node-red-contrib-chromadb 1.0.0
ChromaDB Node for Node-RED
npm install node-red-contrib-chromadb
Chroma is the open-source embedding database. Chroma makes it easy to build LLM apps by making knowledge, facts, and skills pluggable for LLMs.
Ubos - End-to-End Software Development Platform
UBOS • Community • Youtube • Discord • GitHub
Restart your Node-RED instance.
Methods Client
createCollection (more details)
▸ createCollection(params): Promise<Collection>
Creates a new collection with the specified properties.
Throws
If there is an issue creating the collection.
Example
msg.collection = "my_collection";
msg.payload = {
    metadata: {
        description: "My first collection"
Parameters
Name Type Description
params Object The parameters for creating a new collection.
params.embeddingFunction? IEmbeddingFunction Optional custom embedding function for the collection.
params.metadata? CollectionMetadata Optional metadata associated with the collection.
params.name string The name of the collection.
Returns
Promise<Collection>
A promise that resolves to the created collection.
deleteCollection (more details)
▸ deleteCollection(params): Promise<void>
Deletes a collection with the specified name.
Throws
If there is an issue deleting the collection.
Example
msg.payload = {};
Parameters
params Object The parameters for deleting a collection.
Returns
Promise<void>
A promise that resolves when the collection is deleted.
getCollection (more details)
▸ getCollection(params): Promise<Collection>
Gets a collection with the specified name.
Throws
If there is an issue getting the collection.
Example
msg.payload = {};
Parameters
params Object The parameters for getting a collection.
Returns
Promise<Collection>
A promise that resolves to the collection.
getOrCreateCollection (more details)
▸ getOrCreateCollection(params): Promise<Collection>
Gets or creates a collection with the specified properties.
Throws
If there is an issue getting or creating the collection.
Example
msg.payload = {
    metadata: {
Parameters
Returns
Promise<Collection>
A promise that resolves to the got or created collection.
heartbeat (more details)
▸ heartbeat(): Promise<number>
Returns a heartbeat from the Chroma API.
Returns
Promise<number>
A promise that resolves to the heartbeat from the Chroma API.
listCollections (more details)
▸ listCollections(): Promise<CollectionType[]>
Lists all collections.
Throws
If there is an issue listing the collections.
Returns
A promise that resolves to a list of collection names.
reset (more details)
▸ reset(): Promise<Reset200Response>
Resets the state of the object by making an API call to the reset endpoint.
Throws
If there is an issue resetting the state.
Returns
A promise that resolves when the reset operation is complete.
version (more details)
▸ version(): Promise<string>
Returns the version of the Chroma API.
Returns
Promise<string>
A promise that resolves to the version of the Chroma API.
Methods Collection
add (more details)
▸ add(params): Promise<AddResponse>
Add items to the collection
Example
msg.payload = {
    ids: ["id1", "id2"],
    embeddings: [
        [1, 2, 3],
        [4, 5, 6],
    metadatas: [{ key: "value" }, { key: "value" }],
    documents: ["document1", "document2"],
Parameters
params Object The parameters for the query.
params.documents? string | Documents Optional documents of the items to add.
params.embeddings? Embedding | Embeddings Optional embeddings of the items to add.
params.ids string | IDs IDs of the items to add.
params.metadatas? Metadata | Metadatas Optional metadata of the items to add.
Returns
  • The response from the API. True if successful.
count (more details)
▸ count(): Promise<number>
Count the number of items in the collection
Example
msg.payload = {};
Returns
Promise<number>
delete (more details)
▸ delete(params?): Promise<string[]>
Deletes items from the collection.
Throws
If there is an issue deleting items from the collection.
Example
msg.payload = {
    ids: "some_id",
    where: { key: "value" },
    whereDocument: { "$contains": "search_string" }
Parameters
params Object The parameters for deleting items from the collection.
params.ids? string | IDs Optional ID or array of IDs of items to delete.
params.where? Where Optional query condition to filter items to delete based on metadata values.
params.whereDocument? WhereDocument Optional query condition to filter items to delete based on document content.
Returns
Promise<string[]>
A promise that resolves to the IDs of the deleted items.
get (more details)
▸ get(params?): Promise<GetResponse>
Get items from the collection
Example
msg.payload = {
    limit: 10,
    offset: 0,
    include: ["embeddings", "metadatas", "documents"],
    whereDocument: { $contains: "value" },
Parameters
params.ids? string | IDs Optional IDs of the items to get.
params.include? IncludeEnum[] Optional list of items to include in the response.
params.limit? number Optional limit on the number of items to get.
params.offset? number Optional offset on the items to get.
params.where? Where Optional where clause to filter items by.
params.whereDocument? WhereDocument Optional where clause to filter items by.
Returns
  • The response from the server.
modify (more details)
▸ modify(params?): Promise<void>
Modify the collection name or metadata
Example
msg.payload = {
    name: "new collection name",
    metadata: { key: "value" },
Parameters
params.metadata? CollectionMetadata Optional new metadata for the collection.
params.name? string Optional new name for the collection.
Returns
Promise<void>
peek (more details)
▸ peek(params?): Promise<GetResponse>
Peek inside the collection
Throws
If there is an issue executing the query.
Example
msg.payload = {
    limit: 10,
Parameters
params.limit? number Optional number of results to return (default is 10).
Returns
A promise that resolves to the query results.
query (more details)
▸ query(params): Promise<QueryResponse>
Performs a query on the collection using the specified parameters.
Throws
Example
// Query the collection using embeddings
msg.payload = {
    queryEmbeddings: [0.1, 0.2],
    nResults: 10,
    include: ["metadata", "document"]
Example
// Query the collection using query text
msg.payload = {
    queryTexts: "some text",
    nResults: 10,
Parameters
params.include? IncludeEnum[] Optional array of fields to include in the result, such as "metadata" and "document".
params.nResults? number Optional number of results to return (default is 10).
params.queryEmbeddings? Embedding | Embeddings Optional query embeddings to use for the search.
params.queryTexts? string | string[] Optional query text(s) to search for in the collection.
params.where? Where Optional query condition to filter results based on metadata values.
params.whereDocument? WhereDocument Optional query condition to filter results based on document content.
Returns
update (more details)
▸ update(params): Promise<boolean>
Update the embeddings, documents, and/or metadatas of existing items
Example
msg.payload = {
    embeddings: [
        [1, 2, 3],
        [4, 5, 6],
    documents: ["new document 1", "new document 2"],
Parameters
params.documents? string | Documents Optional documents to update.
params.embeddings? Embedding | Embeddings Optional embeddings to update.
params.ids string | IDs The IDs of the items to update.
params.metadatas? Metadata | Metadatas Optional metadatas to update.
Returns
Promise<boolean>
  • The API Response. True if successful. Else, error.
upsert (more details)
▸ upsert(params): Promise<boolean>
Upsert items to the collection
Example
msg.payload = {
    embeddings: [
        [1, 2, 3],
        [4, 5, 6],
Parameters
Returns
Promise<boolean>
Bugs reports and feature requests
Please report any issues or feature requests at GitHub.
MIT License
Version: 1.0.0
Updated 3 years, 3 months ago
Rating: 5.0 2
1 in the last week
  • remote-server-client
  • chromadb-client
  • remote-server-collection
  • chromadb-collection
  • vector
  • database
  • chromadb
  • embedding
