node-red-contrib-clamp 1.0.0
Node-RED clamp node - limits values to a min/max range
npm install node-red-contrib-clamp
Node-RED Clamp Node - limits values to a min/max range.
  • Limits values to configured min/max range
  • Values below min are clipped to min
  • Values above max are clipped to max
  • Runtime overrides via msg properties
  • Configurable decimal places (0-10)
Behavior
  • Input < min → Output = min
  • Input > max → Output = max
  • Input in range → Output = input unchanged
Examples
min=0, max=100:
Input 120  → Output 100 (clamped)
Input -5   → Output 0   (clamped)
Input 42   → Output 42  (passthrough)
min=-10, max=10:
Input 15   → Output 10  (clamped)
Input -15  → Output -10 (clamped)
Input 0    → Output 0   (passthrough)
Property Description Default
Min Lower bound 0
Max Upper bound 100
Decimals Number of decimal places 2
Input
  • msg.payload - Numeric value to clamp
Runtime Overrides
msg.min Override minimum
msg.max Override maximum
Output
  "payload": 100,
  "clamp": {
    "input": 120,
    "output": 100,
    "min": 0,
    "max": 100,
    "clamped": true,
    "clampedAt": "max"
Use Cases
Application Description
Sensor Limit sensor readings to valid range
Control Constrain output to safe limits
UI Ensure slider values stay within bounds
Safety Prevent out-of-range values
Node Status
  • 42 (in range) - Value passed through
  • 100 (clamped, was 120) - Value was clamped at max
  • 0 (clamped, was -5) - Value was clamped at min
  • Invalid range - min >= max
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
133 in the last week
  • clamp
  • clamp
  • limit
  • range
  • min
  • max
  • constrain
