node-red-contrib-claude 1.1.0
A Node-RED node to interact with the Anthropic Claude API
npm install node-red-contrib-claude
A Node-RED node for interacting with the Anthropic Claude API.
Requirements
From npm (once published):
From source (local development):
npm install /path/to/node-red-contrib-claude
Then restart Node-RED. The claude node will appear in the AI category of the palette.
Open the node's properties panel and enter your Anthropic API key. All other fields are optional defaults that can be overridden per-message at runtime.
Property Default Description
API Key — Your Anthropic API key (sk-ant-…)
Model claude-sonnet-4-6 Claude model ID
Max Tokens 1024 Maximum tokens to generate
System Prompt (none) System prompt sent with every message
Temperature (model default) Sampling temperature (0–1)
Top P (model default) Nucleus sampling (0–1)
Top K (model default) Top-k sampling (integer ≥ 1)
Input
Property Type Required Description
msg.payload string Yes The prompt / query text sent to Claude
msg.model string No Override the model for this message
msg.maxTokens number No Override max tokens for this message
msg.systemPrompt string No Override the system prompt for this message
msg.temperature number No Override temperature for this message
msg.topP number No Override top-p for this message
msg.topK number No Override top-k for this message
Non-string payloads are automatically serialized to JSON before being sent.
Output (success)
Property Type Description
msg.payload string The text response from Claude
msg.claudeRaw object Full API response (usage stats, stop reason, etc.)
Output (API error)
msg.payload null
msg.claudeError object { status: <HTTP code>, message: "" }
The node still forwards the message downstream on API errors so flows can handle them explicitly.
Node status indicators
Color Text Meaning
Blue Thinking… Waiting for API response
Green OK Request succeeded
Red error <code> API returned a non-200 status
Red missing payload msg.payload was empty
Red no API key API key not configured
Red request failed Network/connection error
Example Flows
Import examples/flows.json via Menu → Import in the Node-RED editor. It contains four ready-to-use flows:
Tab What it shows
1 - Basic Q&A Inject a question → claude → debug. The simplest possible usage.
2 - System Prompt System prompt set in the node config so Claude always responds as a Python tutor.
3 - Runtime Overrides A function node sets msg.model, msg.systemPrompt, and msg.maxTokens before calling the claude node, overriding the node config per-message.
4 - Error Handling A switch node branches on msg.claudeError (null = success, non-null = API error) so failures are handled explicitly.
After importing, open each claude node and enter your Anthropic API key before deploying.
Project Structure
claude.js    — Node-RED runtime (registers node type, handles API calls)
claude.html  — Node-RED editor UI and help panel
package.json — Package manifest and node-red node registration
MIT © Paramesh Gunasekaran
Version: 1.1.0
Updated 8 months ago
83 in the last week
  • claude
  • claude
  • anthropic
  • ai
  • llm
