node-red-contrib-cluster-leader 1.0.0
Leader election node for Node-RED cluster deployments using Redis/Valkey
npm install node-red-contrib-cluster-leader
Leader election node for Node-RED cluster deployments using Redis/Valkey.
Overview
When running Node-RED in a clustered environment (multiple replicas), scheduled jobs (inject nodes with intervals/cron) will execute on all replicas simultaneously, causing duplicate execution. This node solves that problem by implementing distributed leader election.
  • ✅ Distributed Leader Election: Only ONE replica executes scheduled jobs
  • ✅ Automatic Failover: If leader dies, another replica becomes leader automatically
  • ✅ Real-time Status: Visual indicator shows leader/follower status
  • ✅ Multiple Lock Groups: Distribute different jobs across different leaders
  • ✅ Redis/Valkey Compatible: Works with both Redis and Valkey
  • ✅ Zero Configuration: Works out of the box with environment variables
In Node-RED Container
cd /data
# Restart Node-RED
Via Docker Volume
# On host machine
cd smartorchestra/node-red-contrib-cluster-leader
npm install
npm pack
# Copy to Node-RED data volume
docker cp node-red-contrib-cluster-leader-1.0.0.tgz <container>:/data/
docker exec <container> bash -c "cd /data && npm install node-red-contrib-cluster-leader-1.0.0.tgz"
docker restart <container>
Quick Start
1. Add Valkey Config Node (Optional)
If not using environment variables:
  • Add a new Valkey Config node
  • Set host, port, and database
  • Save configuration
2. Use Cluster Leader Node
[Inject: Every 1 min] → [Cluster Leader] → [Your Job]
                        (only leader executes)
3. Configure
  • Lock Key: nodered:leader (default) - use different keys for different jobs
  • Lock TTL: 10 seconds (default) - time before lock expires
Usage Examples
Example 1: Simple Scheduled Job
    "id": "inject1",
    "type": "inject",
    "repeat": "60",
    "name": "Every Minute",
    "wires": [["leader1"]]
    "id": "leader1",
    "type": "cluster-leader",
    "lockKey": "nodered:leader",
    "lockTTL": 10,
    "wires": [["job1"], []]
    "id": "job1",
    "type": "http request",
    "method": "POST",
    "url": "http://api/job",
    "wires": [[]]
Example 2: Multiple Jobs with Distributed Leadership
Job A (every 1 min):
[Inject] → [Leader: key="job-a"] → [HTTP Request A]
Job B (every 5 min):
[Inject] → [Leader: key="job-b"] → [HTTP Request B]
Job C (every 10 min):
[Inject] → [Leader: key="job-c"] → [HTTP Request C]
Result: Each job has a different leader, distributing load across the cluster.
Example 3: Follower Actions
[Inject] → [Cluster Leader]
           (leader)   (follower)
         [Execute]  [Log Skip]
Use output 2 to log or metric when a job is skipped on followers.
Environment Variables
If no Valkey Config node is specified, the plugin uses:
REDIS_HOST=redis       # Default: redis
REDIS_PORT=6379        # Default: 6379
HOSTNAME=<unique-id>   # Auto-detected
Lock Key Strategy
  • Single Leader: Use same lock key for all jobs → one leader for everything
  • Distributed Leadership: Use different lock keys → different leaders for different jobs
lockKey: "nodered:leader"        // All jobs share one leader
lockKey: "nodered:job-database"  // Database jobs have dedicated leader
lockKey: "nodered:job-api"       // API jobs have dedicated leader
Lock TTL (Time-To-Live)
  • Too Short (<5s): Frequent leadership changes, poor performance
  • Too Long (>60s): Slow failover if leader dies
  • Recommended: 10-30 seconds depending on job frequency
Architecture
How It Works
  1. Leader Election: Each replica tries to acquire a Redis lock with SET key value NX EX ttl
  2. Only One Wins: The replica that successfully sets the key becomes the leader
  3. Heartbeat: Leader refreshes the lock every 2 seconds
  4. Auto-Failover: If leader dies, lock expires after TTL, another replica becomes leader
Redis Commands Used
SET nodered:leader hostname NX EX 10  # Try to become leader
GET nodered:leader                     # Check current leader
EXPIRE nodered:leader 10               # Refresh leadership
DEL nodered:leader                     # Release leadership (on shutdown)
Troubleshooting
All Replicas Show "Follower"
Problem: No leader elected Solution:
  • Check Redis connectivity: docker exec <container> curl redis:6379
  • Verify lock key is the same across all replicas
  • Check Redis logs for errors
Multiple Leaders
Problem: More than one replica acts as leader Solution:
  • Ensure all replicas use the exact same lock key
  • Check for clock skew between nodes
  • Verify Redis is not partitioned
No Failover After Leader Dies
Problem: New leader not elected Solution:
  • Increase Lock TTL (e.g., 30 seconds)
  • Check network connectivity to Redis
  • Verify other replicas are healthy
High Redis Load
Problem: Too many Redis operations Solution:
  • Increase heartbeat interval (modify code)
  • Use separate Redis instance for leader election
  • Reduce number of leader nodes
Docker Swarm Example
docker-compose.swarm.yml
services:
  redis:
    image: valkey/valkey:8-alpine
    networks:
      - orchestra
  nodered-admin:
    image: nodered/node-red:4.1.0
    environment:
      - REDIS_HOST=redis
      - REDIS_PORT=6379
    volumes:
      - nodered_data:/data
    deploy:
      replicas: 1
  nodered-worker:
    environment:
      - REDIS_HOST=redis
      - REDIS_PORT=6379
    volumes:
      - nodered_data:/data:ro
    deploy:
      replicas: 3  # Multiple workers
Installation Script
#!/bin/bash
# Install plugin on all Node-RED instances
for service in nodered-admin nodered-worker; do
    echo "Installing on $service..."
    docker exec $(docker ps -q -f name=${service}) bash -c \
        "cd /data && npm install node-red-contrib-cluster-leader && pm2 restart all"
done
Development
Build
npm install
npm pack
Test Locally
# Terminal 1: Start Redis
docker run -d -p 6379:6379 valkey/valkey:8-alpine
# Terminal 2-4: Start 3 Node-RED instances
docker run -p 1880:1880 -e REDIS_HOST=localhost nodered/node-red
docker run -p 1881:1880 -e REDIS_HOST=localhost nodered/node-red
docker run -p 1882:1880 -e REDIS_HOST=localhost nodered/node-red
# Install plugin in each instance
# Test with scheduled flows
MIT
Contributing
Pull requests welcome! Please ensure:
  • Code follows existing style
  • Tests pass (if applicable)
  • Documentation is updated
Support
For issues and questions:
Changelog
1.0.0 (2025-01-30)
  • Initial release
  • Basic leader election with Redis/Valkey
  • Valkey config node
  • Status monitoring and heartbeat
  • Auto-failover on leader death
  • Multiple lock group support
Version: 1.0.0
Updated 1 year, 1 month ago
68 in the last week
  • cluster-leader
  • valkey-config
  • cluster
  • leader-election
  • redis
  • valkey
  • distributed
  • high-availability
