node-red-contrib-clickhouse 1.1.0
A clickhouse node for Node-Red
npm install node-red-contrib-clickhouse
A Clickhouse driver node for Node-Red.
npm version install size npm downloads
Changelog
1.1.0
  • Configurable request timeout. Added a RequestTimeoutMS field to the ClickHouse config node so the per-query timeout can be tuned per connection. Default raised from the previous hard-coded 400000 ms to 600000 ms (10 minutes) to better cover long-running migrations and ETL jobs. 0 means wait forever (no socket timeout). Environment fallback: CLICKHOUSE_REQUEST_TIMEOUT_MS.
  • Backward compatible: existing config nodes without the new field fall back to the 10-minute default.
1.0.7
  • Previous release (see git history for details).
This package includes two nodes for node-red:
The Config Node
Connect to your local Clickhouse Server or a Cloud versions. client-node
The Flow Node
Execute an query/insert/command within your flow. flow-node
_This node was inspired by other projects like node-red-contrib-mongodb4
Navigate to your .node-red directory - typically ~/.node-red.
npm install --save --omit=dev node-red-contrib-clickhouse
Compatibility
The latest version of [email protected] is tested with the following Clickhouse server versions: 25.3.1
Node-RED >= v3.0.0
NodeJS >= v16.20.1
Usage Example
Import the example flow to get a quick introduction how to use this node.
flow.json
flow-image
The Configuration Node
Simple Connection URI
  • Protocol - http or https
  • Hostname - Hostname / IP to connect to Clickhouse
  • Port - Optional port number. In most cases 8123.
  • Pathname - Custom path name to add to URI. Details
Note: you can set all values in config node to environment variable using form ${CLICKHOUSE_HOST}. Nodered will convert that to your actual setting on startup.
Advanced Connection URI
  • URI - Define your own connection string in URI format.
Authentication (optional)
  • Username - Username for authentication. Also you can define username as environment CLICKHOUSE_USER (it override username value)
  • Password - Password for authentication. Also you can define password as environment CLICKHOUSE_PASSWORD (it override password value)
Application
  • Database - A Clickhouse database name is required.
  • Application Name - The name of the application that created this ClickHouse instance.
If this field is unspecified, the client node will create a app name for you. That looks like this: nodered-azmr5z97. The prefix nodered is static. azmr5z97 is a random connection pool id, created on runtime start-up, config-node update and full deployment.
The current app name of a config node is logged to the node-red runtime log.
Connect Options
  • MaxPoolsize - Specifies the maximum number of connections the driver should create in its connection pool. This count includes connections in use.
  • MaxIdleTimeMS - Specifies the amount of time, in milliseconds, a connection can be idle before it's closed. Specifying 0 means no minimum.
  • RequestTimeoutMS - Maximum time, in milliseconds, a single query is allowed to run before the client aborts the request. Default is 600000 (10 minutes) to cover long-running migrations / ETL jobs. Specifying 0 means wait forever (no socket timeout). Can be overridden per connection node; the environment fallback is CLICKHOUSE_REQUEST_TIMEOUT_MS.
Connection Pools
Each configuration node has his own connection pool with a default max poolsize of 100 connection at a given time.
The Flow Node
Execute clickhouse operations with this node.
Inputs / Options
  • Connection (clickhouse-client) - Select a Clickhouse server connection.
  • Mode | msg.mode (string) - Decide which operation do you want to use {'query', 'command', 'insert'}
  • Table | msg.table (string) - table name for insert operation.
  • Output | msg.output (string) - Define output processing for 'query' mode {'toArray', 'forEach'}.
    'forEach' produce output for each received record in stream manner and additional msg with an payload equal to null.
  • Format | msg.format (string) - format output. By default assigned 'JSONEachRow' value but you can define your own if needed.
  • msg.payload (array | JSON ) - Pass message payload as array for 'insert' mode. For 'query' mode it should be JSON object.
  • Wait for completion - With this feature enabled, the operation node will wait until execution were complete. See wait_end_of_query
  • Do not throw error (place it into msg) - With this feature enabled, the operation node will return error in msg insted of throwing it
Payload Output
The node will output the database driver response as message payload. The mode query can output with toArray or forEach.
Node Status
Node status information is displayed below the node:
  • s : Number of successful executions
  • err : Number of failed executions
  • rt : Last execution runtime in ms
Colors
  • green : Last execution was successful
  • blue : Node execution in progress
  • red : Last execution failed
More general driver information
Visit the Clickhouse Driver Docs
Version: 1.1.0
Updated 2 months, 2 weeks ago
15 in the last week
  • clickhouse-client
  • clickhouse
  • nodes
  • clickhouse
  • db
