node-red-contrib-cip 1.2.1
Connects node-red with Crestron processors though CIP protocol
npm install node-red-contrib-cip
npm version License: ISC Node-RED GitHub issues
Professional Node-RED nodes for seamless integration with Crestron control systems through the CIP (Crestron Internet Protocol). This package provides both client and server nodes, enabling bidirectional communication with Crestron processors.
šŸ”¬ Reverse-Engineered Protocol: This implementation is based on comprehensive reverse-engineering of the proprietary Crestron Internet Protocol (CIP), achieved through extensive network traffic analysis, packet inspection, and protocol behavior study. The library provides a complete, independent implementation of the CIP protocol stack.
✨ Features
šŸ”Œ Dual Node Architecture
  • CIP Client Node: Connect Node-RED to Crestron processors as a client
  • CIP Server Node: Allow Crestron processors to connect to Node-RED as clients
šŸ“” Complete Protocol Support
  • Digital Joins: Boolean control (lights, relays, switches)
  • Analog Joins: Numeric control (volume, dimming, position: 0-65535)
  • Serial Joins: String communication (text, commands, feedback)
  • Smart Objects: Advanced UI controls with intelligent state management
  • Pulse Commands: Momentary button presses with configurable timing
  • Real-time Feedback: Instant status updates from Crestron systems
šŸš€ Enterprise Features
  • Automatic Reconnection: Robust connection management with configurable timeouts
  • Smart Object Support: Advanced UI controls with dynamic lists, keypads, and button arrays
  • Heartbeat Monitoring: Built-in ping/pong mechanism for connection health
  • Packet-level Debugging: Comprehensive logging for troubleshooting
  • State Synchronization: Full system state retrieval on connection
  • TypeScript Support: Complete type definitions included
šŸ”§ Development Tools
  • Docker Environment: Pre-configured development setup
  • Debug Logging: Detailed CIP protocol inspection
šŸ“¦ Installation
Via Node-RED Palette Manager
  1. Open Node-RED in your browser
  2. Go to Menu → Manage Palette
  3. Click the "Install" tab
  4. Search for node-red-contrib-cip
  5. Click "Install"
Via npm
Via Docker (Development)
git clone https://github.com/moty66/node-red-contrib-cip.git
cd node-red-contrib-cip
docker-compose up --build
Access Node-RED at http://localhost:1880 with the plugin pre-installed.
šŸŽÆ Quick Start
1. CIP Client Setup (Node-RED → Crestron)
Crestron Configuration:
// In your Crestron program, add an Ethernet device
ETHERNET_SERVER MyServer {
    DEVICE = "192.168.1.100:41794";  // Node-RED IP
    IPID = 04;
Node-RED Configuration:
// Node configuration
  name: "Crestron Processor",
  host: "192.168.1.50",    // Crestron processor IP
  port: 41794,             // CIP port (default)
  ipid: "04",              // Must match Crestron IPID (hex)
  reconnect: true,
  timeout: 10000
2. CIP Server Setup (Crestron → Node-RED)
// Server node configuration
  port: 41794,             // Listening port
  ipid: "04",              // Server IPID (hex)
  debug: false,
  timeout: 10000
// Configure Crestron to connect to Node-RED server
ETHERNET_CLIENT MyClient {
    DEVICE = "192.168.1.100:41794";  // Node-RED server IP:port
    IPID = 04;
šŸ’” Usage Examples
Digital Control (Lights, Relays)
// Turn on light (Digital Join 1)
msg.payload = {
  type: "event",
  payload: {
    type: "digital",
    join: 1,
    data: true, // true = on, false = off
Analog Control (Volume, Dimming)
// Set volume to 75% (Analog Join 5)
msg.payload = {
  type: "event",
  payload: {
    type: "analog",
    join: 5,
    data: 49152, // 75% of 65535
Serial Communication (Text, Commands)
// Send text to display (Serial Join 10)
msg.payload = {
  type: "event",
  payload: {
    type: "serial",
    join: 10,
    data: "Conference Room Available",
Button Press Simulation
// Simulate 500ms button press (Digital Join 3)
msg.payload = {
  type: "event",
  payload: {
    type: "pulse",
    join: 3,
    time: 500, // milliseconds
System Synchronization
// Request current state of all joins
msg.payload = {
  type: "sync",
šŸŽ›ļø Smart Objects
Smart Objects provide advanced UI control capabilities beyond basic joins, allowing for complex interface elements like dynamic lists, button arrays, and interactive controls. Smart Objects are available with the CIP Server node.
Supported Smart Object Types
šŸ“‹ Dynamic List
Interactive lists with programmable content and selection handling.
// Register a dynamic list
msg.payload = {
  type: "registerSmartObject",
  payload: {
    smartObjectId: 101,
    profile: "dynamicList",
    config: {
      maxItems: 20,
      allowMultipleSelection: false,
// Set list item count
msg.payload = {
  type: "smartObject",
  payload: {
    smartObjectId: 101,
    action: "setItemCount",
    itemCount: 5,
// Set list item text
msg.payload = {
  payload: {
    smartObjectId: 101,
    action: "setItemText",
    itemIndex: 1,
    text: "Living Room",
// Enable/disable list item
msg.payload = {
  payload: {
    smartObjectId: 101,
    action: "setItemEnabled",
    itemIndex: 1,
    enabled: true,
šŸ“„ Page Reference
Multi-page navigation controls with page switching and button management.
// Register a page reference
msg.payload = {
  payload: {
    smartObjectId: 102,
    profile: "pageReference",
    config: {
      totalPages: 5,
      showNavButtons: true,
// Select a page
msg.payload = {
  payload: {
    smartObjectId: 102,
    action: "selectPage",
    pageNumber: 3,
// Enable/disable navigation button
msg.payload = {
  payload: {
    smartObjectId: 102,
    action: "setButtonEnabled",
    buttonNumber: 1,
    enabled: false,
šŸ”˜ Button List
Arrays of programmable buttons with individual text and state control.
// Register a button list
msg.payload = {
  payload: {
    smartObjectId: 103,
    profile: "buttonList",
    config: {
      buttonCount: 8,
      allowToggle: true,
// Set button text
msg.payload = {
  payload: {
    smartObjectId: 103,
    action: "setText",
    buttonIndex: 1,
    text: "Power",
// Enable/disable button
msg.payload = {
  payload: {
    smartObjectId: 103,
    action: "setEnabled",
    buttonIndex: 1,
    enabled: true,
šŸ”¢ Keypad
Numeric input controls with display feedback and key simulation.
// Register a keypad
msg.payload = {
  payload: {
    smartObjectId: 104,
    profile: "keypad",
    config: {
      allowDecimal: true,
      maxValue: 999,
      minValue: 0,
// Send key press
msg.payload = {
  payload: {
    smartObjectId: 104,
    action: "sendKey",
    keyValue: "5",
// Set display text
msg.payload = {
  payload: {
    smartObjectId: 104,
    action: "setDisplay",
    displayText: "125",
// Enable/disable keypad
msg.payload = {
  payload: {
    smartObjectId: 104,
    enabled: true,
Smart Object Events
Smart Objects generate specialized events that provide context about user interactions:
// Smart Object event output
  "topic": "smartObject",
  "payload": {
    "type": "smartObject",
    "smartObjectId": 101,
    "join": 1,
    "data": {
      "action": "itemSelected",
      "itemIndex": 3,
      "itemText": "Kitchen",
      "currentPage": 1
    "timestamp": "2025-08-16T10:30:00.000Z"
Advanced Smart Object Features
State Tracking
// Get current page of a page reference
msg.payload = {
  type: "getSmartObjectState",
  payload: {
    smartObjectId: 102,
    property: "currentPage",
// Get all registered Smart Objects
msg.payload = {
  type: "getRegisteredSmartObjects",
Batch Operations
// Configure multiple items at once
msg.payload = {
  payload: {
    smartObjectId: 101,
    action: "batchSetItems",
    items: [
      { index: 1, text: "Zone 1", enabled: true },
      { index: 2, text: "Zone 2", enabled: true },
      { index: 3, text: "Zone 3", enabled: false },
šŸ“Š Node Outputs
Output 1: Join Events
Real-time events from Crestron processor:
// Digital join feedback
  payload: {
    join: 1,
    data: true,
    type: "digital"
// Analog join feedback
  payload: {
    join: 5,
    data: 32768,
    type: "analog"
// Serial join feedback
  payload: {
    join: 10,
    data: "Status: Online",
    type: "serial"
// Smart Object interaction
  payload: {
    join: 1,
    data: {
      smartObjectId: 101,
      action: "itemSelected",
      itemIndex: 3,
      itemText: "Kitchen",
      currentPage: 1
    type: "smartObject"
Output 2: Connection Status
System events and connection status:
// Connection established
{ connected: true }
// Connection lost
{ connected: false, error: "Connection timeout" }
// Update events
{ connected: true, update: { status: "ready" } }
// Server-specific: client connected
{ connected: true, clientConnected: true }
šŸŽ›ļø Smart Object Configuration
Smart Objects require specific configuration in both Node-RED and Crestron Studio for proper operation.
Crestron Studio Setup
  1. Add Smart Object to Your Project:
    - In Crestron Studio, add desired Smart Objects to your project
    - Configure Smart Object IDs (typically 101-199)
    - Program SIMPL logic to handle Smart Object events
  2. Smart Object ID Mapping:
    Smart Object Type Suggested ID Range Purpose
    Dynamic Lists 101-110 Room/Zone selection
    Page References 111-120 Multi-page navigation
    Button Lists 121-130 Function button arrays
    Keypads 131-140 Numeric input controls
  3. SIMPL Programming Example:
    // For Dynamic List Smart Object ID 101
    Smart_Object_101.Item_Clicked -> [Your logic here]
    Smart_Object_101.Current_Item_Text$ -> [Process selected item]
Smart Objects must be registered before use:
// Register Smart Objects on connection
msg.payload = [
    payload: {
      smartObjectId: 101,
      config: { maxItems: 20 },
    payload: {
      smartObjectId: 102,
      config: { totalPages: 5 },
Configuration Profiles
Dynamic List Profile
  maxItems: 50,           // Maximum number of items
  allowMultipleSelection: false,  // Allow multi-select
  enableScrolling: true,  // Enable scrolling
  itemHeight: 30         // Item height in pixels
Page Reference Profile
  totalPages: 10,        // Total number of pages
  showNavButtons: true,  // Show navigation buttons
  enableSwipeGestures: true,  // Enable swipe navigation
  loopPages: false       // Loop from last to first page
Button List Profile
  buttonCount: 12,       // Number of buttons
  allowToggle: true,     // Allow toggle state
  buttonStyle: "raised", // "raised" or "flat"
  columns: 3            // Number of columns
Keypad Profile
  allowDecimal: true,    // Allow decimal input
  maxValue: 9999,       // Maximum value
  minValue: 0,          // Minimum value
  maxDigits: 4,         // Maximum digits
  showDisplay: true     // Show numeric display
šŸ”§ Configuration Options
Parameter Description Default Required
name Display name for the node "Crestron" No
host Crestron processor IP address - Yes (Client)
port CIP protocol port 41794 Yes
ipid Hexadecimal IPID value "04" Yes
reconnect Enable automatic reconnection true No
timeout Connection timeout (ms) 10000 No
debug Enable packet-level debugging false No
šŸ› ļø Development
Local Development Setup
  1. Clone the repository:
  2. Start development environment:
  3. Access Node-RED: Open http://localhost:1880 in your browser
  4. Enable debug logging:
    DEBUG=CIP* node-red
Project Structure
node-red-contrib-cip/
ā”œā”€ā”€ lib/node-cip/                    # Core CIP protocol library
│   ā”œā”€ā”€ cip.js                       # CIP client implementation
│   ā”œā”€ā”€ cip-server.js               # CIP server implementation
│   ā”œā”€ā”€ helpers/                    # Protocol helpers
│   │   ā”œā”€ā”€ cip-input.helper.js     # Message parsing
│   │   └── cip-output.helper.js    # Message building
│   ā”œā”€ā”€ constants/                  # Protocol constants
│   └── interfaces/                 # TypeScript interfaces
ā”œā”€ā”€ node-red-contrib-cip.js         # Client node implementation
ā”œā”€ā”€ node-red-contrib-cip.html       # Client node UI
ā”œā”€ā”€ node-red-contrib-cip-server.js  # Server node implementation
ā”œā”€ā”€ node-red-contrib-cip-server.html# Server node UI
ā”œā”€ā”€ docker-compose.yml              # Development environment
└── package.json                    # Package configuration
Making Changes
# For code changes
docker-compose restart
# For package.json changes
docker-compose down && docker-compose up --build
šŸ” Protocol Implementation Details
Reverse Engineering Achievement
This library represents a complete reverse-engineering of Crestron's proprietary CIP protocol, accomplished through:
  • Network Traffic Analysis: Deep packet inspection of Crestron-to-Crestron communications
  • Protocol State Mapping: Understanding connection handshakes, authentication, and state management
  • Message Format Decoding: Binary protocol structure analysis and documentation
  • Timing Behavior Study: Heartbeat intervals, timeout handling, and reconnection logic
  • Join Type Implementation: Digital, analog, serial, and unicode message formats
Technical Specifications
Feature Implementation
Protocol Version CIP (Crestron Internet Protocol)
Transport TCP/IP
Default Port 41794
Message Format Binary protocol with custom headers
Heartbeat 5-10 second ping intervals
Authentication IPID-based device identification
Join Types Digital, Analog, Serial, Unicode
Reconnection Configurable automatic retry logic
Message Types Supported
  • 0x00: ACK
  • 0x01: Server Sign-on
  • 0x02: Connection Accepted
  • 0x04: Connection Refused
  • 0x05: Join Event
  • 0x0a: Client Sign-on
  • 0x0d: Ping
  • 0x0e: Pong
  • 0x0f: Who Is
  • 0x12: Unicode
🚨 Troubleshooting
Common Issues
1. Connection Refused
Error: Connection refused by Crestron processor
Solutions:
  • Verify IPID matches between Node-RED and Crestron program
  • Check that the IPID exists in Crestron's IP table
  • Ensure network connectivity (ping test)
  • Verify port 41794 is not blocked by firewall
2. No Response from Joins
Joins not responding to commands
Solutions:
  • Verify join numbers are correct (1-based indexing)
  • Check Crestron program logic for join assignments
  • Enable debug logging: DEBUG=CIP* node-red
  • Confirm join types match (digital/analog/serial)
3. Frequent Disconnections
Connection drops repeatedly
Solutions:
  • Increase timeout value in node configuration
  • Check network stability and latency
  • Verify Crestron processor is not overloaded
  • Review debug logs for specific error patterns
Debug Mode
Enable comprehensive debugging:
# Start Node-RED with debug logging
DEBUG=CIP* node-red
# Docker environment
docker-compose up  # DEBUG=* already configured
Debug Output Example:
CIP ## connecting. { host: '192.168.1.50', port: 41794, ipid: 4 }...
CIP ## connection opened
CIP <= ipid 4
CIP => accepted
CIP <= ping request n° 1
CIP => pong
CIP => digital 1: High
Network Requirements
  • Connectivity: Node-RED and Crestron processor must be on same network or routable
  • Firewall: Port 41794 must be open for TCP connections
  • Latency: Low-latency network recommended for real-time control
  • Bandwidth: Minimal bandwidth required (~1-10 Kbps typical)
šŸ¤ Contributing
We welcome contributions! Please see our Contributing Guide for details.
Development Workflow
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests if applicable
  5. Submit a pull request
Reporting Issues
  • Use GitHub Issues for bug reports
  • Include debug logs when possible
  • Specify Node-RED and Crestron firmware versions
  • Provide network configuration details
šŸ“„ License
This project is licensed under the ISC License - see the LICENSE file for details.
šŸ™ Acknowledgments
  • Crestron Electronics: For creating innovative control systems that inspired this project
  • Node-RED Community: For the excellent platform and development tools
  • Open Source Community: For protocols, libraries, and inspiration
šŸ“ž Support
Built with ā¤ļø by Motaz Abutihab
Bringing Crestron control systems into the Node-RED ecosystem through innovative protocol reverse-engineering.
Version: 1.2.1
Updated 8 months ago
Rating: 5.0 5
4 in the last week
  • node-red-contrib-cip
  • node-red-contrib-cip-server
  • crestron
  • cip
  • automation
  • home-automation
  • av
  • control-system
