node-red-contrib-coccozy 1.0.0
Node-RED node that always returns the string Coccozy (TP IoT)
npm install node-red-contrib-coccozy
Overview
This node is a node for forcibly converting all the alphabet character strings passed as input to the character string "Coccozy".
Even if the input parameter passed is not a character string, "Coccozy" is forcibly returned.
In this process, it is a node that changed the sample node that was executing toLowerCase, which is an instance method of String object in JavaScript, to a process that just returns a constant.
How to use
It is used when you want to forcibly convert all the character strings of the parameters to be passed to "Coccozy".
Flow example: inject -> coccozy -> debug
or from the Node-RED editor: Menu > Manage palette > Install > search node-red-contrib-coccozy.
Version: 1.0.0
Updated 4 days ago
  • coccozy
  • coccozy
