node-red-contrib-compression 0.2.8
Node-RED nodes for data compression, caching, and visualization
npm install node-red-contrib-compression
A collection of Node-RED nodes for time-series data compression, caching, visualization, and data processing utilities.
  • Time-series compression with multiple algorithms (Swinging Door, Exception-based, Deduplication)
  • Message caching with TTL and size limits
  • State sampling for periodic data snapshots
  • Data visualization with real-time charts
  • Type routing for automatic data type detection and routing
  • ID-to-name mapping with web-based table editor
  • Signal simulation for testing compression algorithms
Or install directly from the Node-RED palette manager.
Compression
Time-series data compression node that reduces storage and transmission overhead while preserving data fidelity.
Algorithms:
  • Deduplicate - Removes consecutive duplicate values
  • Deduplicate+prev - Deduplication with previous point insertion on value change
  • Exception - Outputs when value changes by more than a deviation threshold
  • Exception+prev - Exception-based with previous point insertion
  • Swinging Door - Swinging door trending algorithm for optimal linear compression
  • Timedelta - Simple time-based sampling at regular intervals
Configuration:
  • algorithm - Compression algorithm to use
  • deviation - Deviation threshold (for exception and swinging-door algorithms)
  • minDuration - Minimum time between outputs (seconds)
  • maxDuration - Maximum time between outputs (seconds)
  • timestampField - Message property containing timestamp (default: timestamp)
  • valueField - Message property containing value (default: payload)
  • snapshotKey - Global context key for state storage (default: snapshot)
Outputs:
  1. Original message (always passed through)
  2. Compressed message (only when point should be stored) or null
Example:
// Input message
  topic: "temperature",
  timestamp: 1609459200000,
  value: 23.5
// Compressed output includes
  ...originalMessage,
  compressed: true,
  skippedCount: 5  // Number of points skipped since last output
Cache
Stores messages in flow or global context with optional TTL and size limits. Useful for maintaining current state of multiple data points.
Configuration:
  • contextName - Context variable name (default: cache)
  • contextType - global or flow
  • keyProperty - Message property to use as cache key (default: topic)
  • ttl - Time-to-live in seconds (0 = no expiration)
  • maxSize - Maximum number of cached entries (0 = unlimited, uses LRU eviction)
  • outputOnUpdate - Whether to pass messages through on first output
Special Commands:
  • msg.topic = "_cache" - Retrieve entire cache
  • msg.topic = "_get" with msg.key - Get specific entry
  • msg.topic = "_clear" - Clear all cached data
Example:
// Store message
{ topic: "sensor1", payload: 42.5 }
// Retrieve all cached values
{ topic: "_cache" }
// Returns: { payload: { sensor1: {...}, sensor2: {...} } }
Sample
Reads all entries from a global context dictionary and outputs them as individual messages or bulk array. Works perfectly with the Cache node to periodically sample current state.
Configuration:
  • stateKey - Global context key to read from (default: cache)
  • outputMode - individual (one message per entry) or bulk (single array message)
Example:
// Trigger sampling
{ payload: "trigger" }
// Individual output mode sends multiple messages:
{ topic: "sensor1", payload: {...}, _sampledAt: 1609459200000 }
{ topic: "sensor2", payload: {...}, _sampledAt: 1609459200000 }
// Bulk output mode sends one message:
{ payload: [{...}, {...}], topic: "bulk", count: 2 }
Chart
Real-time visualization node that displays time-series data in the Node-RED editor. Automatically separates raw and compressed data into different series.
Configuration:
  • title - Chart title
  • maxPoints - Maximum points per series (default: 100)
  • seriesField - Message property for series name (default: topic)
Features:
  • Automatically creates separate series for raw vs compressed data
  • Real-time updates via WebSocket
  • Clear chart via msg.topic = "_clear"
  • HTTP endpoints for data access and clearing
Type Router
Routes messages based on payload data type with automatic type coercion from strings.
Outputs:
  1. Integer values
  2. Float values
  3. Boolean values
  4. String values
Features:
  • Converts string representations ("true", "123", "45.67") to appropriate types
  • Adds msg.dataType property indicating detected type
  • Useful for processing data from text-based protocols (MQTT, HTTP, etc.)
Example:
// Input: { payload: "123.45" }
// Output on port 2 (float): { payload: 123.45, dataType: "float" }
// Input: { payload: "true" }
// Output on port 3 (bool): { payload: true, dataType: "bool" }
Mapping
ID-to-name mapping table with a web-based editor. Creates bidirectional lookup dictionaries in flow or global context. Useful for tag databases, sensor mappings, and configuration management.
Configuration:
  • tableName - Display name for the table
  • contextName - Context variable name for dictionaries
Features:
  • Persists mappings to JSON files in {userDir}/mapping-data/
  • Web-based table editor (click button in node editor)
  • Auto-save on edit
  • Copy/paste TSV format (Excel compatible)
  • Creates forward lookup: { id → {name, type, deviation, interval} }
  • Creates reverse lookup: { name → {id, type, deviation, interval} }
Outputs:
  1. ID field
  2. Name field
  3. Full object with metadata
Commands:
  • msg.payload = "get" - Output all mappings
  • msg.payload = "clear" - Clear all mappings
  • { id: "...", name: "...", type: "...", deviation: 0, interval: 0 } - Add single mapping
  • msg.payload = [...] - Replace all mappings with array
Example Usage:
// Access mapping in function node
const mapping = global.get("mapping"); // or flow.get()
const metadata = mapping["sensor123"];
// Returns: { name: "Temperature Sensor", type: "ExcDev", deviation: 0.5, interval: 60 }
// Reverse lookup
const reverseMapping = global.get("mapping_reverse");
const metadata = reverseMapping["Temperature Sensor"];
// Returns: { id: "sensor123", type: "ExcDev", deviation: 0.5, interval: 60 }
Simulator
Generates simulated signal data for testing compression algorithms.
Waveforms:
  • Sinusoid - Smooth sine wave oscillating between -amplitude and +amplitude
  • Seesaw - Sawtooth wave with linear rise from -amplitude to +amplitude
  • Rectangle - Square wave alternating between -amplitude and +amplitude
  • Random - Random values uniformly distributed between -amplitude and +amplitude
Configuration:
  • waveform - Signal type to generate
  • amplitude - Peak deviation from offset value
  • frequency - Oscillation frequency in Hz (cycles per second)
  • offset - Center value around which signal oscillates
  • interval - Time between samples in milliseconds
  • topic - Value for msg.topic in output messages
  • autoStart - Start generating signals when flow deploys
Control:
  • msg.payload = "start" or true - Start continuous generation
  • msg.payload = "stop" or false - Stop generation
  • msg.payload = "reset" - Reset time counter to zero
  • Any other value - Generate single sample
Output:
  topic: "simulation",
  payload: 1.234,
Example Flows and Test Cases
Comprehensive test cases and example flows are available in the examples folder:
Import any of these files in Node-RED to see working examples and test all functionality.
Typical Use Case
A common pattern for industrial IoT or sensor data processing:
[Simulator] → [Compression] → [Cache] → [Chart]
              [Database]     [Sample] → [Dashboard]
  1. Simulator - Generate test signals (sinusoid, sawtooth, square, random)
  2. Compression - Reduce data volume while preserving trends
  3. Cache - Maintain current state of all sensors
  4. Chart - Visualize raw vs compressed data
  5. Sample - Periodically snapshot current state for dashboards
  6. Database - Store only compressed points
Testing
Testing uses Playwright for browser/UI verification and the Node-RED MCP server to deploy flows and inject messages into a running Node-RED instance.
Requirements
  • Node-RED >= 2.0.0
  • Node.js >= 18.0.0
MIT
Contributing
Issues and pull requests welcome at the project repository.
Version: 0.2.8
Updated 9 months, 3 weeks ago
132 in the last week
  • compression
  • cache
  • chart
  • sample
  • type-router
  • mapping
  • compression-simulator
  • cron-sample
  • compression
  • chart
  • visualization
  • cache
