferences
  • 10-100x faster compared to spawning a new process per inference
  • Automatic restart if the bridge crashes
Check bridge status via API: GET /ml-inference/python-bridge
State Persistence
Enable Persist State in node configuration to save:
  • Data buffers and training history
  • Calculated statistics (mean, std, thresholds)
  • Trained model states (PCA, Isolation Forest)
States survive Node-RED restarts when using file-based context storage:
// settings.js
contextStorage: {
    default: { module: "localfilesystem" }
Or use the provided Docker image which includes all dependencies.
Security
Admin API permissions
Every HTTP route these nodes register on the Node-RED admin API is guarded by RED.auth.needsPermission(). Node-RED does not apply adminAuth to routes a node registers itself, so this is the node's own responsibility. If you use adminAuth with per-user permissions, grant:
Permission Grants
ml-inference.read Runtime/bridge probing, model listing
ml-inference.write Model upload and deletion
training-data-collector.read Dataset listing and download
signal-analyzer.read, isolation-forest-anomaly.read Library availability probes
A wildcard permission (*) covers all of them.
For operators under NIS2 or an IEC 62443 zone model this matters: the editor port is the only network surface these nodes add, every route on it is authenticated, every request-supplied file name is validated against an allowlist before it reaches the file system, and no node opens an outbound connection unless configured to (LLM provider, MLflow registry, WebSocket broadcast). Cybersecurity is one of the three most-cited barriers to condition-monitoring adoption — see docs/RESEARCH-cm-pdm-landscape.md.
Settings
Optional hardening knobs for settings.js:
module.exports = {
    // Ceiling for POST /ml-inference/upload and /upload-tfjs.
    // Default: 134217728 (128 MB). Bodies above this get a 413.
    mlInferenceMaxUploadBytes: 128 * 1024 * 1024,
    // Directories model paths may resolve into, in addition to the
    // package's model store (<userDir>/ml-models) and its bundled models.
    // The Node-RED userDir and the process cwd are NOT allowlisted.
    conditionMonitoring: {
        allowedModelPaths: ["/data/models"]
Credentials
Store API keys in a node's credential field, never in the plain config field. Credentials are kept out of flows.json and out of flow exports; llm-analyzer and ml-inference (URL, Hugging Face, MLflow and registry tokens) warn at startup if they find a key in the config instead. S3 credentials for training-data-collector are resolved in this order: the node's credential fields, then AWS_ACCESS_KEY_ID / AWS_SECRET_ACCESS_KEY, then the AWS SDK default chain (shared config, IAM role); keys left in the plain config by an old editor are ignored with a warning. The WebSocket auth token of anomaly-detector is a credential too, next to a comma-separated Origin allowlist in the node's WebSocket panel.
See SECURITY.md for how to report a vulnerability.
Documentation
Contributing
Contributions are welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Add tests if applicable
  4. Submit a pull request
Sponsor this project
This package is developed and maintained in my own time. If it saves you some, consider supporting it:
Sponsor on GitHub Buy Me a Coffee
Apache License 2.0 — see LICENSE and NOTICE.
Copyright 2025-2026 blanpa
Contributing and forks
Pull requests are welcome, including large ones. If you are planning a bigger change — a dependency migration, a restructure, new nodes — please open an issue first. We are happy to discuss it and to land substantial work here; that is usually less effort than maintaining a parallel package, and it keeps a single place for users to report bugs.
If you do publish a fork under its own package name, please also rename the Node-RED node type IDs (for example myprefix-condition-monitoring-*) and use your own palette category. Node-RED refuses to register a node type that is already claimed, so identical type IDs make it impossible to install both packages side by side.
Roadmap
  • Consolidate nodes into unified components
  • ML Inference with Model Registry
  • Google Coral / Edge TPU support
  • PCA Anomaly Detection
  • Bearing fault detection via Signal Analyzer (Envelope Mode)
  • Weibull reliability analysis
  • Cepstrum analysis for gearbox diagnostics
  • Mahalanobis distance for multivariate anomalies
  • ISO 20816-3 vibration severity assessment (machine groups, spectral integration of acceleration input)
  • Bearing fault frequencies from geometry, per-message shaft speed, BPFI-sideband / looseness / sub-synchronous rules
  • Operating-point regimes (one baseline per speed/load class) in the anomaly detector
  • Real run-to-failure fixture (PRONOSTIA Bearing1_1) in the test suite
  • Hysteresis (anti-flicker) for anomaly detection
  • Pre-trained models for common use cases (model catalog + ML Inference picker)
  • Concept/data-drift monitoring + retraining feedback loop (current CUSUM drift is process drift, not model/distribution drift)
  • Consistent severity/score in alert output across all anomaly nodes (isolation-forest/pca lack the severity field that anomaly-detector already emits)
Made with ❤️ for the Node-RED community
Version: 0.4.2
Updated 3 days ago
Rating: 4.7 6
70 in the last week
  • anomaly-detector
  • isolation-forest-anomaly
  • multi-value-processor
  • signal-analyzer
  • trend-predictor
  • health-index
  • ml-inference
  • pca-anomaly
  • training-data-collector
  • llm-analyzer
  • condition-monitoring-source
  • vision-annotator
  • image-preprocess
  • image-source
  • json-source
  • anomaly-detection
  • time-series
  • predictive-maintenance
  • z-score
  • iqr
  • isolation-forest
  • threshold
  • percentile
  • ema
  • cusum
  • exponential-moving-average
  • fft
  • vibration-analysis
  • vibration-features
  • trend-prediction
  • health-index
  • rul
  • remaining-useful-life
  • rms
  • crest-factor
  • kurtosis
  • skewness
  • machine-learning
  • ml-inference
  • tensorflow
  • tfjs
  • onnx
  • deep-learning
  • neural-network
  • training-data
  • data-collection
  • dataset
  • ml-training
  • s3-upload
  • llm
  • claude
  • anthropic
  • llm-analysis
  • openai
  • simulator
  • data-source
  • synthetic-data
  • vibration-simulation
