node-red-contrib-colorspace 1.0.2
Conver colors and colors temperature in NodeRed
npm install node-red-contrib-colorspace
Node-RED Node, that helps conver colors
node-red-contrib-colorspace imports into NodeRed the conversion from npm packages color-convert and color-temperature
Please note that color temperature is a extimation! It's very usefull to emulate color temperature in RGB lamps, but the values are not 100% accurate.
Just run
This node recives any of the supported color spaces (RGB, HSV, HEX, HSL, HWB, CMYK, ANSI, XYZ, LAB, LCH, Color Name, HCG, GARY, Color Temperature) and returns all of the other)
Return
   "rgb":{
      "red":140,
      "green":200,
      "blue":100
   "hsv":{
      "hue":96,
      "staturation":50,
      "brightness":78
   "hex":"8CC864",
   "hsl":{
      "hue":96,
      "staturation":48,
      "lightness":59
   "hwb":{
      "hue":96,
      "whiteness":39,
      "blackness":22
   "cmyk":{
      "cyan":30,
      "magenta":0,
      "yellow":50,
      "black":22
   "ansi16":93,
   "xyz":{
      "x":34,
      "y":48,
      "z":20
   "lab":{
      "longitude":75,
      "latitude":-37,
      "altitude":44
   "lch":{
      "lightness":75,
      "chroma":57,
      "hue":130
   "keyword":"darkseagreen",
   "hcg":{
      "hue":96,
      "chroma":39,
      "grayness":65
   "gray":[
      58
   "rgbi":9226340,
   "temperature":4429
How to use
You can send in the payload one of the types supported
You can send
RGB
    "payload":{
        "rgb": {
            "red": 255,
            "green": 10,
            "blue": 20
HSV
    "payload":{
        "hsv": {
            "hue": 358,
            "staturation": 96,
            "brightness": 100
HSL
    "payload":{
        "hsl": {
            "hue": 358,
            "staturation": 96,
            "lightness": 52
HWB
    "payload":{
        "hwb": {
            "hue": 358,
            "whiteness": 4,
            "blackness": 0
CMYK
    "payload":{
        "cmyk": {
            "cyan": 0,
            "magenta": 96,
            "yellow": 92,
            "black": 0
CMYK
    "payload":{
        "xyz": {
            "x": 41,
            "y": 22,
            "z": 3
HEX
    "payload":{
        "hex": "FF0A14"
Temperature
    "payload":{
        "temperatute": 5000
Keyword
    "payload":{
        "keyword": "red"
Direct Payload
    "payload": "red"
Direct Color Name in Payload
    "payload": "red"
Direct Color Temperature Name in Payload
    "payload": "daylight"
Version: 1.0.2
Updated 6 years, 1 month ago
Rating: 4.0 1
13 in the last week
  • node-red-contrib-colorspace
  • color
  • converter
  • nodered
  • temperature
  • yeelight
  • rgb
  • hsv
  • rgbi
  • kelvin
