node-red-contrib-cloudantplus 2.0.6
A Node-RED node to access Cloudant and couchdb databases, supports views, query and bulk operations.
npm install node-red-contrib-cloudantplus
node-red-node-cf-cloudant
A set of Node-RED nodes to work with documents in a Cloudant database that is integrated with IBM Cloud or an on-premises CouchDB. This version is a superset of the functionality in the original Cloudant node and replicates the functionality of the node-red-contrib-cloudantplus node and will eventually replace it.
Ideally, install from the package manager inside Node-RED.
Alternatively, install from npm
npm install node-red-node-cf-cloudant
Allows access to a Cloudant or CouchDB database to insert, update, delete and search for documents. Also bulk operations are supported.
An additional node allows to retrieve information about server and databases
To insert a new document into the database you have the option to store the entire msg object or just the msg.payload. If the input value is not in JSON format, it will be transformed before being stored. If msg or msg.payload is an array, all elements will be processed using the bulk operations API.
For update and delete, you must pass the _id and the _revas part of the input msg.payload object. Bulk operations are also supported when putting documents as an array in the input msg.payload object.
To search for a document you have five options:
  • get a document directly by its _id
  • use query
  • use an existing search index from the database
  • use an existing view
  • retrieve all documents
Take note
  • When getting documents by id, the payload will be the desired _id value.
  • For query, the payload will be the set to an object with a declarative JSON query syntax.
  • For search indexes, the query should follow the format indexName:value.
  • For views and all docs, payload should be set be set to an object containing key/value pairs as defined in the Query string section in the Cloudant documentation
Dependencies
Authors
Based on the node written and enhanced by:
Version: 2.0.6
Updated 2 years, 3 months ago
Rating: 4.5 2
32 in the last week
  • cloudantplus
  • cloudantplus in
  • cloudantplus info
  • cloudantplus out
  • cloudant
  • couchdb
  • bluemix
  • ibm-cloud
  • Túlio Pascoal
  • Igor Leão
  • Luiz Gustavo Ferraz Aoqui
  • Austin Chang
  • Stephan H. Wissel
