node-red-contrib-comfoair 0.0.9
Node-RED Node, that reads and parses the data from a Zehnder ComfoAir 350 and similar devices
npm install node-red-contrib-comfoair
npm version license
Node-RED Node, that reads and parses the data from a Zehnder ComfoAir 350 and similar devices.
This work depends on the comfoair Module (node-comfoair@github and comfoair@npm).
Just run
How to use
Connect to your bus system via serial connection and configure the comfoair node. Follow the instruction for streaming with comfoair and pass json objects to this node.
Additional info from VincentSC
Zehnder talks about intake, exhaust, supply and extract. Or extract, supply, incoming and outgoing.
This library uses supply, exhaust, outgoing and outside.
intake-exhaust-supply-extract
This is my guess how it translates:
  • outside = intake / incoming
  • supply = supply
  • exhaust = extract
  • outgoing = exhaust / outgoing
Example
[{"id":"75939927.987828","type":"inject","z":"f1f45be1.d6959","name":"getTemperatureStates","topic":"","payload":"{\"name\":\"getTemperatureStates\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":900,"y":1020,"wires":[["54ede071.3b8cf"]]},{"id":"1080bf11.e62391","type":"inject","z":"f1f45be1.d6959","name":"setLevelMiddle","topic":"","payload":"{\"name\":\"setLevel\",\"params\":{\"level\":\"middle\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":880,"y":1300,"wires":[["54ede071.3b8cf"]]},{"id":"86c0aa8e.73a6d8","type":"inject","z":"f1f45be1.d6959","name":"setLevelAway","topic":"","payload":"{\"name\":\"setLevel\",\"params\":{\"level\":\"away\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":870,"y":1220,"wires":[["54ede071.3b8cf"]]},{"id":"d89b4127.308c7","type":"debug","z":"f1f45be1.d6959","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1390,"y":1020,"wires":[]},{"id":"54ede071.3b8cf","type":"comfoair","z":"f1f45be1.d6959","name":"ComfoAir","datasource":"6ded16c2.7801","x":1220,"y":1020,"wires":[["d89b4127.308c7"]]},{"id":"211911c4.82bee6","type":"inject","z":"f1f45be1.d6959","name":"setLevelHigh","topic":"","payload":"{\"name\":\"setLevel\",\"params\":{\"level\":\"high\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":870,"y":1340,"wires":[["54ede071.3b8cf"]]},{"id":"d4c9f55a.b60f88","type":"inject","z":"f1f45be1.d6959","name":"setLevelLow","topic":"","payload":"{\"name\":\"setLevel\",\"params\":{\"level\":\"low\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":870,"y":1260,"wires":[["54ede071.3b8cf"]]},{"id":"568d7661.6fb49","type":"inject","z":"f1f45be1.d6959","name":"getBootloaderVersion","topic":"","payload":"{\"name\":\"getBootloaderVersion\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":900,"y":900,"wires":[["54ede071.3b8cf"]]},{"id":"b5258077.6cd73","type":"inject","z":"f1f45be1.d6959","name":"getFanState","topic":"","payload":"{\"name\":\"getFanState\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":870,"y":1100,"wires":[["54ede071.3b8cf"]]},{"id":"132e6b20.9b96a5","type":"inject","z":"f1f45be1.d6959","name":"getFlapState","topic":"","payload":"{\"name\":\"getFlapState\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":870,"y":1140,"wires":[["54ede071.3b8cf"]]},{"id":"5baef116.ed3ee","type":"inject","z":"f1f45be1.d6959","name":"getTemperatures","topic":"","payload":"{\"name\":\"getTemperatures\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":880,"y":980,"wires":[["54ede071.3b8cf"]]},{"id":"5effa3a.8a2d0dc","type":"inject","z":"f1f45be1.d6959","name":"getFaults","topic":"","payload":"{\"name\":\"getFaults\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":860,"y":860,"wires":[["54ede071.3b8cf"]]},{"id":"aae17e5d.46ddf","type":"inject","z":"f1f45be1.d6959","name":"getOperatingHours","topic":"","payload":"{\"name\":\"getOperatingHours\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":890,"y":820,"wires":[["54ede071.3b8cf"]]},{"id":"46491ed2.d780b8","type":"inject","z":"f1f45be1.d6959","name":"setComfortTemperature 19.0","topic":"","payload":"{\"name\":\"setComfortTemperature\",\"params\":{\"temperature\":\"39.00\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":920,"y":1380,"wires":[["54ede071.3b8cf"]]},{"id":"8a902515.0df","type":"inject","z":"f1f45be1.d6959","name":"getVentilationLevel","topic":"","payload":"{\"name\":\"getVentilationLevel\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":890,"y":1060,"wires":[["54ede071.3b8cf"]]},{"id":"be4e2d5b.84dc4","type":"inject","z":"f1f45be1.d6959","name":"getFirmwareVersion","topic":"","payload":"{\"name\":\"getFirmwareVersion\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":890,"y":940,"wires":[["54ede071.3b8cf"]]},{"id":"eba5ab69.e9711","type":"inject","z":"f1f45be1.d6959","name":"Replace filters?","topic":"","payload":"{\"name\":\"getFaults\",\"params\":{}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1260,"y":1220,"wires":[["177ff10d.1d7577"]]},{"id":"177ff10d.1d7577","type":"comfoair","z":"f1f45be1.d6959","name":"ComfoAir","datasource":"6ded16c2.7801","x":1260,"y":1300,"wires":[["590dd614.abe82"]]},{"id":"590dd614.abe82","type":"switch","z":"f1f45be1.d6959","name":"","property":"payload.replaceFilter.value","propertyType":"msg","rules":[{"t":"true"},{"t":"false"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1390,"y":1300,"wires":[["a695a9be.9a2968"],["e60a1caf.794138"],[]],"outputLabels":["Replace or clean filters","Filters are ok","Unexpected results"]},{"id":"a695a9be.9a2968","type":"debug","z":"f1f45be1.d6959","name":"Warn user","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1550,"y":1260,"wires":[]},{"id":"e60a1caf.794138","type":"debug","z":"f1f45be1.d6959","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1550,"y":1300,"wires":[]},{"id":"6ded16c2.7801","type":"comfoair-connection","z":"","serialport":"/dev/ttyUSB1","serialbaud":"9600","reconnectTimeout":"5000"}]
Version: 0.0.9
Updated 3 years, 9 months ago
Rating: 5.0 2
17 in the last week
  • comfoair
  • comfoair-connection
  • zehnder
  • comfoair
  • ca350
  • storkair
  • wernig
  • santos
  • paul
