node-red-contrib-cip-suite 0.2.2
Comprehensive Node-RED nodes for Allen-Bradley and CIP-capable devices via EtherNet/IP — ControlLogix, CompactLogix, Micro800, SLC500, MicroLogix, PLC-5, and third-party CIP devices
npm install node-red-contrib-cip-suite
Sponsor
Comprehensive Node-RED nodes for Allen-Bradley and CIP-capable devices via EtherNet/IP. Covers the full spectrum from modern ControlLogix to legacy SLC500/PLC-5, plus advanced CIP objects for motion, energy, time sync, security, and more.
Supported Hardware
Platform Protocol Notes
ControlLogix (L6x, L7x, L8x) CIP Symbolic Slot-based backplane routing
CompactLogix (L1x, L2x, L3x) CIP Symbolic Typically slot 0
Micro800 (Micro820/850/870) CIP Symbolic No backplane — enable Micro800 mode
SLC 500 PCCC over CIP File-based addressing (N7:0, F8:0)
MicroLogix (1100/1400) PCCC over CIP File-based addressing
PLC-5 PCCC over CIP File-based addressing
Third-party CIP devices CIP Raw Any EtherNet/IP device with CIP objects
Or search for node-red-contrib-cip-suite in the Node-RED Palette Manager.
Node Overview
All nodes appear under the CIP Suite category with a grey CIP icon.
Core CIP Nodes
Node Type Description
cip-endpoint Config Shared TCP session to a Logix PLC. Auto-reconnect, Micro800 support, multi-hop routing.
cip-read In/Out Read tag values. Supports bit access (Tag.5), array elements (Tag[3]), array ranges (Tag[0..9]), UDT/structures, batch reads, and polling.
cip-write In/Out Write tag values. Supports bit-level writes (atomic via CIP 0x4E or software RMW), arrays, UDT partial merge, text to STRING tags, batch writes.
cip-browse In/Out Discover tags on the PLC. Glob/regex filtering, UDT detection, program-scoped tags.
cip-subscribe Out Continuous cyclic multi-tag scanning via readTagGroup(). Deadband filtering, report-by-exception, runtime reconfiguration.
cip-controller In/Out Read controller identity, mode, fault status, keyswitch, tag count. Read-only: no mode change or fault reset.
cip-raw In/Out Send raw CIP service requests. Supports Multiple Service Packet (0x0A). Full response parsing with human-readable status codes.
cip-discover In/Out UDP broadcast ListIdentity for network device discovery. Standalone — no endpoint required.
Legacy PCCC Nodes (SLC500 / MicroLogix / PLC-5)
cip-pccc-endpoint Config Raw TCP session with EtherNet/IP + PCCC encapsulation. Transaction-based request/response matching.
cip-pccc-read In/Out Read PCCC addresses: N7:0, F8:0, B3:0/5, T4:0.ACC, S:1/5. Multi-element reads, polling.
cip-pccc-write In/Out Write PCCC addresses with bit-level read-modify-write support.
Advanced CIP Object Nodes
Node CIP Class Description
cip-io-scanner Class 1 Implicit I/O via ForwardOpen + UDP. Cyclic data exchange with remote I/O, drives, servos.
cip-security 0x5D CIP Security Object — TLS/DTLS status and security profile reading.
cip-sync 0x43 IEEE 1588 PTP time synchronization — grandmaster discovery, offset monitoring, PTP enable/disable.
cip-motion 0x42 Motion Axis Object — jog, moveAbsolute/Relative, home, stop, enable/disable, gear ratio, axis status polling.
cip-energy 0x4F/0x4E Energy Object — power/energy monitoring, electrical measurements (V/A/Hz/PF/THD), energy mode control.
cip-file 0x37 File Object — firmware upload/download with fragmented transfer, file directory listing, metadata access.
cip-param 0x0F Parameter Object — device parameterization, discovery scan, read/write with scaling support.
Tag Addressing
CIP Symbolic (Logix)
Format Example Description
Simple MyTag Read/write a tag
Bit access MyDint.5 Read/write bit 5 of a DINT
Array element MyArray[3] Single array element
Array range MyArray[0..9] Read elements 0-9 via fragmented read
Nested array range MyStruct.Member[0..101] Read a range of a UDT member array
UDT member MyUDT.MemberName Read/write a single structure member
Whole UDT/STRUCT MyUDT Full structure as an object (needs tag list)
STRING MyString, MyUDT.Name Text, as a tag or as a UDT member (needs tag list). Text longer than the string fails the write
Array of UDTs MyUDT where MyUDT : MyType[5] One object per element
Program-scoped Program:MainProgram.MyTag Tag inside a program
Batch msg.tags = ["Tag1","Tag2"] Multi-tag read via TagGroup
Tag paths are matched case-insensitively, the way Logix itself treats them — fis_stn[0].local and FIS_Stn[0].Local address the same tag and both decode into an object.
On cip-read, the Data Type field controls decoding: Auto-detect returns scalars natively and expands whole arrays and UDT/STRUCT tags when the endpoint's tag list is available; ARRAY forces a full array read; STRUCT forces UDT decoding. Auto-detect of full arrays and structures requires the tag list, which ControlLogix/CompactLogix provide on connect.
Array lengths are resolved in this order, and memoised until the connection is re-established, so a polled array costs one request per poll:
  1. msg.arraySize, if you set it.
  2. The UDT template, for a member array such as MyStruct.Member — the controller sends the element count with the tag list.
  3. Symbol Object attribute 8 (array dimensions), for controller- and program-scoped array tags, whose length the tag list does not carry. One request, exact answer.
  4. A bisecting index probe (~2·log2 n requests), if a controller does not answer attribute 8.
PCCC (SLC/MLX/PLC-5)
Integer N7:0 Integer file 7, element 0
Float F8:5 Float file 8, element 5
Bit B3:0/5 Bit file 3, element 0, bit 5
Timer T4:0 Full timer (CTL/PRE/ACC)
Timer sub-element T4:0.ACC Timer accumulator only
Counter C5:0.ACC Counter accumulator
Output/Input O:0/3, I:1/0 I/O with bit access
Status S:1/5 Status file with bit
String ST9:0 String file
Long L10:0 Long integer file
cip-endpoint
Setting Default Description
IP Address — PLC IP address
Port 44818 EtherNet/IP port
Slot 0 Backplane slot (ControlLogix)
Timeout (ms) 5000 Connection timeout
Retry (ms) 5000 Reconnection interval, doubling up to Max retry
Max retry (ms) 60000 Backoff ceiling. Set equal to Retry for a flat interval
Keepalive (ms) 30000 Identity reads that hold an idle session open. 0 disables
Auto connect on Off leaves the session idle until a connect action arrives
Dynamic Control off Opt in to runtime control via msg.action / msg.endpoint
Micro800 off Enable for Micro800 (skips ForwardOpen, uses UCMM)
Routing Path — Multi-hop routing (e.g. 1/0/2/192.168.1.1)
Port is informational. EtherNet/IP is always contacted on 44818.
cip-pccc-endpoint
Timeout (ms) 5000 Connection/request timeout
cip-io-scanner
Target IP — I/O adapter / drive IP address
RPI (ms) 100 Requested Packet Interval (cyclic rate)
Input/Output Assembly 100 / 150 Assembly instance numbers (see device EDS)
Config Assembly 0 Optional config assembly instance
Input/Output Size 32 Assembly data size in bytes. Do not count the Run/Idle header or the 16-bit sequence count — the node adds both to the negotiated connection size
UDP Port 2222 Local UDP port for implicit I/O
32-bit Run/Idle header on Prepend the Run/Idle header on O→T. Required by the ODVA AC/DC drive profile — leave on for PowerFlex drives, or they stay idle and ignore the output assembly
Electronic keying off Add an Electronic Key segment to the connection path. Off = no key ("don't check identity"), the most compatible choice. Enable only if a strict target rejects an unkeyed connection, then fill in Vendor ID / Device Type / Product Code / Major+Minor revision (from the device EDS). The compatibility bit accepts compatible revisions instead of an exact match
The produced/consumed assemblies are addressed with Connection Point path segments and the connection is opened with the transport direction set to Server (0x81) — both required by stricter drive firmware such as the PowerFlex 525.
When a target refuses the connection, the node reports both status words, for example:
ForwardOpen refused by target: CIP status 0x01 (Connection failure),
extended 0x012a (Invalid Originator→Target application path)
The general status of a refused I/O connection is nearly always 0x01 "connection failure" and says nothing useful — the extended status is the one that names the parameter the target objected to. The common ones:
Extended Meaning Usually means
0x0103 Transport class and trigger combination not supported Target wants a different transport byte
0x0106 Ownership conflict Another scanner (often a PLC) already owns the connection point
0x0110 Target application not configured for this connection Wrong assembly instance, or the device needs configuring first
0x0111 RPI not supported Requested RPI outside the device's range
0x0114–0x0116 Electronic key mismatch Vendor / device type / revision in the key does not match
0x0127 / 0x0128 Invalid O→T / T→O connection size Input or Output Size wrong — enter the assembly size from the EDS only; the node adds the sequence count (2 bytes) and the Run/Idle header (4 bytes, O→T) itself
0x012a / 0x012b Invalid O→T / T→O application path Wrong Output or Input assembly instance
Drive Control (PowerFlex 525)
A PowerFlex 525 is controlled with implicit (Class 1) messaging via cip-io-scanner — not with the tag nodes (it has no Logix tags). The drive's native assembly instances (verified against a working PLC→PF525 capture) are:
Setting Value
Output Assembly / Size 2 / 4 (Logic Command word + Speed Reference word)
Input Assembly / Size 1 / 8 (Logic Status word + Speed Feedback + datalinks)
Config Assembly 6
RPI 100 ms (the PLC requests 0 and the drive negotiates ~98 ms)
Electronic keying off (enable only if the drive refuses the unkeyed connection)
These native instances (Output 2 / Input 1 / Config 6) differ from the generic ODVA AC-drive assemblies (20/70). Send the 4 output bytes as a Buffer in msg.payload (bytes 0-1 = Logic Command, bytes 2-3 = Speed Reference, little-endian). Toggle the drive between Run and Idle with msg.command:"run"/"idle" (or msg.run:true/false).
Device parameters (read/write) use explicit messaging via cip-param (Parameter Object 0x0F), not cip-write. Confirm the exact assembly numbers, Logic Command bit map, and Speed Reference scaling against PowerFlex publication 520-UM001 — they differ between the ODVA AC-drive assemblies (20/70) and the PowerFlex-native ones.
Connection Management
  • Drop detection — an unexpected socket loss is noticed and retried, rather than leaving the endpoint reporting connected forever
  • Auto-reconnect with exponential backoff and jitter, so a rack of nodes on one PLC does not retry in lockstep
  • Keepalive — periodic Identity reads hold an idle session open (a Micro850 closes one after 120 s)
  • Connection metrics — response times, error counts, uptime tracking
  • Micro800 mode — bypasses UnconnectedSend, uses direct UCMM messaging
  • Multi-hop routing — reach PLCs behind ControlLogix backplanes
Dynamic Connection Control
Opt in per endpoint with the Dynamic Control checkbox, then cip-read, cip-write, cip-browse, cip-raw, cip-controller and cip-subscribe accept msg.action and msg.endpoint, following the pattern the core MQTT nodes use. While the checkbox is off, both properties are ignored entirely, so existing flows are unaffected.
A message carrying msg.action performs that action and does no PLC I/O.
msg.action Effect Re-points the node
switch Re-points the receiving node at another endpoint yes
connect Connects. Already connected with no override is a no-op success yes
reconnect Forces a disconnect then connect, and refreshes the tag list yes
disconnect Disconnects and stops retrying until told otherwise no
status Emits connection state and metrics on the output no
(none) The node's normal read or write no
msg.endpoint is the id or the configured Name of a deployed cip-endpoint. A bare reference borrows that endpoint for one message and leaves the node where it was; use switch to move a node for good. cip-subscribe is the exception — it holds a scan loop rather than answering one message at a time, so it requires switch.
// Read a tag from a different PLC, this message only
msg = { endpoint: "PLC2", tagName: "Line1.Speed" };
// Move this node to another PLC for good
msg = { action: "switch", endpoint: "PLC2" };
// Report on PLC3 without moving
msg = { action: "status", endpoint: "PLC3" };
// Re-address the shared config node and reconnect (affects every node using it)
msg = { action: "connect", endpoint: { target: "config", address: "10.0.0.5", force: true } };
switch affects one node. A settings object with target: "config" changes the shared config node, so it affects every node using that endpoint. Settings overrides apply only to connect, since connecting is the only moment new settings take effect, and are refused on a live connection unless you add force: true. Runtime changes are not saved — a full deploy restores whatever is configured in the editor.
Output messages carry msg.endpoint naming the PLC that answered, so piping a read into a write keeps both halves on the same controller.
Backpressure Protection
All nodes skip subsequent requests while a previous one is in-flight, preventing PLC overload.
Atomic Bit Operations
Write nodes support CIP Read-Modify-Write service (0x4E) for safe bit manipulation without race conditions.
Admin HTTP Endpoints
  • GET /cip-endpoint/:id/browse — browse tags from a deployed endpoint
  • GET /cip-endpoint/:id/metrics — connection statistics (response times, error counts, uptime)
Both require the cip-endpoint.read permission where adminAuth is configured.
Status Indicators
Color Shape Meaning
Green dot Connected / OK
Yellow ring Connecting / warning
Red ring Error / disconnected
Blue dot Operation in progress
Docker Simulation Environment
A multi-profile PLC simulator is included for development and testing.
docker compose up -d
Services
Container Description Port
plc-clx ControlLogix simulator 44818
plc-cplx CompactLogix simulator 44819
plc-micro Micro800 simulator 44820
plc-mlx MicroLogix simulator (PCCC) 44821
plc-plc5 PLC-5 simulator (PCCC) 44822
drive-powerflex525 PowerFlex 525 drive — implicit Class 1 I/O 44823 (TCP) + 2222 (UDP)
node-red Node-RED with pre-loaded test flows 11880
Simulator Profiles
Each profile provides a realistic tag set:
  • ControlLogix — scalars (BOOL, INT, DINT, REAL, LINT), arrays (MyIntArray INT[10], MyRealArray REAL[5]), program-scoped tags (Program:MainProgram.Speed, Program:MainProgram.Recipe INT[8]), a STRING tag MyString, a UDT testVarUDT with two STRING members and an INT, and a nested UDT array FIS_Stn : FIS_STATION[5] whose Local member holds FBCONTROL DINT[2], FBFACTUAL REAL[102], FBCOMPARE REAL[102] and FBRESULT DINT[2] — 832 bytes per element, so struct reads exercise fragmentation
  • CompactLogix — Same as CLX
  • Micro800 — 24 I/O tags (10 DO + 14 DI, all BOOL)
  • MicroLogix — PCCC registers (N7, F8, B3, T4, C5, S)
  • PLC-5 — PCCC registers
  • PowerFlex 525 — no tags; implicit Class 1 I/O only (assemblies: Output 2 / Input 1 / Config 6). Models the drive's strict Forward_Open acceptance — the connection is granted only when the produced/consumed assemblies use Connection Point path segments and the transport is Server + Class 1
Simulated CIP Services
Service Code Description
RegisterSession 0x0065 Session establishment
ForwardOpen/Close 0x54/0x4E Connected messaging
ReadTag 0x4C Read tag values — honours the requested element count, answers 0xFF/0x2105 past the end of a tag
ReadTagFragmented 0x52 Continues a read too large for one packet (structs, long arrays)
WriteTag 0x4D Write tag values
GetInstanceAttributeList 0x55 Tag browsing — type word carries the array and structure flags
GetAttributeAll 0x01 Controller identity
GetAttributeSingle 0x0E Single attribute read, incl. Symbol Object array dimensions (attr 8)
Template Object 0x6C UDT definitions — attributes and Read Template, so struct tags decode
ExecutePCCC 0x4B PCCC over CIP
MultipleServicePacket 0x0A Batch operations
Implicit I/O (Class 1) — Cyclic UDP assemblies for the PowerFlex 525 drive profile (ForwardOpen + UDP 2222)
Quick Start
# Start everything
# Open Node-RED
open http://localhost:11880
# View simulator logs
docker compose logs -f plc-clx
# Stop
docker compose down
Example Flows
Pre-built flows are included in examples/:
  • basic-read-write.json — Simple read/write operations
  • full-test-flow.json — 6 tabs covering all simulators and node types
Import via Node-RED: Menu > Import > select file.
Testing
npm test
Tests cover:
  • Tag name parsing (bit, array, range, program-scoped)
  • Tag path canonicalisation against the controller's tag list and UDT templates
  • Array length resolution (Symbol Object dimensions, bisecting index probe, caching)
  • Bit manipulation (getBit, setBit, buildBitMasks)
  • CIP status/type name resolution, including Connection Manager extended status
  • PCCC address parsing (all file types, sub-elements, bit access)
  • PCCC command building and response parsing
  • CIP path building (8-bit/16-bit segments, attributeId edge cases)
  • Forward_Open framing — strict PowerFlex 525 acceptance (transport byte, Connection Point vs Instance segments, electronic key parsing)
  • cip-read end-to-end — the real node reads whole arrays, nested UDTs, arrays of UDTs, ranges, program-scoped tags and batches from the ControlLogix simulator, over fragmented responses
  • cip-write end-to-end — the real node writes against the ControlLogix simulator: the Data Type check, bit writes including the sign bit, partial UDT writes, and text to STRING tags and STRING members (empty, non-ASCII, full length, too long)
  • cip-io-scanner end-to-end — the real node drives the PowerFlex 525 simulator over TCP ForwardOpen + cyclic UDP I/O, asserting the connection establishes, data flows both directions, and a refused connection surfaces its extended status
To exercise implicit I/O manually without Docker, run the drive simulator directly and point a cip-io-scanner node (Output 2 / Input 1 / Config 6, sizes 4 / 8, Run/Idle on) at 127.0.0.1:44818:
npm run sim:pf525
API Reference
cip-read Output
  "payload": "<tag value>",
  "tagName": "MyDint",
  "dataType": "DINT",
  "timestamp": 1710000000000
Batch read (msg.tags) — payload is an array in the order requested, and a tag that could not be read carries an error string instead of a value:
  "payload": [
    { "tagName": "MyDint", "value": 42, "type": "DINT" },
    { "tagName": "MyIntArray", "value": [100, 200, 300], "type": "INT" },
    { "tagName": "Missing", "value": null, "type": "", "error": "..." }
cip-write Input
  "payload": 42,
  "tagName": "MyDint"
cip-subscribe Output
Single tag:
  "payload": 42,
  "dataType": "DINT",
  "changed": true,
  "scanRate": 1000,
Multi-tag:
  "payload": { "Tag1": 42, "Tag2": 3.14 },
  "tags": [
    { "name": "Tag1", "value": 42, "type": "DINT", "changed": true },
    { "name": "Tag2", "value": 3.14, "type": "REAL", "changed": false }
  "scanRate": 1000,
cip-raw Input
  "service": 14,
  "classId": 1,
  "instanceId": 1,
  "attributeId": 1,
  "data": null
Multiple Service Packet:
  "requests": [
    { "service": 14, "classId": 1, "instanceId": 1, "attributeId": 1 },
    { "service": 14, "classId": 1, "instanceId": 1, "attributeId": 7 }
cip-pccc-read Output
  "payload": 1234,
  "address": "N7:0",
  "fileType": "Integer",
Dependencies
Requirements
  • Node.js >= 16.0.0
  • Node-RED >= 2.0.0
Sponsor this project
This package is developed and maintained in my own time. If it saves you some, consider supporting it:
Sponsor on GitHub Buy Me a Coffee
Apache License 2.0 — see LICENSE and NOTICE.
Copyright 2026 blanpa
Contributing and forks
Pull requests are welcome, including large ones. If you are planning a bigger change — a dependency migration, a restructure, new nodes — please open an issue first. We are happy to discuss it and to land substantial work here; that is usually less effort than maintaining a parallel package, and it keeps a single place for users to report bugs.
If you do publish a fork under its own package name, please also rename the Node-RED node type IDs (for example myprefix-cip-suite-*) and use your own palette category. Node-RED refuses to register a node type that is already claimed, so identical type IDs make it impossible to install both packages side by side.
This package is better than it would have been alone. Thank you to everyone who has contributed code, and to everyone who took the time to report a problem properly — several releases exist because someone described a bug well enough to reproduce it.
Contribution
@Steve-Mcl (Stephen McLaughlin) Dynamic/runtime connection management (#12, #10), the connection lifecycle rework that made a dropped PLC detectable at all (#11), and the tag browse fix (#13)
@cgraun Reported that arrays returned only their first element (#4), which uncovered the UDT array, tag casing and program scope bugs fixed in 0.0.7
@rmsems Reported the PowerFlex 525 drive control gaps (#3), which led to the extended Forward_Open diagnostics and the drive simulator profile
@QvixoteRoux Fixed bit writes on the sign bit of INT and SINT tags and verified them on a 1769-L36ERM (#35)
@giovannapalomba Reported that text could not be written to a STRING tag, with the root cause and a proposed fix (#36), and confirmed the fix on a Compact GuardLogix 5380
New contributors are welcome — see Contributing and forks above.
Version: 0.2.2
Updated 1 week, 3 days ago
Rating: 5.0 5
352 in the last week
  • cip-endpoint
  • cip-read
  • cip-write
  • cip-browse
  • cip-raw
  • cip-subscribe
  • cip-discover
  • cip-controller
  • cip-pccc-endpoint
  • cip-pccc-read
  • cip-pccc-write
  • cip-io-scanner
  • cip-security
  • cip-sync
  • cip-motion
  • cip-energy
  • cip-file
  • cip-param
  • ethernet-ip
  • cip
  • allen-bradley
  • rockwell
  • plc
  • controllogix
  • compactlogix
  • micro800
  • micro850
  • slc500
  • micrologix
  • plc5
  • pccc
  • industrial
  • automation
  • scada
  • iiot
  • iot
  • hmi
  • cip-security
  • cip-motion
  • cip-sync
  • cip-energy
  • ieee-1588
  • ptp
