node-red-contrib-cistern 1.1.0
A collection of node-red nodes for cisterns.
npm install node-red-contrib-cistern
This package contains node-red nodes for usage with cisterns. Best for usage with an ultrasound module like the HC-SR04.
Node - Outlier
A node that removes/gets outliers of incoming values, specified by numberOfSamples or directly by an array.
Input mode
  • Batch - samples: Evaluates input once the amount of input values are equal to the given numberOfSamples. Afterwards the node awaits again numberOfSamples or an array.
  • Array: Evaluates the incoming array and ignores numberOfSamples.
Outlier mode
Outliers are values outside of 1.5 times the interquartile range. https://mathworld.wolfram.com/Outlier.html)
  • Remove: Outliers are removed and not passed on.
  • Get: Outliers only are passed on.
Output mode
  • Median: Median value of the remaining values is given as output: (1 1 2 8) -> 3
  • Mean: Mean value of remaining values: (1 1 2 8) -> 1.5
  • Mode: Mode value of remaining values: (1 1 2 8) -> 1
  • Array: The filtered values are passed on.
Max interquartile range
Maximum range between 1st quartile and 3rd quartile to be allowed for a valid output. In case the range is wider than defined here: No output is passed on.
Node - Cistern
A node for easy calculation of liters and percentage in a cylindrical cistern.
  • Radius: radius of the cylindrical cistern.
  • Input: measured distance from top to water level.
  • maxDistance: distance from top to bottom of the cistern.
  • minDistance: distance from top to max water level.
Version: 1.1.0
Updated 3 years, 9 months ago
4 in the last week
  • outlier
  • cistern
  • cistern
  • outlier
