node-red-contrib-clab-interfaces 0.0.1
Node-RED nodes for CompuLab IoT Gateway interfaces (IOT-GATE-iMX8, SBC-IOT-iMX8, IOT-GATE-RPi)
npm install node-red-contrib-clab-interfaces
Node-RED nodes for CompuLab IoT Gateway hardware interfaces.
Node-RED License
Note: This is an independent open-source project and is not affiliated with, endorsed by, or sponsored by CompuLab Ltd.
Overview
This package provides Node-RED nodes to interact with the hardware interfaces of CompuLab IoT Gateways, including:
  • IOT-GATE-iMX8 / SBC-IOT-iMX8
  • IOT-GATE-IMX8PLUS / IOT-DIN-IMX8PLUS
  • IOT-LINK
  • IOT-GATE-RPi
Category Node Description
GPIO clab-gpio-in Digital input (read GPIO pins)
clab-gpio-out Digital output (set GPIO pins)
Serial clab-serial-in Serial/RS485 receive
clab-serial-out Serial/RS485 transmit
CAN Bus clab-can-in CAN bus receive
clab-can-out CAN bus transmit
Analog clab-analog-in Analog input (4-20mA, 0-10V, PT100/PT1000)
LED clab-led User LED control (on/off/blink)
System clab-system System info, RTC, Watchdog, TPM, Power
Bluetooth clab-bluetooth BT adapter control, scan, connect
GPS clab-gps Position, satellites, distance calculation
Cellular clab-cellular LTE modem info, connect, signal strength
WiFi clab-wifi WiFi status, scan, connect, access point
Ethernet clab-ethernet Interface status, DHCP/static IP config
Network clab-network Ping, DNS, traceroute, port check, HTTP check
Multiple Add-on Modules Support
CompuLab IoT Gateways support multiple stackable I/O add-on modules, allowing massive expansion of your gateway capabilities.
IOT-DIN-IMX8PLUS - Up to 8 Stackable Modules
The IOT-DIN-IMX8PLUS supports stacking up to 8 I/O expansion modules in positions A through H:
Module Type Max Stack Description Device Index Range
IFM-RS485 3 modules 4x RS485 ports each Up to 12 RS485 ports (3×4)
IFM-RS232 3 modules 4x RS232 ports each Up to 12 RS232 ports (3×4)
IFM-DI8O8 8 modules 8 DI + 8 DO each Up to 64 DI + 64 DO (8×8+8)
IFM-ADC8 8 modules 8x analog inputs each Up to 64 analog channels (8×8)
IFM-WB 1 module WiFi 6E + BT 5.3 Single module only
IFM-MESH 3 modules BT Mesh/Thread/Zigbee Up to 3 mesh modules
IFM-NVME 1 module NVMe SSD storage Position A only
Stacking Rules:
  • Maximum 8 modules total (positions A-H)
  • RS485/RS232/MESH: maximum 3 combined
  • IFM-NVME: must be in position A
  • Automatic detection and configuration
Other CompuLab Devices
Device Base I/O Add-on Support
IOT-GATE-iMX8/IMX8PLUS 4 DI + Backpanel RS485/RS232 2 Add-on modules
IOT-LINK 2x RS485 (FARS4/FBRS4) 3 DIO base
IOT-GATE-RPi 4x RS485 ports 8 IN/OUT
How to Use Multiple Modules
Serial Ports - Up to 12 RS485 or RS232 Interfaces
Each serial port requires its own configuration node. With 3× IFM-RS485 modules:
// Module A (Position A) - 4 ports
Serial Config 1: /dev/ttyLP6  (or device-specific path)
Serial Config 2: /dev/ttyLP7
Serial Config 3: /dev/ttyLP8
Serial Config 4: /dev/ttyLP9
// Module B (Position B) - 4 ports
Serial Config 5: /dev/ttyLP10
Serial Config 6: /dev/ttyLP11
// ... up to 12 RS485 ports total
Analog Inputs - Up to 64 Channels (8 Modules × 8 Channels)
Use msg.deviceIndex and msg.channelIndex to access different modules:
// Module A, Channel 0-7
msg.deviceIndex = 0;
msg.channelIndex = 0; // to 7
// Module B, Channel 0-7
msg.deviceIndex = 1;
// Module C, Channel 0-7
msg.deviceIndex = 2;
// ... up to deviceIndex 7 (Module H)
Example: Scanning all 64 analog channels
// Flow context to track current position
var deviceIndex = context.get('deviceIndex') || 0;
var channelIndex = context.get('channelIndex') || 0;
// Set current channel
msg.deviceIndex = deviceIndex;
msg.channelIndex = channelIndex;
// Move to next channel
channelIndex++;
if (channelIndex >= 8) {
    channelIndex = 0;
    deviceIndex++;
    if (deviceIndex >= 8) {
        deviceIndex = 0; // Start over
context.set('deviceIndex', deviceIndex);
context.set('channelIndex', channelIndex);
Digital I/O - Up to 64 Inputs + 64 Outputs
With 8× IFM-DI8O8 modules, you can have massive I/O capacity:
// Module A: DI0-DI7, DO0-DO7
msg.pin = "DI0"; // First module, first input
// Module B: DI8-DI15, DO8-DO15
msg.pin = "DI8"; // Second module, first input
// ... up to DI63, DO63
CAN Bus - Multiple CAN Interfaces
Create separate configuration nodes for each CAN interface:
// CAN Config 1: can0 @ 500 kbit/s
// CAN Config 2: can1 @ 250 kbit/s
Real-World Use Case: Industrial Monitoring System
Example configuration with IOT-DIN-IMX8PLUS + 8× IFM-ADC8 + 3× IFM-RS485:
// Monitor 64 temperature sensors (PT100)
// via 8 ADC modules + Log data via 12 RS485
// PLCs distributed across factory floor
// Flow 1: Read all 64 temperature sensors
var device = flow.get('currentDevice') || 0;
var channel = flow.get('currentChannel') || 0;
msg.deviceIndex = device;    // Module A-H (0-7)
msg.channelIndex = channel;  // Channel 0-7
// Round-robin through all channels
channel++;
if (channel >= 8) {
    channel = 0;
    device = (device + 1) % 8;
flow.set('currentDevice', device);
flow.set('currentChannel', channel);
// Flow 2: Send aggregated data to PLCs
// Each RS485 port connected to different PLC
// Port mapping handled by 12 separate serial-out nodes
msg.topic = `sensor_${device}_${channel}`;
msg.payload = {
    temperature: msg.payload,
Dynamic Module Selection via msg Properties
All nodes support dynamic configuration through message properties:
// Example: Switch between different analog channels
var channels = [0, 1, 2, 3, 4, 5, 6, 7];
var currentChannel = context.get('currentChannel') || 0;
msg.channelIndex = channels[currentChannel];
currentChannel = (currentChannel + 1) % channels.length;
context.set('currentChannel', currentChannel);
Via Node-RED Palette Manager
  1. Open Node-RED
  2. Go to Menu → Manage Palette → Install
  3. Search for node-red-contrib-clab-interfaces
  4. Click Install
Via npm
Via Docker
Use the provided Docker Compose setup:
git clone https://github.com/YOUR_USERNAME/node-red-contrib-clab-interfaces.git
cd node-red-contrib-clab-interfaces
docker-compose up -d
Quick Start
GPIO Example
        "id": "gpio-in-example",
        "type": "clab-gpio-in",
        "name": "Button Input",
        "device": "IOT-GATE-iMX8",
        "pin": "DI0",
        "interval": 1000
Serial RS485 Example
        "id": "serial-out-example",
        "type": "clab-serial-out",
        "name": "Modbus TX",
        "port": "/dev/ttymxc2",
        "baudRate": 9600
Node Documentation
clab-gpio-in / clab-gpio-out
Digital I/O for CompuLab devices.
Supported Devices:
  • IOT-GATE-iMX8: DI0-DI3, DO0-DO3
  • IOT-GATE-RPi: GPIO pins via gpiochip0
  • IOT-LINK: DI0-DI7, DO0-DO7
Input Properties:
  • device - Target device type
  • pin - GPIO pin name
  • interval - Polling interval (ms)
clab-serial-in / clab-serial-out
RS232/RS485 serial communication.
Configuration:
  • port - Serial device path
  • baudRate - Baud rate (9600, 19200, 38400, 57600, 115200)
  • dataBits - Data bits (7, 8)
  • stopBits - Stop bits (1, 2)
  • parity - Parity (none, even, odd)
clab-analog-in
Analog input for industrial sensors.
Input Types:
  • current - 4-20mA current loop
  • voltage - 0-10V or 0-5V voltage input
  • temperature - PT100/PT1000 RTD sensors
Output:
Field Type Description
payload number Measured value (scaled if enabled)
raw number Raw ADC value (e.g. 0-4095 for 12-bit)
percent number Value as percentage (0-100%)
valid boolean True if within expected range
unit string Unit of the value
currentMA number Current in mA (current type only)
voltage number Voltage in V (voltage type only)
celsius number Temperature in °C (temperature type only)
Scaling Example:
A pressure sensor with 4-20mA output representing 0-10 bar:
  • Input Type: 4-20mA Current
  • Enable Scaling: ✓
  • Min: 0, Max: 10, Unit: bar
Output:
  "payload": 5.5,
  "raw": 2048,
  "currentMA": 12.8,
  "percent": 55,
  "scaled": 5.5,
  "unit": "bar",
  "valid": true
clab-can-in / clab-can-out
CAN bus communication.
Configuration:
  • interface - CAN interface (can0, can1)
  • bitrate - CAN bitrate (125000, 250000, 500000, 1000000)
clab-system
System functions with action selector:
Action Description
info System information (hostname, kernel, CPU, memory)
uptime System uptime
temperature CPU temperature
rtc-read Read hardware clock
rtc-set Set hardware clock
rtc-sync Sync RTC to system time
watchdog-status Watchdog status
watchdog-enable Enable watchdog
watchdog-disable Disable watchdog
watchdog-kick Reset watchdog timer
tpm-status TPM availability
tpm-random Generate random bytes via TPM
reboot System reboot
shutdown System shutdown
clab-bluetooth
Bluetooth control with action selector:
Action Description
status Adapter info
enable Enable Bluetooth
disable Disable Bluetooth
scan Scan for devices
devices List known devices
connect Connect to device
disconnect Disconnect from device
remove Remove paired device
clab-gps
GPS functions:
Action Description
position Current position (lat, lon, alt, speed)
satellites Satellite information
distance Calculate distance between two points
start-gpsd Start gpsd daemon
stop-gpsd Stop gpsd daemon
clab-cellular
LTE/4G modem control:
Action Description
status Connection status
info Modem information (manufacturer, model, IMEI)
sim SIM card info (IMSI, ICCID)
signal Signal strength (RSRP, RSRQ, quality %)
connect Connect to network
enable Enable modem
disable Disable modem
reset Reset modem
at-command Send AT command
clab-wifi
WiFi control:
Action Description
status WiFi status
enable Enable WiFi
disable Disable WiFi
scan Scan for networks
saved List saved connections
delete Delete saved connection
ap-start Start access point
ap-stop Stop access point
clab-ethernet
Ethernet configuration:
Action Description
status Interface status (IP, MAC, speed)
interfaces List all interfaces
statistics RX/TX statistics
enable Enable interface
disable Disable interface
dhcp Enable DHCP
static Set static IP
clab-network
Network diagnostics:
Action Description
ping Ping host
dns DNS lookup
reverse-dns Reverse DNS lookup
traceroute Trace route to host
port-check Check TCP port
http-check Check HTTP/HTTPS URL
routes Show routing table
arp Show ARP table
speed-test Simple download speed test
Device Compatibility
Feature IOT-GATE-iMX8 IOT-GATE-RPi IOT-LINK IOT-DIN-IMX8PLUS
GPIO
Serial RS232/485
CAN Bus
Analog 4-20mA
User LED
RTC
Watchdog
TPM
Bluetooth
GPS
LTE Modem
WiFi
Docker Setup
Uses the official Node-RED container with hardware mounts:
version: '3.8'
services:
  node-red:
    image: nodered/node-red:latest
    container_name: node-red-clab
    ports:
      - "1880:1880"
    volumes:
      - node-red-data:/data
      - ./:/data/node_modules/node-red-contrib-clab-interfaces:ro
      - /dev:/dev
      - /sys:/sys:ro
    privileged: true
    group_add:
      - dialout
      - gpio
Start:
Install package in container:
docker exec -it node-red-clab npm install node-red-contrib-clab-interfaces
docker restart node-red-clab
Access: http://localhost:1880
Example Flows
Mount the demo flow to get started quickly:
volumes:
  - ./examples/compulab-demo-flow.json:/data/flows.json:ro
Or import manually in Node-RED: Menu → Import → Select examples/compulab-demo-flow.json
See examples/README.md for details.
Docker Networking Considerations
For full hardware access (especially network interfaces like Ethernet, WiFi, Bluetooth), consider using host network mode:
network_mode: host
Quick Start for WiFi:
Detailed documentation:
Development
Prerequisites
  • Node.js >= 14.0.0
  • Node-RED >= 2.0.0
Setup
npm install
Testing
npm test
Project Structure
node-red-contrib-clab-interfaces/
├── nodes/              # Node-RED node definitions
│   ├── clab-gpio.js
│   ├── clab-gpio.html
│   ├── clab-serial.js
│   └── icons/
│       └── clab.svg
├── lib/                # Helper libraries
│   ├── gpio-helper.js
│   ├── serial-helper.js
│   ├── can-helper.js
│   ├── system-helper.js
│   ├── bluetooth-helper.js
│   ├── gps-helper.js
│   ├── cellular-helper.js
│   ├── wifi-helper.js
│   ├── ethernet-helper.js
│   ├── network-helper.js
│   └── analog-helper.js
├── test/               # Unit tests
├── examples/           # Example flows
├── docker-compose.yml
├── Dockerfile
└── package.json
API Reference
See API.md for detailed API documentation.
Contributing
  1. Fork the repository
  2. Create a feature branch (git checkout -b feature/amazing-feature)
  3. Commit your changes (git commit -m 'Add amazing feature')
  4. Push to the branch (git push origin feature/amazing-feature)
  5. Open a Pull Request
MIT License - see LICENSE for details.
Resources
Disclaimer
This project is not affiliated with, endorsed by, or sponsored by CompuLab Ltd. CompuLab and related product names are trademarks of CompuLab Ltd.
Support
For issues and feature requests, please use the GitHub Issues page.
Version: 0.0.1
Updated 7 months, 3 weeks ago
35 in the last week
  • clab-gpio-in
  • clab-gpio-out
  • clab-gpio-read-all
  • clab-serial-config
  • clab-serial-in
  • clab-serial-out
  • clab-uart-mode
  • clab-uart-mode
  • clab-can-config
  • clab-can-in
  • clab-can-out
  • clab-analog-in
  • clab-analog-devices
  • clab-led
  • clab-system
  • clab-bluetooth
  • clab-gps
  • clab-cellular
  • clab-wifi
  • clab-wifi-config
  • clab-ethernet
  • clab-network
  • compulab
  • iot-gateway
  • imx8
  • gpio
  • can
  • rs485
  • rs232
  • industrial
  • bluetooth
  • gps
  • lte
  • cellular
  • wifi
